So I have been using this script for some time and like it very much. I wanted to add an extra query to display a custom chart of most played albums of the genre that is currently played. Everything is set up fine and the sql query is sound however for some reason the WHERE clause for case 160 doesn't seem to work. The strange thing is only +albumid+ and +artistid+ seem to work in a WHERE clause and nothing else.
I've got no knowledge of Jscript and basic knowledge of sql.
// show and generate bar charts
function build_charts(){
if(fso.fileExists(db_file)){
try{
var date_range = dateRangeObj[dateRangeIdx].sql;
var dateRangeSqlStr = (date_range)? 'datetime(PLAYTIME) > datetime(\'now\',\''+date_range+'\',\'localtime\')' : "1=1" ;
if(show_charts === 1){
var query = "";
switch(chart_mode){
case 150:
query = '\"SELECT COUNT(ARTISTID) AS ARTISTCOUNT,ARTIST FROM playcount WHERE '+dateRangeSqlStr+' GROUP BY artistid ORDER BY artistcount DESC LIMIT '+limit+';\"';
break;
case 151:
query = '\"SELECT COUNT(TRACKID) AS TRACK_COUNT ,ARTIST || \' - \' || TITLE, TRACKID FROM playcount WHERE '+dateRangeSqlStr+' GROUP BY ARTIST, TITLE ORDER BY TRACK_COUNT DESC LIMIT '+limit+';\"';
break;
case 152:
query = '\"SELECT COUNT(ALBUMID) AS ALBUM_COUNT ,ARTIST || \' - \' || ALBUM FROM playcount WHERE '+dateRangeSqlStr+' GROUP BY ALBUMID, ARTIST ORDER BY ALBUM_COUNT DESC LIMIT '+limit+';\"';
break;
case 153:
// SELECT COUNT(albumid),artist || ' ~ ' || album FROM playcount where artistid = 1646199482 group by albumid
query = '\"SELECT COUNT(ALBUMID) AS ALBUM_COUNT, ALBUM FROM playcount WHERE ARTISTID = '+artist_id+' AND '+dateRangeSqlStr+' GROUP BY ALBUMID ORDER BY ALBUM_COUNT DESC LIMIT '+limit+';\"';
break;
case 155:
query = '\"SELECT COUNT(TITLE) AS TITLE_COUNT, TITLE FROM playcount WHERE ARTISTID = '+artist_id+' AND ALBUMID = '+album_id+' AND '+dateRangeSqlStr+' GROUP BY TITLE ORDER BY TITLE_COUNT DESC, PLAYTIME DESC LIMIT '+limit+';\"';
break;
case 156:
query = '\"SELECT COUNT(TITLE) AS TITLE_COUNT, TITLE FROM playcount WHERE ARTISTID = '+artist_id+' AND '+dateRangeSqlStr+' GROUP BY TITLE ORDER BY TITLE_COUNT DESC, PLAYTIME DESC LIMIT '+limit+';\"';
break;
case 154:
query = '\"SELECT COUNT(sort1) AS SORT1_COUNT, sort1 FROM playcount WHERE '+dateRangeSqlStr+' GROUP BY sort1 ORDER BY SORT1_COUNT DESC LIMIT '+limit+';\"';
break;
case 160:
query = '\"SELECT COUNT(ALBUMID) AS ALBUM_COUNT, ALBUM FROM playcount WHERE sort1 = '+sort1+' AND '+dateRangeSqlStr+' GROUP BY ALBUMID ORDER BY ALBUM_COUNT DESC LIMIT '+limit+';\"';
break;
case 157: // query lfm charts
case 158:
case 159:
get_lfm_charts();
return;
break;
default:
query = '\"SELECT COUNT(ARTIST) AS ARTISTCOUNT,ARTIST FROM playcount WHERE '+dateRangeSqlStr+' GROUP BY artistid ORDER BY artistcount DESC LIMIT '+limit+';\"';
Can anyone advise? I've been looking at this, and the entire script, for 2 days now and can't seem to find what's wrong. Is there some variable that needs to be defined so that it knows to look at the current playing genre and us that in the WHERE clause of the query? The field name in the table for it is "sort1".
