Topic: foo_musicbrainz (Read 283007 times) previous topic - next topic
foo_musicbrainz
Reply #75
Seems to be fairly successful at finding the right album, nice work.
Just one suggestion, can you give the option to wipe previous tags when applying the new musicbrainz tags?
foo_musicbrainz
Reply #76
Proxy support please!
foo_musicbrainz
Reply #77
I hope this plugin is still being developed!
I have a few suggestions:
1.) Support for more information such as composer info or Label or any information available from musicbrainz
2.) Ability to manually set which information we want to tag, which not and allow us to change the way info is tagged on the files (ie: I use %album_relasedate% instead of %date% for the album release date)
I have another question, I'm not familiar with the Musicbrainz API but is it possible to update the Musicbrainz DB from within Foobar? For example to make corrections or add albums. Can Picard or any other musicbrainz tagger program do that? I'd love to contribute more to Musicbrainz but I cringe at the possibility of editing everything by hand on the site...
foo_musicbrainz
Reply #78
It seems that lookup by Album ID does not work anymore. It uses the following URL segment for release - /ws/1/release/{release_id}, while it should be ws/1/release-group/{release_id}.
Could you please fix it?
foo_musicbrainz
Reply #79
Second this. Musicbrainz has changed their URI scheme since the last version of the plugin was released.
foo_musicbrainz
Reply #80
Hey,
I use EAC to rip CDs to FLAC image + CUE sheet (with default gap detection). When the CD has HTOA:
REM DISCID 3A0B4D05
FILE "image.flac" WAVE
  TRACK 01 AUDIO
    INDEX 00 00:00:00
    INDEX 01 00:00:32
  TRACK 02 AUDIO
    INDEX 01 05:33:20
  TRACK 03 AUDIO
    INDEX 00 13:21:65
    INDEX 01 13:22:65
  TRACK 04 AUDIO
    INDEX 00 16:14:57
    INDEX 01 16:16:57
  TRACK 05 AUDIO
    INDEX 00 19:26:05
    INDEX 01 19:28:05
and I use foobar2000 to convert this image to separate tracks (gaps appended I assume) then I can't use TOC lookup in MusicBrainz:
URI: /ws/1/release/?type=xml&discid=sYIYkpYbJjZvvemDRl7NpWAFM0k-&count=5
If I try on CUE sheet tracks, everything is fine:
URI: /ws/1/release/?type=xml&discid=WbnYzKGBYkSS1_hcICed9K2nxZQ-&count=5
The files produced this way, have valid DISCID (FreeDB ID) tag as showed by CUE sheet
Thanks for your attention, and hope it's worth adding couple of code lines
foo_musicbrainz
Reply #81
I suspect that it is the gap detection that is causing this. Foobar only converts what is played so in this case, no gaps are not appended. The original TOC contains 2 second silence, however since the index00s are not part of the disc and are created by EAC the "TOC" of the new files is different to the original. So when looking up this new TOC it is not found in the database.
Removing all the index 00s should work.
foo_musicbrainz
Reply #82
I think we misunderstood because I used CueTools terminology. I'm trying to remove all .NET/Java apps from my system (more from practical then puritan reasons) which would mean removing also CueTools
I would say that foobar2000 converter splits tracks by appending gaps, which is done by not considering INDEX 00. Gaps are not prepended nor left out, while foobar2000 does not care about. HTOA is generally pregap on Track 01 for CueTools users.
Removing INDEX 00 does not solve the problem obviously as foobar2000 does that for me while converting
Trying to guess what this component is doing by manually calculating MusicBrainz Disc ID is not worth the effort as I'm afraid I wont be able to resolve it automatically in later time. I thought problem must be start offset, but after your reply I tried on couple of other disc images and now I really can't think of it. Here is example of CUE sheet from flac image that does TOC lookup even when converted to separate tracks:
REM DISCID 75104C09
FILE "The Balanescu Quartet - Possessed.flac" WAVE
  TRACK 01 AUDIO
    INDEX 00 00:00:00
    INDEX 01 00:00:42
  TRACK 02 AUDIO
    INDEX 00 08:41:12
    INDEX 01 08:42:45
  TRACK 03 AUDIO
    INDEX 01 12:26:72
  TRACK 04 AUDIO
    INDEX 00 18:46:32
    INDEX 01 18:49:27
  TRACK 05 AUDIO
    INDEX 00 25:06:55
    INDEX 01 25:09:40
  TRACK 06 AUDIO
    INDEX 00 28:55:40
    INDEX 01 28:58:70
  TRACK 07 AUDIO
    INDEX 00 45:50:60
    INDEX 01 45:53:30
  TRACK 08 AUDIO
    INDEX 00 53:34:15
    INDEX 01 53:35:70
  TRACK 09 AUDIO
    INDEX 00 64:34:65
    INDEX 01 64:37:05
Here is another one that does not, but resolves by TOC only on CUE sheet tracks:
REM DISCID C9119F0F
FILE "The Legendary Pink Dots - Asylum.flac" WAVE
  TRACK 01 AUDIO
    INDEX 00 00:00:00
    INDEX 01 00:00:33
  TRACK 02 AUDIO
    INDEX 01 04:49:13
  TRACK 03 AUDIO
    INDEX 01 07:18:58
  TRACK 04 AUDIO
    INDEX 00 10:04:28
    INDEX 01 10:05:60
  TRACK 05 AUDIO
    INDEX 00 13:39:33
    INDEX 01 13:41:05
  TRACK 06 AUDIO
    INDEX 00 18:01:28
    INDEX 01 18:03:55
  TRACK 07 AUDIO
    INDEX 01 20:39:28
  TRACK 08 AUDIO
    INDEX 00 25:49:10
    INDEX 01 25:50:63
  TRACK 09 AUDIO
    INDEX 00 37:02:33
    INDEX 01 37:04:18
  TRACK 10 AUDIO
    INDEX 00 45:03:00
    INDEX 01 45:05:23
  TRACK 11 AUDIO
    INDEX 00 48:51:33
    INDEX 01 48:54:40
  TRACK 12 AUDIO
    INDEX 01 54:44:35
  TRACK 13 AUDIO
    INDEX 01 59:37:68
  TRACK 14 AUDIO
    INDEX 01 63:44:28
  TRACK 15 AUDIO
    INDEX 01 67:09:63
I could only think that there is some kind of threshold when generating this ID, as by looking at the TOC from MusicBrainz TOC page for the release in my previous post, I can see that none of the three different TOCs provided are same as TOC generated by EAC for my CD. Also not all track have pregap on problematic CUE sheets whatever that can mean for ID generator. But this is just guessing when I don't know what really is happening
Also I thought that MusicBrainz can be looked up upon DISCID aka FreeDB ID: http://musicbrainz.org/bare/cdlookup.html?id=FREEDB_ID, but the system provided is reduced, to say at least.
