Topic: Possible bug in properties editor - FB 1.6.2 (Read 458 times) previous topic - next topic
Select an album or a few tracks, press alt + enter,
highlight and select track title field, select edit,
then navigate to single value press tab-key and the field will be auto-entered with text, witch can't be edited.
If you try to click on it or press tab, the text disappears, if you press tab multiple times the text in the field appears and disappears.
Also, I can edit individual values with just the keyboard, I must use the mouse to select the track I want to edit, but I can the tab-key after that.
I don't know if this is the intended behavior or not.
I tried on normal foobar2000 and portable, the result are the same. version 1.5.6, 1.6.0, 1.6.1 and 1.6.2 has this behavior.
I'm using Windows 10 version 2004, OS build 19041.572
