Topic: foo_dsp_xgeq (Read 46295 times) previous topic - next topic
foo_dsp_xgeq
For discussion please use this thread.
Download:
Current version:
0.3.7
[attachment=6895:foo_dsp_xgeq.zip]
Previous versions:
0.3.6
[attachment=6894:foo_dsp_xgeq.zip]
0.3.5
[attachment=6888:foo_dsp_xgeq.zip]
0.2.2
[attachment=6839:foo_dsp_xgeq.zip]
0.2.1
[attachment=6713:foo_dsp_xgeq.zip]
Changelog:
0.3.7
  • switching through the sliders with tab now also changes the current band in the combo box
  • fixed menu conflict
0.3.6
  • added entry to View menu (can also be used to open the EQ with a keyboard shortcut)
  • small interface tweaks (tab order, spelling)
  • print supported/chosen SSE version in console on startup
0.3.5
  • fixed seldom stereo mode volume control crash
0.3.4
  • fixed bug with higher sample rates
0.3.3
  • fixed stereo mode volume control crash
0.3.2
  • fixed import/export file dialog default directory
0.3.1
  • fixed gain-only (flat sliders) CPU load in stereo mode
0.3.0
  • experimental stereo mode (independent equalization for left/right channel)
    this mode only works if the audio data has exactly two channels (fallback mode: mono)
    note that this new mode causes changes in the preset format so please backup (export) your presets before updating if you want to be able to go back to v0.2.x
  • gain-only adjustments in stereo mode cause some (unnecessary) CPU load, will be fixed in the next version
  • new band combobox replaces the stupid [<] and [>] buttons
  • fixed rounding bug when entering gain values
0.2.2
  • reduced number of allocations
  • reduced copying of audio samples
  • experimental SSE, SSE2 and SSE3 optimizations (chosen automatically depending on your CPU)
0.2.1
  • master gain edit control is now editable, allows users to enter master gain directly
  • change band and update band gain automatically when user adjusts sliders
  • update displayed master gain correctly after importing a preset
  • code cleanup
0.2.0
  • import/export from/to .xgeq files added
  • band gain edit control added, allows users to enter gain directly
  • fixed tab-order
  • changed gain range to +-12 dB
  • changed gain resolution to .1 dB
  • fixed sliders being off one tick due to rounding errors
  • some internal tweaks here and there
0.1.2
  • improved CPU load scaling with simple configurations
  • fixed noise bug with extremely short input files
  • fixed high CPU load despite flat sliders
  • configuration changes get applied periodically during user interaction
  • resizable configuration window
  • left-click: slider thumb jumps directly to mouse position
  • right-click: slider thumb is reset
  • sliders don't capture the mouse anymore
0.1.1
  • fixed interaction between adjacent band filters
  • fixed a bug that resulted in a chopped off impulse response for certain configurations
  • improved slider "scrolling" behaviour, each mouse click or page up/down now causes a +- 1 dB change
0.1.0
  • Initial release
"I hear it when I see it."