After all, this is not some big problem, but effort to understand what I can do with this software, although I can't write MusicBrainz data to CUE sheet and then convert it as not all tags are written
foo_musicbrainz
Reply #83
Yes you are right index 00s are ignored, foobar only looks at 01 indexes. However the cue-sheets and separate tracks still produce a different DiscID.
In both cases the first track is shortened by 00:42 and 00:33 respectively (pre-gap), however if you check the release pages you will see the first disc has more than one DiscID, one of which matches a change of 00:42 (so MB returns the album.) However the second album only has one DiscID so is not matched at all. The component has no way of knowing what the pre-gap size was and so has to use 0.
Solution: If looking up by TOC fails: try by Artist/Album, and if that fails: look it up on the site and use by AlbumID.
foo_musicbrainz
Reply #84
Non of linked CD TOCs (Balanescu) has 42 frames as start sector, it's either 150, 182 or 190 frames. But if sector values are shifted to match those start sectors, then there is match in 1st, 3rd and 5th CD TOC, all with difference of 1 CD frame. And indeed this component matches on first CD ID. This also applies to the CD from my first post
I tried to rip this CD with foobar2000 ripper and CUE sheet produced this way is with pregap only to first track (others appended). It's the same result as flac images produced by EAC. Now it seems, that really first track pregap is blocking the way to TOC lookup in some way
foo_musicbrainz
Reply #85
And why would you do that? There is no better rip than a complete image. Just embed the cuesheet instead and no more trouble with online databases.
foo_musicbrainz
Reply #86
I use images for backup and separate tracks for playing. Using images with embedded CUE sheets has its benefits, but I just want separate tracks for regular usage, easily editable and no problem with other software
foo_musicbrainz
Reply #87
Dremora, thank you so very much for your awesome plug-in !
I've been using it for almost a year now without meeting any difficulties, ever.
foo_musicbrainz is just the best foobar2000 plug-in in the universe.
foo_musicbrainz
Reply #88
Is the author still planning to work on this plugin or release the source?
I just need it to apply original release date instead of subrelease date, and that'd probably be a matter of 1 variable change...
foo_musicbrainz
Reply #89
release the source
why. >_>
foo_musicbrainz
Reply #90
I only meant to ask whatever the author was up to, not that he should release it if he's not going to develop it anymore (as it may have sounded?)
No harm done.
foo_musicbrainz
Reply #91
I was asking whats the point in releasing source.
If its GPLed, its useless, and thats a fact.
foo_musicbrainz
Reply #92
I think release the source does not equal GPLed it, look at WSH Panel mod.
foo_musicbrainz
Reply #93
Again, depends on licensing. It should be LGPL or better pretty much. GPL for closed sourced apps == not work.
foo_musicbrainz
Reply #94
hey mudlord, can you stop spoiling threads with you licensing BS?
foo_musicbrainz
Reply #95
If you ever bothered to check the GPL licensing, you will find I am correct.
GPL is viral. So anything it touches, must be GPL too.
foo_musicbrainz
Reply #98
Musicbrainz rollout of NGS has broken this plugin. The returned results do not always match and sometimes it capitalizes everything or can't determine the year,etc. Hopefully the author will take this opportunity to update the plugin with support for more fields, options, etc. I believe he posted somewhere that he was waiting to update until NGS was released, and now it has been.
foo_musicbrainz
Reply #99
First I want to thank everybody for your attention and support of this component!
I also want to inform you that I've started working on a new version of foo_musicbrainz, which is going to be released somewhere in June.
Regarding Szekely's issues: component behaviour shouldn't have been changed a lot due to NGS, as the old web service is still working. The only exception are old release events now being represented as separate releases. Can you please be more specific and give me examples of situations where these things happen? It may as well be a bug of MusicBrainz.
