Topic: Columns UI appearance (Read 3301959 times) previous topic - next topic
Reply #1426
wupi - where did u find some of the components for ur config?i loaded ur fcl file but im still missing one or two components which is not listed in the official components page
Reply #1427
Wich components do you mean ?
Reply #1429
wupi -
I cant find the following components in foobar components page
Lyric Show 2
Channel Spectrum Panel
Reply #1430
wupi -
Lyric Show 2
You can download lyric show 2 here -> http://code.google.com/p/foo-display-lyrics/downloads/list -> forum http://www.hydrogenaudio.org/forums/index....showtopic=76968
Jeremija posted already the link for Channel spectrum panel -> http://foo2k.chottu.net
Reply #1431
i got all the components except for the quick search toolbar..i got the component from foobar page but Columns UI still prompts for it.have i dled the right one?
Reply #1433
dude...it seems that component that u used is heavily outdated
Reply #1438
i think thats the point...foo_uie_quicksearch is already obsolete and the author has already indicated to use foo_quicksearch
Reply #1439
Can we move on now? wupi was kind enough to share his layout. You can either use the obsolete but working component, reconfigure the layout to use the newer component or move on.
Reply #1440
foo_uie_quicksearch !
I uploaded all my components, please check wich you need.
Please do not distribute obsolete components. Thanks
Im sorry, im testing the newone.
EDIT
Now with foo_quicksearch instead of foo_uie_quicksearch.
http://files.myopera.com/wunage/files/wunage_2.1.fcl
Reply #1442
[a href="http://img64.imageshack.us/i/68818908.png/" target="_blank"]
Reply #1443
Clean and simple works for me. Only fancy thing is WSH Panel-made statusbar, because I really wanted to see how long ago I listened to songs last time...
Reply #1444
This looks simply amazing. Care to share?
Reply #1445
Well, it's pretty much optimized for my preferences so it might need a little tweaking to be of any use.. Nevertheless, here are the .fcl and necessary images (unzip images to your "..\foobar2000\images\" (make directory if necessary): http://www.multiupload.com/176EJW17WZ
Few words: I use only %album rating% and with values from 10 to 50, so if you have some different rating system I guess it won't quite work as expected. Also many of WSH Panels are actually made by marc2003 (with perhaps few modifications), mainly those concerning last.fm integration.
As for the components, I guess WSH Panel, Panel Stack Splitter, Waveform seekbar, EsPlaylist, Lyric Show Panel, Playlists Dropdown and Quick Search Toolbar should be enough. Oh, and foo_run, if you wish to use mp3tagger-shortcut in the toolbar (expects mp3tagger to be installed to "c:\program files\mp3tag")
Reply #1446
Thanks! I actually usually don't ues a rating system at all - I find it too hard to properly rate stuff, so I might just delete those lines. I?ll have a look around. It's been a while though, I've stopped looking at foobar stuff like 3 years ago.
Reply #1447
Cannonball, some link to the Pannel stack tabs mod and Lyric Show you have used for this?
Ys
Rozzo
Reply #1448
Hi Guys,
I'm new here because I had a question about the waveform seekbar. But now that I'm already registered I thought I'd drop by and show you my config.
It's simple and handy, I love it! No buttons because I use the notebooks media keys.
