Topic: Composer Metadata (Read 1151 times) previous topic - next topic
Composer Metadata
Hello, I'm new to using foobar. I have added the composer metadata, how do I get it to show as a column in foobar? I tried adding a new column but composer isn't under the options.
Re: Composer Metadata
Column in the view?
I assume you have tried Right-click -> Columns. Then choose "More" (nearly at the bottom). (Alternatively: Preferences -> Display -> Default User Interface -> Playlist View. Assuming you use the Default UI.
From there, you can customize columns. "Add New". Name: "Composer" or what you prefer. Pattern: %composer%
