Topic: convert sacd iso audio file to dsf audio file (Read 6839 times) previous topic - next topic
hi,
is it possible to convert a sacd iso audio file to dsf audio file? ... i can convert to wav audio file but can not find any option in convert to dsf file ... is this possible? ... if yes, can anyone provide me with the details in conversion...
cheers,
Re: convert sacd iso audio file to dsf audio file
Not a foobar component, but you can use sacd_extract. It can't add compression if not used in the ISO.
j7n,
thanks ... will try "sacd_extract" to see how it works...
cheers,
iso2dsd is an excellent freeware tool, easy to use and excellent performance
yes, iso2dsd is a good tool to convert iso audio files to dsf audio files...
sacd_extract seems not working ... it flashed and crashed ... not sure how to make it works...
cheers,
Iso2dsd is a graphical interface for sacd_extract command-line tool, and bundles it in the package. As with all such programs, you can read the usage instructions, by executing sacd_extract --help in Command Prompt (cmd.exe). For example, to extract stereo files from a disc image: sacd_extract -2 -s -i"d:\path\to\iso.iso"
Iso2dsd would produce the same result, and you can use that. I wouldn't suggest it, because it apparently requires Java.
