I have disappointing results with foobar2000 with my 2nd test cd.
First the EAC secure no C2 log. Please note that track 19 had errors.
Exact Audio Copy V0.99 prebeta 4 from 23. January 2008
EAC extraction logfile from 22. April 2009, 21:39
Imago / Probably Not, But Most Definitely
Used drive : TSSTcorpCDDVDW TS-L632H Adapter: 1 ID: 0
Read mode : Secure
Utilize accurate stream : Yes
Defeat audio cache : No
Make use of C2 pointers : No
Read offset correction : 6
Overread into Lead-In and Lead-Out : No
Delete leading and trailing silent blocks : No
Null samples used in CRC calculations : Yes
Used interface : Native Win32 interface for Win NT & 2000
Gap handling : Not detected, thus appended to previous track
Used output format : User Defined Encoder
Selected bitrate : 768 kBit/s
Quality : High
Add ID3 tag : No
Command line compressor : C:\Program Files\encoders\flac-1.2.1b\flac.exe
Additional command line options : -T "artist=%a" -T "title=%t" -T "album=%g" -T "date=%y" -T "tracknumber=%n" -T "genre=%m" -8 %s
TOC of the extracted CD
Track | Start | Length | Start sector | End sector
1 | 0:00.00 | 3:12.06 | 0 | 14405
2 | 3:12.06 | 1:00.69 | 14406 | 18974
3 | 4:13.00 | 4:20.33 | 18975 | 38507
4 | 8:33.33 | 3:15.71 | 38508 | 53203
5 | 11:49.29 | 0:29.29 | 53204 | 55407
6 | 12:18.58 | 3:20.54 | 55408 | 70461
7 | 15:39.37 | 2:39.00 | 70462 | 82386
8 | 18:18.37 | 0:28.42 | 82387 | 84528
9 | 18:47.04 | 3:11.62 | 84529 | 98915
10 | 21:58.66 | 3:49.66 | 98916 | 116156
11 | 25:48.57 | 0:55.00 | 116157 | 120281
12 | 26:43.57 | 3:14.44 | 120282 | 134875
13 | 29:58.26 | 2:50.59 | 134876 | 147684
14 | 32:49.10 | 0:41.60 | 147685 | 150819
15 | 33:30.70 | 3:06.37 | 150820 | 164806
16 | 36:37.32 | 0:19.16 | 164807 | 166247
17 | 36:56.48 | 4:17.63 | 166248 | 185585
18 | 41:14.36 | 0:06.42 | 185586 | 186077
19 | 41:21.03 | 4:38.05 | 186078 | 206932
Track 1
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\01 - Pretty Me.wav
Peak level 100.0 %
Track quality 99.9 %
Copy CRC 764FB328
Track not present in AccurateRip database
Copy OK
Track 2
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\02 - Pauna.wav
Peak level 78.4 %
Track quality 100.0 %
Copy CRC F969AE4F
Copy OK
Track 3
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\03 - Rain Song.wav
Peak level 100.0 %
Copy CRC C1988BC1
Copy OK
Track 4
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\04 - Bathala.wav
Peak level 100.0 %
Copy CRC 0D61EC3D
Copy OK
Track 5
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\05 - The Box.wav
Peak level 57.1 %
Copy CRC BFAE3A5C
Copy OK
Track 6
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\06 - Tugon.wav
Peak level 100.0 %
Copy CRC BBB7E080
Copy OK
Track 7
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\07 - Hiwaga.wav
Peak level 100.0 %
Track quality 99.8 %
Copy CRC AA2329D8
Copy OK
Track 8
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\08 - On Shadows & Tendencies (Saliwan).wav
Peak level 81.7 %
Track quality 99.6 %
Copy CRC 2CFCE0EB
Copy OK
Track 9
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\09 - Do.wav
Peak level 100.0 %
Copy CRC 5F97A9C9
Copy OK
Track 10
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\10 - Alay.wav
Peak level 100.0 %
Copy CRC 08172FD3
Copy OK
Track 11
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\11 - Salitoo.wav
Peak level 80.5 %
Track quality 99.5 %
Copy CRC CA49E909
Copy OK
Track 12
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\12 - Otherwise.wav
Peak level 100.0 %
Copy CRC A3BCAF83
Copy OK
Track 13
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\13 - Idlip.wav
Peak level 100.0 %
Copy CRC 2592E0FC
Copy OK
Track 14
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\14 - Salitree.wav
Peak level 81.5 %
Copy CRC 9D9F6087
Copy OK
Track 15
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\15 - Unwed.wav
Peak level 100.0 %
Copy CRC EA19EE4A
Copy OK
Track 16
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\16 - Wishlist.wav
Peak level 34.7 %
Copy CRC 286F8809
Copy OK
Track 17
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\17 - Laya.wav
Peak level 100.0 %
Copy CRC DD5A88DD
Copy OK
Track 18
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\18 - Box Storage Directions.wav
Peak level 13.0 %
Copy CRC 8E1FECEF
Copy OK
Track 19
Filename C:\Users\ac25\Desktop\testing\probably not\eac no c2\19 - Rain Song (remix).wav
Suspicious position 0:00:07
Peak level 67.3 %
Copy CRC C6CC86A7
Copy finished
None of the tracks are present in the AccurateRip database
There were errors
End of status report
Next the Dbpoweramp log.
