Topic: foo_discogs (Read 1494825 times) previous topic - next topic
Re: foo_discogs
Reply #3300
Last post before waiting for a reply... This is with foo_discogger:
If I search for the first time I get the JSON error detailed above. When I click search a second time, a modal window "Release format mismatch" pops up which I cannot close and foobar2000 then becomes unresponsive.
Re: foo_discogs
Reply #3301
That´s weird... maybe you are running more than one Foobar 2000 instance at once?
Here is a minor foo_discogs v2.23 (32bits) update.
Tested most releases reported in previous posts and it seems to fix the JSON error.
foo_discogs v2.23 061024.zip
Change log:
- Fixed: Error loading release: JSON Parser Exception Array assertion failed
Re: foo_discogs
Reply #3302
Just wanted to share that above release has solved my issue on discogs.
Real thank you Da Yuyu
Re: foo_discogs
Reply #3303
Anyone having problems with release images?
Last days I noticed that there the option to manage images is not available, there is no album cover preview and no cover images are being downloaded.
I check in the console and I have a message that said.
foo_discogger: Unable to read album thumbnail from cache, index: 0
I have the same problem on random releases, that either no image or only the artist's image is accessible.
I checked the downloaded release json in the cache (https://pastebin.com/rtf8WGqB) and all cover images are there. But in the UI it's only the artist or "manage artwork" checkbox is inactive.
Re: foo_discogs
Reply #3304
da yuyu
Please do the checkbox "excl. those defined in Tag mapping".
foo_discogs removes all the tags (when checkbox is set) and write all info from Discogs.
in case of foo_discogger i must select additionally what tags to be removed or rewritten . it's not convenient.
Thanks in advance.
Re: foo_discogs
Reply #3305
Hey again. I'm trying to update tags of a release but it doesn't work - it doesn't update, even when DISCOGS_RELEASE_ID is set to write+update. I have latest version installed.
Re: foo_discogs
Reply #3306
OK, nevermind - I cleared release cache and it helped.
Re: foo_discogs
Reply #3307
Would it be possible for Discnumber/Totaldiscs to be only tagged for Multidiscreleases?
Same question for Album Artist, i only want i present for releases with multiple Artists. Thanks!
