What you should do with defective Intel CPUs?
- RMA with a similar if not same CPU as before
- Replace your CPU with a different kind of Intel CPUs that doesn't have known stability problems (e.g. 10th gen, 12th gen, and older Intel CPUs than 10th gen)
- Replace Intel CPU with an AMD one
- Wait until Arrow Lake releases (so long as it doesn't have similar stability woes)
- Do nothing (only if you either already applied a temporarily fix or can't apply it for some reason) until your CPU show sign of problems related to it, which in the case, do either of first 4 options above
Total Members Voted: 2
