Hello everyone.
Two days ago released the latest update of Oggenc2.87 using aoTuVb6.01:
http://www.rarewares.org/ogg-oggenc.php#oggenc-aotuv (http://www.rarewares.org/ogg-oggenc.php#oggenc-aotuv)
But it is only in Windows version! Not available for GNU/Linux in binary format!:
http://wiki.hydrogenaudio.org/index.php?ti...#Linux_binaries (http://wiki.hydrogenaudio.org/index.php?title=Recommended_Ogg_Vorbis#Linux_binaries)
Where could get?
Thank you very much.
Salute.
You first need to download the source code from the AoTuV website and then compile it into an executable-linking format with GCC. I would help you by creating a custom compile, but I am pretty busy as of late. Let me see what I can come up with though in my spare-time! Maybe I will try to compile and upload it to the forums here. If not you will simply have to wait for somebody else to create a compile as I am sure a lot of folks on this forum are more then willing to do so. Take care!
Thank you very much for your reply, friend.
In my opinion, aoTuV is the best current Vorbis encoder.
I'll keep waiting to be compiled.
Salute.
Where could get?
On Ubuntu 10.10 here's what you have to do.
Prepare the system to build aotuv
1) Open a terminal
2) sudo apt-get install build-essential libogg-dev
Download aotuv sources to a folder
3) mkdir aotuv-src
4) cd aotuv-src
5) wget http://www.geocities.jp/aoyoume/aotuv/sour...v_b6.02.tar.bz2 (http://www.geocities.jp/aoyoume/aotuv/source_code/libvorbis-aotuv_b6.02.tar.bz2)
Uncompress them
6) tar xjf libvorbis-aotuv_b6.02.tar.bz2
Change to the sources directory
7) cd aotuv-b6.02_20110227
Build it to some folder in your home (or anywhere)
8) sh ./configure --prefix=/home/myuser/aotuv
9) make
10) make install
11) Then call oggenc like this
LD_PRELOAD=`echo /home/myuser/aotuv/lib/libvorbis*.so` oggenc -q-2 track01.flac
Excelent!
Works fine your solution!
I've also managed to implement in the encoder ABCDE.
Thank you very much, my friend.
Salute.