This is the complete script:
[code]// ==PREPROCESSOR==
// @import "%fb2k_path%scripts\common.js"
// ==/PREPROCESSOR==
var version = "1.0 beta5";
version 1.0 beta5
optimize customization vars a bit (colors/fonts)
loading one common.js file
version 1.0 beta4
customized install routine
version 1.0 beta3
some cleanup, adding sprintf()
set titleformat and lang strings as object for easier edit.
version 1.0 beta2
query the playlist, write it to json because playlistObj go nowhere
read json, sort it from chartArray write m3u - load it with foobar
version 1.0 beta
generate playlist from different charts (artist/title)
playlist is generated by serarchquery of foo_httpcontrol.
No SORT possible, right now.
Playlist could be generated via javascript/json.
result could be parsed and sorted right, writing m3u playlist
version 0.9.0
add install routine to create playcount.sqlite
drop batchfile using %comspec% /c sqlite3.exe ...
simplify reading charts.txt using function
version 0.8.5
add meta total played to stat!
version 0.8
add overall to track stat, using an Sqlite SQL View Table!
fix display longer timespans in statistic
version 0.7
add last.fm charts finally
cleanup/messup code
version 0.6
add Tooltip to points, finally
points generated by class
version 0.5
add Radio counting by station
fix "?" for untagged parts to NULL and write them as undefined in DB
version 0.4
add correct scrobbling behaviour and set playcount after 50% or 4 minutes (lean by marc2000)
version 0.3
add album, tracks from album, tracks by current artist to charts
remove writing daily playcount.txt (flatfile db)
add menu to mouse leftclick
version 0.2
add SORT1 Query for charts
version 0.1
initial release
TODO:
set meta for charts (average track etc)
- var modulo = depending on daterange woche = 7 / monat/jahr = 30 / need to display dates on x axsis
- easier setup.
- make playlist work on first try!
// CUSTOM CHANGES START
* Set fb2k titleformatsyntax here
Note:
define your titleformat for artist,album,title here
the data to each track in db is stored as readable text.
for grouping data, we generate unique numbers/id from artist, album, to ensure
displaying after changing lower/uppercase of these fields.
But if you change artist/title/album we can't group correctly anymore
So this is where %FOO_..._ID% comes in.
But these values must be hardwired to each track as id3tag
Same goes for %FINGERPRINT_FOOID% a unique acoustic fingerprint.
If they are present you can change your Tags and statistic keeps track and can group
by artist/album correctly
var tf ={ artist:"$trim($if2(%artist%,undefined))",
artist_id:"$if(%FOO_ARTIST_ID%,%FOO_ARTIST_ID%,$crc32($lower([%artist%])))",
album:"$trim($if2(%album%,undefined))",
album_id:"$if(%FOO_ALBUM_ID%,%FOO_ALBUM_ID%,$crc32($lower([%album%])))",
title:"$trim($if2(%title%,undefined))",
id:"$if(%FINGERPRINT_FOOID%,$crc32(%FINGERPRINT_FOOID%),$crc32($lower([%artist%][%album%][%title%])))",
date:"[%date%]",
playcount:"[%play_counter%]",
first_played:"[%first_played%]",
last_played:"[%last_played%]",
tracktime:"[%length%]",
sort1:"[%genre%]", // sort1 and 2 are mapped to playcount table
sort2:"[%style%]"
Some language strings
var lang = {
no_stat:"No Stats at the moment, but they will be generated",
chart_mode_text:{ 150:"Overall artist charts for %s",
151:"Most played tracks for the last %s",
152:"Most played albums for the last %s",
153:"Most played album by %s for the last %s",
154:"Favorite genre for the last %s",
155:"Most played tracks of %s's album ''%s'' for the last %s",
156:"Most played tracks of %s for the last %s",
160:"Favorite album of genre for the last %s",
157:"Last.fm artist charts for the last %s",
158:"Last.fm most played tracks for the last %s",
159:"Last.fm most played albums for the last %s",
def:"Charts for %s"
