Topic: foo_discogs (Read 1372255 times) previous topic - next topic
foo_discogs
Reply #1425
I don't think that italic bit (custom format fields) was ever gathered by foo_discogs. It could be added though.
Maybe. That's not crucial, anyway.
Just observed the same issue as previously reported:
For release: http://www.discogs.com/Gibson-Dan-Songbird...release/4490766
Style: "Field recording" becomes "Fielc Recording"
worked fine for me. Try to update the component from this post.
foo_discogs
Reply #1426
[This is my first attempt at using the plug-in. It's installed and Oauth is setup. My example is Muse, The Resistance, 2009]
Configuration>Album/artist art settings: What's recommended here? Can someone recommend some over all settings to help get me started?
For this specific example, there seem to be 3 releases? What's the general guide to deciding between them?
EDIT: I used the plug-in again. There seem to be many more releases than the first time I used it?
foo_discogs
Reply #1427
Thanks so much for the quick updating of this plugin!
I'm trying to authorize OAuth and I just can't get it to connect. Maybe api.discogs.com is down (it's responding to pings but not direct http requests)? Or otherwise, I've done something wrong (but I have renamed the old foo_discogs.dll.cfg)
Cheers.
foo_discogs
Reply #1428
I tried it a little but now does not seem to crash.
Maybe it does not work now support proxy server?
foo_discogs
Reply #1429
Cheers.
According to the discogs forums there has been service connectivity issues in the past hours. It should work now.
foo_discogs
Reply #1430
It did work for me this evening - awesome!
Thanks bubbleguuum for your original dev and thanks to zoomorph for your quick updating! It's awesome to have Discogs tagging working again - an essential part of the foobar2000 experience  (Actually a really indispensable part of my pretty much daily workflow when listening to new music)
foo_discogs
Reply #1431
HUGE thanks to bubbleguuum and zoomorph!!  It's working perfectly with v1.3.3 on Windows 7 Pro x64.  OAuth setup was smooth as butter.  Having used, and continuing to use, foo_discogs to tag many thousands of albums, it is sooo appreciated!
foo_discogs
Reply #1432
Good to hear that lucido!
Here's another build that uses the JSON API exclusively. (According to their website, the rest of the XML API will be shut off on Aug 22.)
https://www.sendspace.com/file/igsvhu
I've not tackled OAuth support as they've bumped the deadline to Oct 14.
Thanks for your work! I've updated the components site with your version (1.33).
It will be picked by the foobar2000 auto-updater.
If you make new updates make sure to bump the version number and I'll upload it to the components site.
That's good news OAuth has been pushed back as it give more time to add support for it.
It works great for me but where is the album cover art ?
Even the last version 1.36 doesn't fetch album cover art. Why?
foo_discogs
Reply #1433
There are two things.
One, I think that there's an issue on the Discogs server side of things right now.  I was having no problem downloading art just a few hours ago.  Now I get this type of error:
  foo_discogs: error: could not save url=http://api.discogs.com/image/R-910147-1249319424.jpeg, skipping...
Two, when I installed the new version all the check boxes under the "Album/artist art" tab in the foo_discogs configuration were unchecked.  I just went back in and checked the ones I wanted and it worked perfectly.
Anyway, as long as the apparent server problem is resolved and you have those boxes checked, you should be in business.
foo_discogs
Reply #1435
http://api.discogs.com/image/R-5953840-1407260370-7839.jpeg
>> You must authenticate to access this resource.
we've hit a limit.
HTTP/1.1 403 Forbidden
Reproxy-Status: yes
Access-Control-Allow-Origin: *
Cache-Control: public, must-revalidate
Content-Type: text/plain
X-RateLimit-Limit: 1000
X-RateLimit-Remaining: 0
X-RateLimit-Reset: 4420
X-RateLimit-Type: image
Server: lighttpd
Content-Length: 21
Date: Sat, 23 Aug 2014 11:52:54 GMT
X-Varnish: 2283323027
Via: 1.1 varnish
Connection: close
Rate limit exceeded.
foo_discogs
Reply #1436
Although I have re-checked the check-boxes about fetching album art images in the configuration and I have authorized OAuth, I still can't get any cover images....
And right now the search stopped working as in the old version of the plugin.
foo_discogs
Reply #1437
working again for me and one other person.
foo_discogs
Reply #1438
Yes, and for me just right now without making any changes.  So, I guess maybe it was a server problem...
foo_discogs
Reply #1439
So is the image downloading problem coming to end? I have no error now but albumart is not fetched.
foo_discogs
Reply #1440
After updating from version 1.32 to 1.36 I've got message:
"Failed to load DLL: foo_discogs.dll
Reason: Unknown error code (3221225501)"
My system: Windows XP SP3, Pentium III
I will appreciate any advices and suggestions.
foo_discogs
Reply #1441
i see a reference to "shared.dll" but i not have it in my system. Do it important? It is working for now.
foo_discogs
Reply #1442
The "shared.dll" is important and you definitely have in your system. If not, you would complain that your foobar2000 ist not working. The dll is part of your foobar2000 installation and you will find it in your foobar2000 program folder.
foo_discogs
Reply #1443
Modern compilers use SSE2 instructions by default. Your CPU doesn't support them.
But it's possible to build foo_discogs that it doesn't require SSE/SSE2.
foo_discogs
Reply #1444
I feel like the plugin needs some more fixing yet. Got hanged at "(fetching additional artist information...)" stage for release 1341431.
Other releases go fine
foo_discogs
Reply #1445
I faced the issue that the tag field "DISCOGS LABEL LINK" doesn't write the actual label but a different number for each label.
foo_discogs
Reply #1446
Discogs now gave all labels unique indexes. This field is used for technical reason to get to label page from Discogs menu in foobar. Label is written into Publisher field by default.
The only problem I have now is timeout errors with downloading artwork, but this is because of slow connection at work. On retry the artwork is downloaded. Maybe you just need to do this mechanism tough. Or add retry button to error dialog.
Listen to WMRI...
foo_discogs
Reply #1447
Thanks zoomorph for making this great plugin work again!
foo_discogs
Reply #1448
Try this one: https://www.sendspace.com/file/s6hwpc
I built it with no enhanced instructions.
foo_discogs
Reply #1449
we've hit a limit.
Reproxy-Status: yes
Server: lighttpd
Content-Length: 21
Via: 1.1 varnish
Connection: close
Unfortunately I don't think there's much that can be done about this other than adding a check and alerting an error.
