Hi. I've recently installed this plugin. Great work. Exactly what I wanted.
Except that today it crashed my foobar a couple of times. Well, I suspect foo_dirwatch is the culprit, since I've not had a crash in ages.
Each time the crash happened after I moved/renamed some files with masstagger.
I'm using the latest version, 0.1.5 (2006-02-26).
Here is the log if it helps.
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0094410Ch
Access violation, operation: read, address: FFFFFFFFh
Call path:
Code bytes (0094410Ch):
009440CCh: E8 40 94 00 11 00 00 00 11 00 00 00 00 00 00 00
009440DCh: 00 00 00 00 04 00 04 00 5A 01 0F 00 00 01 94 00
009440ECh: 78 01 94 00 00 00 00 00 00 00 00 00 00 00 00 00
009440FCh: 00 00 00 00 04 00 04 00 66 01 08 00 00 00 00 00
0094410Ch: 3A 2F 2F 00 B5 00 00 00 B5 00 00 00 00 00 00 00
0094411Ch: A4 00 00 00 0A 00 04 00 62 01 0B 00 40 57 94 00
0094412Ch: 20 47 68 65 74 74 6F 5C 4C 6F 76 65 20 4C 69 66
0094413Ch: 65 5F 5C 30 39 2E 20 48 65 79 20 59 6F 75 6E 67
Stack (01EBFB48h):
01EBFB28h: 00000000 00000000 001520A0 0012FA88
01EBFB38h: 00944288 00940178 00890000 0012FA98
01EBFB48h: 009326B8 00000000 009441F8 00000001
01EBFB58h: 7C917BB0 009350D8 01CD0608 00000085
01EBFB68h: 00000085 00000000 00000074 009350D8
01EBFB78h: 01CCFBD0 00000040 00000040 00000000
01EBFB88h: 0000002F 01CD07F8 01EBFBD8 7C90EE18
01EBFB98h: 7C910570 FFFFFFFF 7C91056D 7C00118F
01EBFBA8h: 00940000 00000000 7C001194 00000000
01EBFBB8h: 01EBFBD8 00932AD3 01EBFC18 00944260
01EBFBC8h: 00000000 009441F8 00000001 00932072
01EBFBD8h: 01EBFC40 0093434C 00000004 01EBFC4C
01EBFBE8h: 00931F4E 00945380 00000B38 01EBFC84
01EBFBF8h: 00936124 009441F8 009350D8 01CCFBD0
01EBFC08h: 0000003B 0000003B 00000000 0000002A
01EBFC18h: 009350D8 01CCFC78 0000007E 0000007E
01EBFC28h: 00000000 0000006D 01CC0048 00000060
01EBFC38h: 01CC0048 00936124 01EBFF98 009342B5
01EBFC48h: 00000000 01EBFC70 00931D13 00000060
01EBFC58h: 009441F8 7C838575 00000000 00000060
Registers:
EAX: 01CCFC18, EBX: 00000000, ECX: 00945380, EDX: 00000003
ESI: 00945380, EDI: FFFFFFFF, EBP: 01EBFBE4, ESP: 01EBFB48
Unable to identify crash location
Loaded modules:
foobar2000 loaded at 00400000h - 00452000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F4000h
USER32 loaded at 77D40000h - 77DD0000h
GDI32 loaded at 77F10000h - 77F57000h
ole32 loaded at 774E0000h - 7761D000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F01000h
msvcrt loaded at 77C10000h - 77C68000h
COMCTL32 loaded at 773D0000h - 774D2000h
SHLWAPI loaded at 77F60000h - 77FD6000h
utf8api loaded at 10000000h - 1000D000h
comdlg32 loaded at 763B0000h - 763F9000h
SHELL32 loaded at 7C9C0000h - 7D1D5000h
foo_ape loaded at 008D0000h - 008EF000h
foo_burninate loaded at 008F0000h - 008FC000h
VERSION loaded at 77C00000h - 77C08000h
foo_cdda loaded at 00900000h - 0090E000h
foo_clienc loaded at 00910000h - 0091B000h
foo_console loaded at 00920000h - 00927000h
foo_dirwatch loaded at 00930000h - 00939000h
MSVCR70 loaded at 7C000000h - 7C054000h
foo_diskwriter loaded at 00950000h - 00962000h
WINMM loaded at 76B40000h - 76B6D000h
foo_dsp_extra loaded at 009F0000h - 00A05000h
foo_faac loaded at 00A10000h - 00A43000h
foo_flac loaded at 00A50000h - 00A6F000h
foo_flaccer loaded at 00A70000h - 00A8A000h
foo_freedb loaded at 00A90000h - 00AAD000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
foo_id3v2 loaded at 00AB0000h - 00AE1000h
MSVCP60 loaded at 76080000h - 760E5000h
foo_infobox loaded at 00AF0000h - 00B03000h
