Topic: foo_vis_spectrum_analyzer (Read 168951 times) previous topic - next topic
Re: foo_vis_spectrum_analyzer
Reply #825
Now the dust seems a bit settled with your foo_uie_text component,
can I expect a bugfix for foo_vis_spectrum_analyzer in regard to windows scaling (125/150/175/225/250/350) peakmeter issues?
https://hydrogenaud.io/index.php/topic,125031.msg1045171.html#msg1045171
Thx
Eventually. It may surprise you but I do have a life besides foobar2000 development.
No. I am not surprised.
It's just that I value bugfixes a whole lot more than adding new functionality.
And as a developer I know that when you are "out" of the code for a period of time fixing old bugs becomes more difficult.
Reply #826
Thx
Don't worry, I've been keeping it warm. ;-)
Reply #827
International Programmers’ Day celebrates the positive changes that programmers make to improve our everyday lives. It is usually held on January 7, but is also popularly celebrated on September 13, or on September 12 in leap years.
~ https://www.timeanddate.com/holidays/world/international-programmers-day
counting the days
Quis custodiet ipsos custodes?
Reply #828
Hi, this is a great component and it has really come a long way since you started development!
One small request / question since perhaps I missed a setting that already does what I'm looking for:
Is there a way to choose where in the DSP chain the analysis happens? I would love to have the analysis happen before application  of any DSPs in the chain as a configurable behavior.
Reply #829
Not that I know of, but hey it WOULD be neat to have a "before/after DSP chain applied" image toggle--interesting (and scary?) to see how much the signal has been changed from the original input.
Reply #830
That is not something a visualization component can affect. And visualization would have no meaning if it worked on data prior to DSPs, it could be entirely invalid in regard to what is actually heard.
If you want scientific measurements of audio files you do not use a realtime visualization eye candy for that.
Reply #831
For educational purposes, would you mind explaining why that is?
Reply #832
DSP chain can do anything to the signal. You could for example see data from an hour ago. You could see empty visualization yet hear perfect audio. Or in reverse, see perfectly valid looking visualization yet hear nothing or only noise.
Visualization has no meaning if it doesn't match what is being played.
If you want to analyze a static file, use a different tool.
Reply #833
But wasn't that @sveakul 's original question: why is there no way to access the raw PCM or other encoded format right after the audio stream has been decoded?
Surely it's a software design choice to send that decoded data first through the DSP chain?
Reply #834
Case, I think you're being overly scientific  ;)  A "FYI" visual reference can have meaning in the fact that it gives perspective as to how applied user effects have "affected" a heretofore original signal.  No scientific analysis sought or expected.
Reply #835
I tend to agree :)
For my use-case, I am using a DSP chain to correct my Beyerdymanic DT1990PROs' overly aggressive 8khz peak. After doing so, the resulting spectrum has subdued values around that area and no longer look like the original graph. However, it does sound correct and probably is correct according to many, many users around the internet. Why then should I not want to show the original spectrum?
Reply #836
By going to Common in the Artwork section and activating the "Show artwork on background" flag, if you do not have the panel active the artwork will not appear.
UP
The problem is always present.
Accurate. At the first instance of restarting foobar2000 the images / covers / artwork appear.
But if you jump track the images are not updated.
Reply #837
Suggestion: Infinite average spectrum/cumulative average graph
X
Like the RMS spectrum in foo_enhanced_spectrum_analyzer, but with infinite averaging that eventually converge to the particular curve when you let the analyzer running for long enough with an equation:
for (let i = 0; i < averageSpectrum.length; i++) {
  averageSpectrum[i] = (data[i] + cumulativeIdx*(isFinite(averageSpectrum[i]) ? averageSpectrum[i] : 0))/(cumulativeIdx+1)
cumulativeIdx++ // being incremented by one every time you calculate the infinite average spectrum
Of course, since infinite averaging never decays, this infinite average spectrum should be reset on seek or when playing new track(s) alongside the main spectrum and peaks like foo_enhanced_spectrum_analyzer
Reply #838
[attach type=image]31580[/attach]
Please no. I just want a simple long overdue bugfix instead if new features.
Reply #839
I agreed with you, so for @pqyt, better off bugfixing this component first before adding new features
Reply #840
Strange:  there is a stream Nordic Chillout Radio (http://176.9.86.211:8023/stream) that according to Foobar v.2.2 x64 Properties is being sent at a sample rate of 7350 Hz--I find that hard to believe unless Foobar is resampling it internally (I did not have that sample rate in my "resample only" list in my active DSP SoX resampler), because the stream plays normally, although does not send metadata.  The stream's "icy-sr" header does show "7350" though that could be bogus.
Anyway, what this has to do with foo_vis_spectrum_analyzer is that no spectrum is shown with this stream, although the Peak Meter component is active.  Why would that be??
This is one of those things that the sending server will probably fix tomorrow, but what would cause the no-spectrum?
Reply #841
I'll see if I can reproduce it in Debug mode.
Reply #842
Don't waste your time on it pqyt, as I predicted today it is back to "normal" with its unmodified 48kHz sample rate and producing the spectrum just fine.  They must have been doing some kind of maintenance that produced the goofy 7350 Hz rate.
Reply #843
I've noticed that the component looks odd when playing .dsf files. The movement is very slow compared with other file types. If it dances for those, then the motion is more like the homecoming queen waving from the parade float. The built-in components don't look nearly so sluggish.
I have foo_input_sacd and foo_dsd_processor installed to play them with.
Reply #844
Is Output Type in foo_input_sacd set to "DSD+PCM"?  If not, try that.  It produces a parallel PCM stream so meters work but the output to the DAC is still DSD.
Reply #845
I don't have any DSF files to try to reproduce it. As long as fb2k produces rendered audio data in 32-bit or 64-bit fp numbers the behavior shouldn't be different.
Reply #846
I also get the slow motion effect when playing DSD files and have DSD+PCM output selected in the SACD plugin (V. 1.5.11), interestingly all FB2K vsualizations run at the correct speed.
BTW, here are some free DSD sample files (>200MB):
https://www.oppodigital.com/hra/dsd-by-davidelias.aspx
Reply #847
Then the .dsf file will not play properly.
For DSD native playback you don't need foo_dsd_processor, you need foo_out_asio+dsd.
ASIO+DSD Output (foo_out_asio+dsd) + Super Audio CD Decoder (foo_input_sacd) are used as a set.
https://sourceforge.net/projects/sacddecoder/files/foo_out_asio%2Bdsd/
Preferrences > Tools > SACD > Output (per device) > Type > DSD
Output: ASIO+DSD: Select DSD-compatible DAC ASIO Driver
I also tried with foo_input_udsd
https://sourceforge.net/projects/sacddecoder/files/macOS%20%2BWindows/foo_input_udsd/
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Reply #848
Foobar's own ASIO works fine.
I'm outputting SACD plugin (from Maxim's Sourforge) -> DSD Transcosder -> ASIO V. 2.2.3 -> DAC's driver (iFi Audio miniDSD) and I'm indeed getting standard DSD from a DSF file as reported both by Foobar and the DAC's driver:
X
Reply #849
I followed @Air KEN's lead (Thx) and installed foo_input_sacd. With the demo files from @Jackal29a I don't see anything wrong on the first play-through.
When the track restarts, however, I get @Sue Dunham's slow-mo behavior.
I have an idea where the problem starts. Stay tuned.
