Topic: foo_input_std with LAME VBR profile recognition (Read 66704 times) previous topic - next topic
updated 16th jan 2005
about
this is a modification of foo_input_std to read the lame profile used
to encode mp3s.
it exports the following info items:
%__lame_profile%     - for example "aps", "ape" or "apfs"
%__lame_version%     - for example "LAME3.90a"
%__lame_profile_idx% - for example 0 or 2, which corresponds to the
                       following list:
 NONE   0
 R3MIX  1
 APE    2
 APS    3
 APFS   4
 APFE   5
 API    6
source
a diff against the distributed version of mp3.cpp is included in the
src directory.
changelog
16th jan 2005 - fixed a few minor bugs, added lame 3.96 --preset extreme support
14th dec 2004 - initial public release
author
 ctz <ctz@ifihada.com>
download
note: you will likely need to "reload info from file" to see the updated tags
great plugin i love it
Thank you, Great Plugin.
is this meant to work on CBR mp3 aswell ?
bitrate = 320
channels = 2
codec = MP3
enc_delay = 0
enc_padding = 0
lame_profile =
lame_profile_index = 0
lame_version =
mp3_accurate_length = yes
mp3_stereo_mode = joint stereo
replaygain_track_gain = -8.16 Db
replaygain_track_peak = 1.040457
samplerate = 44100
13223279 samples @ 44100Hz
(rounded samples : 13222944)
this files was encoded lame, you can see it doesn't show the lame version number.
any ideas ?
Nice ... is it possible to have the third level of the Lame version (like 3.90.2)?
Posting in support of ctz's awesome work.
[a href="index.php?act=findpost&pid=259772"][{POST_SNAPBACK}][/a]
no unfortunately not. the lame version is stored as part of the vbr header. cbr file = no vbr header.
there may be an alternative way to read the encoder version, but i haven't investigated this yet.
Excellent! Thanks.
Maybe further improvements could be made to this by using parts of the Mr Questionman source code?
Excellent! Thanks.
[a href="index.php?act=findpost&pid=259962"][{POST_SNAPBACK}][/a]
Possibly too slow for general playlist use, but it would be great as a component/panel.
This could be a great plugin and this is what foobar needs
Thank you...great plugin
I've been waiting for such a plugin for a long time !!!
thanks
WavPack 4.31 -hm
Wonderfull plug thanks CTZ!!!!
Argh it doesn't work for me... is tehre something to do after installing the DLL in the components directory???
Thanks...
Thanks...
you need to "reload info from file" to see the new fields
Thanks ctz.
The Lame version is stored into the INFO header. By default it is also written in CBR, but some encoding apps could decide to disable it.
bitrate = 192
channels = 2
codec = MP3
enc_delay = 576
enc_padding = 1716
lame_profile =
lame_version = LAME3.96
replaygain_track_gain = -9.08 dB
replaygain_track_peak = 1.026334
samplerate = 44100
4939788 samples @ 44100Hz
(mod 588 = 0)
This is taken from a CBR mp3.
Some show the lame version, and some don't (even if they were encoded by lame)
Would it be possible to also support preset medium? Or isn't it stored in the header?
Besides of that, VERY cool modification - thank you.
- Lyx
This foo_input_std mod doesn't recognize enc_delay and enc_padding of the mp3 file created by acmenc.
Therefore I can't get gapless playback.
Thanks, good plugin, but needs VS7 (.net) stuff on the computer in order to work.
[a href="index.php?act=findpost&pid=261541"][{POST_SNAPBACK}][/a]
Is this bug valid? And if yes, has it been fixed or do you intend to fix it?
- Lyx
For some files I have, both tags exist but are empty, eg:
lame_version =
lame_profile =
bitrate = 154
codec = MP3
channels = 2
samplerate = 44100
extrainfo = VBR
mp3_stereo_mode = stereo
It seems they were encoded with Xing (new) VBR.
normal foo_input_std :
enc_delay = 672
enc_padding = 1127
bitrate = 128
codec = MP3
channels = 2
samplerate = 44100
1323001 samples @ 44100Hz
File size: 479 967 bytes
modified foo_input_std :
lame_version =
lame_profile =
bitrate = 128
codec = MP3
channels = 2
samplerate = 44100
1324271 samples @ 44100Hz
Sample file here.
I wish someone to fix this bug.
- Lyx
[a href="index.php?act=findpost&pid=265646"][{POST_SNAPBACK}][/a]
does the standard foo_input_std library read these correctly?  if so, could you give me a sample mp3 with the problem so i can debug?
