I got a message (error) while installing wmp10 (wmp7 needed or sth like that)
but on the terminal it says winetricks installed wmp10 and executed (and installed I assume the wma libraries) WM9Codecs9x.exe
/tmp$ sh winetricks wmp10
vcrun6 already installed, skipping
Executing wget -nd -c --read-timeout=300 --retry-connrefused --header Accept-Encoding: gzip,deflate [url=http://download.microsoft.com/download/2/8/a/28a5a346-1be1-4049-b554-3bc5f3174353/WindowsXP-Windows2000-Script56-KB917344-x86-enu.exe]http://download.microsoft.com/download/2/8...344-x86-enu.exe[/url]
--2009-06-11 14:49:06-- [url=http://download.microsoft.com/download/2/8/a/28a5a346-1be1-4049-b554-3bc5f3174353/WindowsXP-Windows2000-Script56-KB917344-x86-enu.exe]http://download.microsoft.com/download/2/8...344-x86-enu.exe[/url]
Résolution de download.microsoft.com... 213.199.149.11, 213.199.149.9
Connexion vers download.microsoft.com|213.199.149.11|:80... connecté.
requête HTTP transmise, en attente de la réponse... 200 OK
Longueur: 693800 (678K) [application/octet-stream]
Saving to: `WindowsXP-Windows2000-Script56-KB917344-x86-enu.exe'
100%[==========================================================>] 693 800 584K/s in 1,2s
2009-06-11 14:49:07 (584 KB/s) - « WindowsXP-Windows2000-Script56-KB917344-x86-enu.exe » sauvegardé [693800/693800]
Executing wine /home/lan/.winetrickscache/WindowsXP-Windows2000-Script56-KB917344-x86-enu.exe
err:alsa:ALSA_CheckSetVolume Could not find 'PCM Playback Volume' element
fixme:advpack:set_ldids Need to support changing paths - default will be used
Executing wget -nd -c --read-timeout=300 --retry-connrefused --header Accept-Encoding: gzip,deflate [url=http://download.microsoft.com/download/1/2/A/12A31F29-2FA9-4F50-B95D-E45EF7013F87/MP10Setup.exe]http://download.microsoft.com/download/1/2...7/MP10Setup.exe[/url]
--2009-06-11 14:49:18-- [url=http://download.microsoft.com/download/1/2/A/12A31F29-2FA9-4F50-B95D-E45EF7013F87/MP10Setup.exe]http://download.microsoft.com/download/1/2...7/MP10Setup.exe[/url]
Résolution de download.microsoft.com... 213.199.149.182, 213.199.149.180
Connexion vers download.microsoft.com|213.199.149.182|:80... connecté.
Longueur: 12754672 (12M) [application/octet-stream]
Saving to: `MP10Setup.exe'
100%[==========================================================>] 12 754 672 779K/s in 16s
2009-06-11 14:49:35 (776 KB/s) - « MP10Setup.exe » sauvegardé [12754672/12754672]
Executing wine /home/lan/.winetrickscache/MP10Setup.exe
fixme:advapi:DecryptFileA "C:\\windows\\temp\\IXP000.TMP\\" 00000000
fixme:wininet:INET_QueryOptionHelper INTERNET_OPTION_CONNECTED_STATE: semi-stub
fixme:urlmon:ObtainUserAgentString (0, 0x334530, 0x334510): stub
fixme:wininet:InternetGetConnectedStateExW always returning LAN connection.
fixme:wininet:InternetGoOnlineA ("", 0x10020, 0x00000000) stub
Executing wget -nd -c --read-timeout=300 --retry-connrefused --header Accept-Encoding: gzip,deflate [url=http://download.microsoft.com/download/5/c/2/5c29d825-61eb-4b16-8eb8-58367d0464d5/WM9Codecs9x.exe]http://download.microsoft.com/download/5/c...WM9Codecs9x.exe[/url]
--2009-06-11 14:49:49-- [url=http://download.microsoft.com/download/5/c/2/5c29d825-61eb-4b16-8eb8-58367d0464d5/WM9Codecs9x.exe]http://download.microsoft.com/download/5/c...WM9Codecs9x.exe[/url]
Résolution de download.microsoft.com... 87.248.221.200, 87.248.221.196
Connexion vers download.microsoft.com|87.248.221.200|:80... connecté.
Longueur: 1186032 (1,1M) [application/octet-stream]
Saving to: `WM9Codecs9x.exe'
9% [====> ] 106 846 518K/s err:rundll32:main Unable to load L"c:\\windows\\system32\\wpd_ci.dll"
100%[==========================================================>] 1 186 032 700K/s in 1,7s
2009-06-11 14:49:51 (700 KB/s) - « WM9Codecs9x.exe » sauvegardé [1186032/1186032]
Setting Windows version to win2k
Executing wine regedit /home/lan/.wine/drive_c/winetrickstmp/set-winver.reg
Executing wine /home/lan/.winetrickscache/WM9Codecs9x.exe
Executing wine regedit /D HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Cdr4_2K
Executing wine regedit /D HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Cdralw2k
Clearing Windows version back to default
Executing wine regedit /home/lan/.wine/drive_c/winetrickstmp/unset-winver.reg
Install of wmp10 done
winetricks done.
but I relaunched foobar and it still can't play wma