dBpoweramp Release 13.2 Digital Audio Extraction Log from Thursday, April 16, 2009 2:49 PM
Drive & Settings
Ripping with drive 'D: [TSSTcorp - CDDVDW TS-L632H ]', Drive offset: 6, Overread Lead-in/out: No
AccurateRip: Active, Using C2: Yes, Cache: None, FUA Cache Invalidate: No
Pass 1 Drive Speed: Max, Pass 2 Drive Speed: Max
Ultra:: Vary Drive Speed: No, Min Passes: 1, Max Passes: 2, Finish After Clean Passes: 1
Bad Sector Re-rip:: Drive Speed: Max, Maximum Re-reads: 34
Encoder: FLAC -compression-level-8
Extraction Log
Track 1: Ripped LBA 0 to 14406 (3:12) in 0:42. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 01 - Pretty Me.flac
Secure [Pass 1, Ultra 1 to 1]
CRC32: 764FB328 AccurateRip CRC: B30E17ED [DiscID: 019-001ffc8b-01bad9e8-db0ac713-1]
Track 2: Ripped LBA 14406 to 18975 (1:00) in 0:10. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 02 - Pauna.flac
CRC32: F969AE4F AccurateRip CRC: D42B89B1 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-2]
Track 3: Ripped LBA 18975 to 38508 (4:20) in 0:44. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 03 - Rainsong.flac
CRC32: C1988BC1 AccurateRip CRC: 49E8E8E3 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-3]
Track 4: Ripped LBA 38508 to 53204 (3:15) in 0:30. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 04 - Bathala.flac
CRC32: 0D61EC3D AccurateRip CRC: 4925C977 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-4]
Track 5: Ripped LBA 53204 to 55408 (0:29) in 0:04. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 05 - The Box.flac
CRC32: BFAE3A5C AccurateRip CRC: CC3A1F3C [DiscID: 019-001ffc8b-01bad9e8-db0ac713-5]
Track 6: Ripped LBA 55408 to 70462 (3:20) in 0:29. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 06 - Tugon.flac
CRC32: BBB7E080 AccurateRip CRC: A90FC20A [DiscID: 019-001ffc8b-01bad9e8-db0ac713-6]
Track 7: Ripped LBA 70462 to 82387 (2:39) in 0:22. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 07 - Hiwaga.flac
CRC32: AA2329D8 AccurateRip CRC: 930575D5 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-7]
Track 8: Ripped LBA 82387 to 84529 (0:28) in 0:03. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 08 - On Shadows & Tendecies (Saliwan).flac
CRC32: 2CFCE0EB AccurateRip CRC: 3841BC56 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-8]
Track 9: Ripped LBA 84529 to 98916 (3:11) in 0:25. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 09 - Do.flac
CRC32: 5F97A9C9 AccurateRip CRC: 422DE6D6 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-9]
Track 10: Ripped LBA 98916 to 116157 (3:49) in 0:29. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 10 - Alay.flac
CRC32: 08172FD3 AccurateRip CRC: 1A5F41CC [DiscID: 019-001ffc8b-01bad9e8-db0ac713-10]
Track 11: Ripped LBA 116157 to 120282 (0:55) in 0:06. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 11 - Salitoo.flac
CRC32: CA49E909 AccurateRip CRC: FDBEB4FA [DiscID: 019-001ffc8b-01bad9e8-db0ac713-11]
Track 12: Ripped LBA 120282 to 134876 (3:14) in 0:23. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 12 - Otherwise.flac
CRC32: A3BCAF83 AccurateRip CRC: 24BC54DA [DiscID: 019-001ffc8b-01bad9e8-db0ac713-12]
Track 13: Ripped LBA 134876 to 147685 (2:50) in 0:20. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 13 - Idlip.flac
CRC32: 2592E0FC AccurateRip CRC: 5650D8A6 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-13]
Track 14: Ripped LBA 147685 to 150820 (0:41) in 0:04. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 14 - Salitree.flac
CRC32: 9D9F6087 AccurateRip CRC: C3F734A8 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-14]
Track 15: Ripped LBA 150820 to 164807 (3:06) in 0:21. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 15 - Unwed.flac
CRC32: EA19EE4A AccurateRip CRC: D46EEC7C [DiscID: 019-001ffc8b-01bad9e8-db0ac713-15]
Track 16: Ripped LBA 164807 to 166248 (0:19) in 0:02. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 16 - Wishlist.flac
CRC32: 286F8809 AccurateRip CRC: 1CF80A31 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-16]
Track 17: Ripped LBA 166248 to 185586 (4:17) in 0:28. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 17 - Laya.flac
CRC32: DD5A88DD AccurateRip CRC: ACCD5EAB [DiscID: 019-001ffc8b-01bad9e8-db0ac713-17]
Track 18: Ripped LBA 185586 to 186078 (0:06) in 0:00. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 18 - [Untitled].flac
CRC32: 8E1FECEF AccurateRip CRC: A854E63B [DiscID: 019-001ffc8b-01bad9e8-db0ac713-18]
Track 19: Ripped LBA 186078 to 206933 (4:38) in 0:29. Filename: C:\Users\ac25\Music\Imago\Probably Not, But Most Definitely\Imago - 19 - [Untitled].flac
CRC32: 1E89CCA8 AccurateRip CRC: 19AAD421 [DiscID: 019-001ffc8b-01bad9e8-db0ac713-19]
19 Tracks Ripped Securely
Finally the foobar2000 log. Take note that foobar2000 had minor problems with tracks 7, 9, 11, 12, 17 and 19.
