Topic: Export parameters (Read 444 times) previous topic - next topic
Export parameters
Hello.
Il would like to install foobar on a new PC. Is it possible to export the parameters and the skin on the new computer ?
Thank you for your help.
Phil.
Re: Export parameters
To save just the theme, use the Export / Import buttons in File > Preferences > Display > Default UI / Columns UI  (whichever UI you are using)
Alternatively you can copy the entire setup, including components, your settings and playlists, etc. In source foobar, [hold shift key] > File > Browse Configuration Folder. Backup contents of this entire folder. Use same menu on the new install, close foobar, and restore / copy from the backup.