foo_input_std loaded at 00B10000h - 00BCE000h
MSACM32 loaded at 77BE0000h - 77BF5000h
foo_masstag loaded at 00BE0000h - 00BF4000h
foo_matroska loaded at 00C00000h - 00C42000h
foo_monkey loaded at 00C50000h - 00C6C000h
foo_msn loaded at 00C70000h - 00C77000h
MSVCR71 loaded at 7C340000h - 7C396000h
foo_ofr loaded at 00C90000h - 00C96000h
OptimFROG loaded at 00CA0000h - 00CCC000h
foo_output_std loaded at 00CE0000h - 00CE9000h
foo_out_dsound_ex loaded at 00CF0000h - 00CF9000h
DSOUND loaded at 73F10000h - 73F6C000h
foo_read_http loaded at 00D10000h - 00D19000h
foo_rgscan loaded at 00D20000h - 00D2D000h
foo_scheduler loaded at 00D30000h - 00D45000h
foo_uie_albumart loaded at 00D50000h - 00D60000h
gdiplus loaded at 4EC50000h - 4EDF3000h
foo_uie_albumlist loaded at 00D70000h - 00D81000h
foo_ui_columns loaded at 00D90000h - 00DC7000h
foo_unpack loaded at 00DD0000h - 00E01000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_vis_manager loaded at 00E10000h - 00E18000h
foo_vorbisenc loaded at 00E20000h - 00F31000h
foo_wavpack loaded at 00F40000h - 00F54000h
foo_web loaded at 00F60000h - 00F78000h
foo_wma loaded at 01080000h - 01099000h
WMVCore loaded at 086D0000h - 08916000h
WMASF loaded at 070D0000h - 0710A000h
uxtheme loaded at 5AD70000h - 5ADA8000h
MSCTF loaded at 74720000h - 7476B000h
SynTPFcs loaded at 63000000h - 63014000h
dciman32 loaded at 73BC0000h - 73BC6000h
Powrprof loaded at 74AD0000h - 74AD8000h
SSSensor loaded at 061F0000h - 06205000h
WINTRUST loaded at 76C30000h - 76C5E000h
CRYPT32 loaded at 77A80000h - 77B14000h
MSASN1 loaded at 77B20000h - 77B32000h
IMAGEHLP loaded at 76C90000h - 76CB8000h
wdmaud loaded at 72D20000h - 72D29000h
msacm32 loaded at 72D10000h - 72D18000h
midimap loaded at 77BD0000h - 77BD7000h
KsUser loaded at 73EE0000h - 73EE4000h
xpsp2res loaded at 20000000h - 202C5000h
mswsock loaded at 71A50000h - 71A8F000h
hnetcfg loaded at 662B0000h - 66308000h
wshtcpip loaded at 71A90000h - 71A98000h
DNSAPI loaded at 76F20000h - 76F47000h
winrnr loaded at 76FB0000h - 76FB8000h
WLDAP32 loaded at 76F60000h - 76F8C000h
rasadhlp loaded at 76FC0000h - 76FC6000h
DBGHELP loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 009326B8h, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 7C917BB0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlReAllocateHeap" (+000001B3h)
Address: 009350D8h, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 7C00118Fh, location: "MSVCR70", loaded at 7C000000h - 7C054000h
Symbol: "free" (+00000039h)
Address: 7C001194h, location: "MSVCR70", loaded at 7C000000h - 7C054000h
Symbol: "free" (+0000003Eh)
Address: 00932AD3h, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 00932072h, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 0093434Ch, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 00931F4Eh, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 00936124h, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 009342B5h, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 00931D13h, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 7C838575h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ReadFileEx" (+000000B0h)
Address: 7C90EAC7h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserApcDispatcher" (+00000007h)
Address: 00931CFFh, location: "foo_dirwatch", loaded at 00930000h - 00939000h
Address: 7C90EB94h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiFastSystemCallRet" (+00000000h)
Version info:
foobar2000 v0.8.3
UNICODE
