Topic: Google Custom Search (Read 8940 times) previous topic - next topic
It seems that Google Custom Search (at the top right corner) now works very poorly, I often get no results at all (or only 1 result). What happened?
It is still searching hydrogenaudio.org, hasn't been updated for the new domain.
In the meantime try adding:
"site:hydrogenaud.io" into a google query to only search this site.
Example
On a side note, am I the only one who cannot search a user's posts?  If I click on the left side of a post on a user name, select "Find Members Posts", I get:
Sorry, the board administrator has enabled search flood control. Please wait at least 4 seconds before trying again.
It's working for me saratoga
Not working here either, it keeps giving me "No Results".
Same here. What's the point of this search box?
1/ You are really using the wrong search function. If you look below the google box there is another search option. It is on the line between FAQ and Members. This will work without any problems.
2/ If you have a browser app that blocks trackers, it will block the Google search API brcause it tracks your movements. I use Ghostery which does this. It can be disabled.
Glass half full!
Still, someone must have the ability to update the site. Whoever that is, they should reconfigure the Google search box so it works on the new domain.
Yes, I block shit and it doesn't block non shit.
Using Search (not input box in up right corner although why not?) but Search from the menu I get still nothing, compared to searching google with site:hydrogenaud.io
It shouldn't be like this, but I guess someone can make it that this behavior is as supposed to be.
Yeah, cheers
Fixed and verified working once again. Thanks, Garf.
I forgot to post about this a few days ago, when the correct search was configured and the template was edited to reflect the change, as the search was completely broken at the time, returning 50x errors from Google. I guess new searches take a while to propagate throughout their network.
