Topic: Convolver CD de-emphasis impulsefile (Read 13580 times) previous topic - next topic
an impulse file to use with foobar convolver for example to do de-emphasis on CDs that were recorded with pre-emphasis, should be highly accurate
It is old and not based on the Waves impulsefile that was floating around.
A simpler solution: foobar EQ de-emphasis preset
Ceterum censeo, there should be an "%is_stop_after_current%".
Deemphasis impulse file generated by SoX: [attachment=7353:deemph_SoX.wav]
Simpler, but also less accurate (green line  - SoX, red - impulse from Wombat, yellow - fb2k eq.):
Deemphasis impulse file generated by SoX: [attachment=5542:deemph44.wav]
Wow. You're right. I thought that foobar eq worked differently using smooth interpolation between center frequencies of bands. I should have checked it
Now, there is no quick way to enable/disable the convolver from the UI, like I can do with the eq. One has to go through preferences, DSP, etc. So I converted my pre-emphasized ogg to FLAC while convolving it with your impulse file, and I got rid of all the hassle at the expense of losing 200 MB of disk space :-).
Thanks again for showing me the frequency response of the eq, and for providing impulse files.
Save it as DSP preset and pin it to button or shortcut (in latest betas)
As I said, I already chose another solution. But out of curiosity - will this give me feedback so I can easily tell if the DSP is on or off?
If you shift-click playback menu, active DSP is ticked in DSP settings submenu
I uploaded the sample for Aquares mostly. If he could find some time he may compare it like the other ones here: http://www.hydrogenaudio.org/forums/index....=65067&st=0
Of cause we still don´t know how exact this Denon sourced reference file is but it may be fun.
