Topic: Crossmix DSP (Read 576 times) previous topic - next topic
Crossmix DSP
I have installed this plugin.
https://foobar.hyv.fi/?view=foo_dsp_crossmix
I have noticed that at the end of the last sequential track of a playlist, there are a number of anomalous noises at the end.
Re: Crossmix DSP
I don't see anything wrong in the sources, At the end of playback all buffered samples should just be played out.
I tried creating a few playlists from different albums and played the last two or three tracks of these with the Default playback mode. I failed to replicate the noise bug, playback just ended smoothly.
Would you kindly confirm if the bug requires some special settings to replicate? Or special input.
Re: Crossmix DSP
I did some tests.
The problem seems to be related to the [exclusive] mode, both with the default sound card and with the dac.
By removing the [exclusive] mode, the problem does not arise.
Re: Crossmix DSP
Thank you. This turned out to be a problem in foobar's output code and should be fixed for the next build.
For now you can circumvent it by enabling the smooth fader in the output config.
Re: Crossmix DSP
Fixed in the freshly released v2.1 preview.
Re: Crossmix DSP
THX  :D
