Topic: Are there any ABX or ABC/HR testing tools for ARM Linux? (Read 2773 times) previous topic - next topic
  • quadH
ABC/HR for Java doesn't work, it gives me an error when I try to play anything.
  • quadH
Re: Are there any ABX or ABC/HR testing tools for ARM Linux?
And "abx" gives me this error on the command line:
ALSA lib pcm_dmix.c:990:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
  • 2tec
  • eric.w
Is this the latest ABC/HR for Java? rpp3po's Version 0.53a:
https://hydrogenaud.io/index.php/topic,77573.msg683924.html#msg683924
  • quadH
I solved my problem. The native "abx" program and the Java ABX tools work, but your PC has to support multiple audio streams at the same time. If it doesn't support multiple audio streams on hardware, you have to use a software mixer (dmix). ABC/HR for Java doesn't work.
I changed my /etc/asound.conf file from this:
Spoiler (click to show/hide)
to this:
The newest version is 0.53b, I got it from the 2014 listening test: http://listening-test.coresv.net/
  • Last Edit: 17 July, 2017, 08:16:34 PM by quadH
