Topic: EAC—almost any UI function= freeze+error “EAC.exe has stopped working” (Read 3377 times) previous topic - next topic
Hi I have downloaded the latest version of EAC
However each time i need to browse  for something (in the program interface) or use a function  slightly out of the norm it freezes and says EAC.exe has stopped working and has an error message
Im running windows 7 64 bit
is this a known problem? is there a patch or something?
it does it when i tried to browse to find an external encoder
it does it when i choose copy image > compressed
and i am sure it will do it for many more things if i used more functions...
I believe EAC is only available as a 32-bit application, so make sure you are not trying to use 64-bit encoders.
64 bit Win7 here, using EAC + 64 bit lame.exe -> no problem.
...or use a function  slightly out of the norm...
Means what?
Hey
Just to let you know i found the issue
EAC has an issue with Adobe Drive CS4 - u need to un-install it to get full functionality of the EAC
