foo_pod - Foobar2000 meets the iPod
Version 0.9.9j is now available. This version should fix the problems people have recently been having with playlists. Unfortunately, it reverts the fix for transcoded songs and playlists added in 0.9.9i, so I'll have to find a better way to fix that. I also added a new feature that I have already found is very useful - Cull 1 Star Songs. This menu item will search your iPod for 1 star songs and delete them. This doesn't touch unrated songs, or songs with 2 - 5 stars, and it will prompt you with the number of songs it is planning to delete before doing anything. The reason I wanted to add this is that after I have listened to a podcast, I typically want to delete it. But if I'm away from a computer, it isn't always easy to remember which files I wanted to delete. So now, I can mark the song with a single star, and use the Cull feature to automatically remove it when I am connected. From the Readme:Version 0.9.9j - May 28, 2005 * Reverted the transcoded songs not appearing in playlists fix from 0.9.9i - this was causing many more serious problems with playlist. I will revisit this bug later... * Added the "Cull 1 Star Songs" feature. This automatically deletes any songs on the iPod that are rated with 1 star. Note that this feature will not erase unrated songs, or rated songs with 2 or more stars. * Removed duplicate warnings about out of disk space when sending files or using OttoFill.
