Topic: Using system() to call application with parameters (Read 10023 times) previous topic - next topic
I am trying to mute foobar2000 from the command line using system(). I have tried using
system("\"C:\\Program Files\\Foobar2000\\foobar2000.exe\" \"/command:volume mute\"");
but that does not seem to be working correctly as the command line says
'C:\Program' is not recognized as an internal or external command,
operable program or batch file.
when my program is run. I have a feeling it's just a syntax error, but because I'm a noob to C++ I can't see it...
you probably need to escape the spaces
well first your backslashes looks very messy.
that error only occures when you use quatation marks incorectly.
you should pass something like:
"c:\program files\foobar2000\foobar2000.exe" /command:volume mute
Do you mean something like?
system("\"C:\\Program Files\\Foobar2000\\foobar2000.exe\" /command:volume mute");
I tried that and it doesn't work, foobar says:
Unable to open item for playback (Unsupported file format):
"C:\Documents and Settings\Neural_Overload\My Documents\Visual Studio 2008\Projects\FooControl\FooControl\mute"
sorry, man i don't know the C syntax, but the problem is obviously in the quatation marks.
i was trying to show, only how the parse should look like:
"c:\program files\foobar2000\foobar2000.exe" "/command:volume mute"
and not
my mistake
i was trayng to show, only how the parse should look like:
and not
my mistake
system("c:\program files\foobar2000\foobar2000.exe" "/command:volume mute");
is this working?
You see, I'm pretty sure you have to escape the double quotes and the backslashes in the path. Kinda like this:
system("\"c:\\program files\\foobar2000\foobar2000.exe\" \"/command:volume mute\"");
Which as I said before, does not work.
you are right, the parse should be fine that way, but...
maybe with 8.3 style:
system("c:\\progra~1\\foobar~1\\foobar~1.exe \"/command:volume mute\"");
It works if I do that, but now I have to figure out how to convert from normal to 8.3
i'm glad that finally something worked.
i don't understand what you have to figure out!?
why do you need that?
what are you trying to do?
I'm trying to make a program similar to this program HERE however I want to expand upon the idea and so I don't want to use hard coded paths for the reason that people might have foobar in directories other than C:\Program Files\Foobar2000
Using the CreateProcess API directly won't suffer from this kind of problems.
The problem with exec(2) is that it does never return.
Each of the  functions  in  the  exec  family  replaces  the
current  process  image  with  a  new process image. The new
image is constructed from a regular, executable file  called
the  new  process image file. This file is either an execut-
able object file or a file of data for an interpreter. There
is  no  return  from a successful call to one of these func-
tions because the calling process image is overlaid  by  the
new process image.
I think you meant _spawn.
(Yes, ShellExecute would work too, I'm just used to use it only for URLs, documents, etc.)
Neither would ShellExecute or _exec, and the number of their parameters is less intimidating. Decisions, decisions...
Well, that was odd. I tried using shellapi.h and it gave me a ton of compile errors. So I googled and came across someone with similar errors. I used windows.h instead of shellapi.h and my program works, but only if I compile it in DEV-C++. Visual Studio gives me the error
1>.\foobar.cpp(25) : error C2664: 'ShellExecuteW' : cannot convert parameter 2 from 'const char [5]' to 'LPCWSTR'
1>        Types pointed to are unrelated; conversion requires reinterpret_cast, C-style cast or function-style cast
Edit: Problem solved, had to switch to a Multi-byte Character Set instead of Unicode
PS. Thanks for all the help guys! I really appreciate it
Actually, you should use the _T macro to convert the string constants to TCHAR. May as well use Unicode.
