Topic: The track mark that has already been played. (Read 2227 times) previous topic - next topic
I'm new here, so I wanted to greet everyone first.
And now the question. Can foobar2000 set this function to mark the played songs for eg a different color? Maybe there is such a plug? Thank you.
Re: The track mark that has already been played.
Yes it can. As far as I know at least NG playlist can do that and also ELplaylist. Although this isn't just done with a simple plugin but rather requires some simple scripting usually a bit like this:
$ifgreater(%play_counter%,0,$rgb(100,100,100),$rgb(200,200,200))
Using playcounter statistics custom, which will update playcount value, foobar will display different color for whatever text you want to have displayed in a different color.
I use this too but I have it to change text color with a progressive gradient of colors the more something gets played. This is within NGplaylist:
In NGplaylist Style script
$set_style(text,
$ifgreater(%play_counter%,9,5e5ac2,
$ifgreater(%play_counter%,5,85729d,
$ifgreater(%play_counter%,3,9482d8,
$ifgreater(%play_counter%,1,c5a0c5,
ffffff))))
,0)
or a numerical playcount, e.g. superscript that could be added after the song title:
[$replace(%play_count%,1,$char(185),2,$char(178),3,$char(179),4,$char(8308),5,$char(8309),6,$char(8310),7,$char(8311),8,$char(8312),9,$char(8313),0,$char(8304))]
Neat, but what about any play counts that go beyond 9? Also for playcounter statistics custom, %play_count% should be %play_counter%.
above 9, keep going?... 10,$char(185)$char(8304),11,$char(185)$char(185)...
%play_count% is used with foo_playcount (playback statistics) component
That seems to be completely unnecessary since as it seems foobar already uses the predefined chars for numbers beyond 9. This is nice, gonna use that script myself.
