Topic: foobar2000 v0.9.3 beta (Read 67690 times) previous topic - next topic
Reply #153
anyone got a change log for 0.9.3.4 ? i love seeing the new versions but I really have no idea of what has been changed or fixed so its very hard to judge or test the features...
any ideas appreciated..
+1
foobar2000 + EAC + Burrrn = Happiness
Reply #154
What you want is not a cuesheet, but instead APL. Cuesheets dont support what you want to do. Use APL instead.
Hrm... maybe a cuesheet isn't the absolute best solution, but I've already got hundreds of albums with cuesheets that have metadata for each track embedded into it.  Foobar 0.9 can read such data okay, but only the common fields, and it mangles the cuesheets (i.e. deletes all my metadata) if I try to change some info.  I'd like to see this functionality extended so that it will work the way that trusty 0.8.3 did (with cue_ex).
Reply #155
Also, using .apl has the advantage of being able to reference a single track in a playlist (*m3u8/fpl). The greatest drawback being its closed format, system encoding dependancy and having many files instead of one (which is also an advantage). This said, embedded (or not) cuesheets are still useful so long as it doesn't go overboard. I don't like the idea of an escape mess in cuesheet extended tags, but I support your suggestion.
Apparently components that have been modified in beta 4 are
shared.dll
foo_unpack.dll
foo_rgscan.dll
foo_masstag.dll
foo_converter.dll
foo_cdda.dll
foo_input_std.dll
foo_albumlist.dll
foo_dsp_std.dll
foo_ui_std.dll
Reply #156
Thanks to the developers for the keyboard shortcut for "Properties (properties tab)" .
There is also a "Properties (metadata tab)", but that's the same as just "Properties".
Reply #157
At least the Vorbis decoding failure issue appears to be fixed again  Thanks Peter!
Reply #158
This has been fixed in b3 afaik.
Reply #159
Nope, I discovered and reported it after beta 3.
Reply #160
I just wanted to say thanks for beta 4!  It is significantly faster opening/closing and all around for me that the beta 3.
Reply #161
Exactly.  Sadly, all such enquiries have met with no response so far.
Reply #163
guys, I really can't download the executable from the official site!
I'd just tried to clean my cookies and cache (like Yotsuya suggested), but don't worked in the Firefox and Internet Explorer.
Always I click in the link, and simply reload the webpage.
Reply #164
Try this: Copy the downloadlink and Paste it into the adressbar.
Reply #165
What changes needed to be made to fix Vista compatability?  I'm not running Vista yet, but I'm curious about the state of the transistion and why some programs do not work properly in under it.
Reply #166
I just installed Foobar v0.9.3 final on my Vista Public Beta2 testbox and it appears to run fine. Mind you this was just a default install and nothing fancy, no 3rd party plugins or anything but it appears to work out of the box with nothing special.
Reply #167
In this case, it was some memory management functions in the runtime library that Microsoft changed in a non-backwards compatible way.
Reply #168
Don't worked too! I'd tried to copy to my download manager (flashget) and don't worked too!
it's too bad
Reply #169
If you want, I can upload it to YouSendit, and you can dl from there..just reply .
Reply #170
it's too bad
Well... it sounds like bloated software (read: firewall) is installed on your computer. If this is the case turn it off/uninstall/shift+delete... As you may see it's less than helping.
Reply #171
oh, do this for me, please! thanks!
I don't use firewall, but thanks for your help!
Reply #172
meh. just disable the download manager.. works just fine
Reply #173
I don't using download manager, what I said's: I'd tried to use, but don't worked.
Reply #174
v 0.9.3.1 is out