6 out of 19 tracks converted with minor problems.
Source: "cdda://019D3361,01"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 1, sample offset: 6, security: standard
Track converted successfully.
Source: "cdda://019D3361,02"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 2, sample offset: 6, security: standard
Source: "cdda://019D3361,03"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 3, sample offset: 6, security: standard
Source: "cdda://019D3361,04"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 4, sample offset: 6, security: standard
Source: "cdda://019D3361,05"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 5, sample offset: 6, security: standard
Source: "cdda://019D3361,06"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 6, sample offset: 6, security: standard
Source: "cdda://019D3361,07"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 7, sample offset: 6, security: standard
Secure mode: CRC mismatch, retrying.
Secure mode: match found after 1 attempts.
Track converted with minor problems.
Source: "cdda://019D3361,08"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 8, sample offset: 6, security: standard
Source: "cdda://019D3361,09"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 9, sample offset: 6, security: standard
Source: "cdda://019D3361,10"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 10, sample offset: 6, security: standard
Source: "cdda://019D3361,11"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 11, sample offset: 6, security: standard
Source: "cdda://019D3361,12"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 12, sample offset: 6, security: standard
Source: "cdda://019D3361,13"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 13, sample offset: 6, security: standard
Source: "cdda://019D3361,14"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 14, sample offset: 6, security: standard
Source: "cdda://019D3361,15"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 15, sample offset: 6, security: standard
Source: "cdda://019D3361,16"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 16, sample offset: 6, security: standard
Source: "cdda://019D3361,17"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 17, sample offset: 6, security: standard
Source: "cdda://019D3361,18"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 18, sample offset: 6, security: standard
Source: "cdda://019D3361,19"
Audio CD extraction setup: drive: "CDDVDW TS-L632H ", track: 19, sample offset: 6, security: standard
Secure mode: match found after 2 attempts.
Here are the MD5 checksums:
[!--sizeo:1--][span style=\"font-size:8pt;line-height:100%\"][!--/sizeo--]7F26BA9DD5F575DB5C4CBA0DF91C1A22 7 eac no c2
7F26BA9DD5F575DB5C4CBA0DF91C1A22 7 foo standard
7F26BA9DD5F575DB5C4CBA0DF91C1A22 7 dbpoweramp
2AC41AC52C1220F8633174D07D29B910 9 eac no c2
0C27B4FA5F5868B2A17D8E57F3E98068 9 foo standard
2AC41AC52C1220F8633174D07D29B910 9 dbpoweramp
CC10DD5BF3A71D32D2E34553BD7153F2 11 eac no c2
9869C6AEE20F0D8E019D6875D102E90D 11 foo standard
CC10DD5BF3A71D32D2E34553BD7153F2 11 dbpoweramp
555EA678D2C8A2127653CAA1EB5F1252 12 eac no c2
555EA678D2C8A2127653CAA1EB5F1252 12 foo standard
555EA678D2C8A2127653CAA1EB5F1252 12 dbpoweramp
550CA64FD6F453B0B0013FB600F5AC87 17 eac no c2
8EA42B577B0FCDC9233D2135E369A270 17 foo standard
550CA64FD6F453B0B0013FB600F5AC87 17 dbpoweramp
281E3A16DDAD93CCB0D1014A15241DA4 19 eac no c2
E9473EDD7C946B34F6BEC71EAC12F4CE 19 foo standard
BCFCDEF1C6D16764D3828A11B7561486 19 dbpoweramp[/size]
The EAC rip matched the Dbpoweramp rip for all the tracks where it did not report any errors. Foobar2000 only matched 2 out of 6 tracks.
Previously with another cd, foobar2000 paranoid also failed to match both EAC and Dbpoweramp's rips.
Hopefully more people will submit their own tests. As for me, I'll be sticking with good old EAC.
