Topic: faad2-2.7 fails for some iso conf test stream. (Read 2054 times) previous topic - next topic
Hai all,
while testing ISO conformance streams, fadd2-2.7 fails for three streams out of seven. by seeing the output wave, it was found that some small amplitude section of the PSstream cant ge reproduced by faad.
did anyone find these already and have a solution..?
thanks in advance.
regards,
vasanth.
Prove the worth of being You.
It has been proved by listenig tests that FAAD distortions are rather pleasant
  [a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=73101" target="_blank"]http://www.hydrogenaudio.org/forums/index....showtopic=73101[/a]
so you shouldn't bother about conformance too much.
And why not to use the reference deocder? Does anyone know any FAAD advantage?