chart_meta_text:{ def:"Meta (Query Avarage Track Playing per day and total over time)"
stat_mode_text:{ 1:"Statistic for ''%2$s'' by %1$s",
2:"Statistic for album ''%3$s'' by %1$s",
3:"Statistic for %1$s",
4: "Top per day"
stat_meta_text:{ def:"Total played %f times - first played %s - last played %s"
var stat_headline = "Charts & Statistics";
var meta = "by muzack, version "+version;
var stat_install_info = "Click on the top headline to get the menu.\nSetup your last.fm username and api key to retrive your last.fm statistics\nSetup a custom playcount statistic database to track your plays locally and get some nice realtime graphs. (experimental!)";
Color & Font Settings
var stat_item_color = RGB(113,183,230); // element color
var stat_bg_color = RGB(28,28,28); // white
var stat_hl_color = RGB(255,255,255); // white
var stat_line = RGB(230,230,230); // light grey
var stat_legend = RGB(200,200,200); // grau
var stat_item_t = RGBA(200,10,200,0); // grau
var stat_meta_color = RGB(150,150,150); // grey
var g_textcolor_hl = RGB(141,213,225); // Head Text Color
var g_color_hl = RGB(203,203,203);
var m_font = gdi.Font("Segoe UI", 8, 1); // micro font-size
var s_font = gdi.Font("Segoe UI", 9, 1); // small font-size
var n_font = gdi.Font("Tahoma", 9, 0); // normal font-size
var nb_font = gdi.Font("Lucida Grande", 9, 0); // normal font-size, bold
var bb_font = gdi.Font("Segoe UI", 13, 1); // big font, bold
// CUSTOM CHANGES END - Do not edit below this, unless you know what you do!
var debug = window.GetProperty("debug",0);
// tooltip Marks
var g_tooltip = window.CreateTooltip();
var g_down = false;
var ttm_down = null;
var cur_ttm = null;
var ttMarks = [];
// standard values for stat/charts
// date range
var dateRangeObj = [{text:"one week",sql:"-7 days",lfm:"7day"},
{text:"one month",sql:"-1 months",lfm:"1month"},
{text:"three months",sql:"-3 months",lfm:"3month"},
{text:"six month",sql:"-6 months",lfm:"6month"},
{text:"one year",sql:"-1 years",lfm:"12month"},
{text:"overall",sql:"",lfm:"overall"}];
var dateRangeIdx = window.GetProperty("date_range",110) - 110;
// limit charts
var limitRangeArray = ["20", "30", "40","50"];
var limit = limitRangeArray[window.GetProperty("limit_range",120) - 120];
// which_stat = Current Track based statistic
// 1 = track, 2=album, 3=artist, 4 Top per day
var which_stat = window.GetProperty("which_stat",1);
// show bars = 1/show valley = 0
var show_charts = window.GetProperty("show_charts",1);
// chart_mode = artist/album/trackcharts
var chart_mode = window.GetProperty("chart_mode",150);
// lfm chart mode api call
var lfm_chart = {157:"gettopartists",158:"gettoptracks",159:"gettopalbums"};
// files & paths
var sqlite3exe = fb.FoobarPath+'sqlite3.exe';
var db_file = fb.ProfilePath+'playcount.sqlite';
var init_sql = script_path + 'custom_playback_statistic\\playcount-struct.sql';
var info_txt = script_path + 'custom_playback_statistic\\install-custom-playcount-info.txt';
var batch_cmd = '%comspec% /c sqlite3.exe "' + os_escape(db_file) + '" ';
var pc_file = data_folder + 'playcount.txt';
var pc_file_test = data_folder + 'playcount.txt';
var chart_file = data_folder + 'charts.txt';
var lfm_chart_json = data_folder + "lfm-chart.json";
var username_file = settings_path + "username";
var username = read(username_file);
var api_key_file = settings_path + "api_key";
var api_key = read(api_key_file);
// data arrays
var pc_data = [];
var chartsArray = [[0,'unknown']];
var chartsObj = {};
// playlist generator
var foo_httpcontrol_exist = utils.CheckComponent("foo_httpcontrol", true);
var playlistEnabledArr = ["151","155","156"]; // which stat can produce playlists
var playlist_query_url = 'http://127.0.0.1:8888/Query/';
var playlistObj = {};
var playlistSortArray = [];
var playlist_json = data_folder + "playlist.json";
var playlist_m3u = data_folder + "playlist.m3u";
var playlist_img = gdi.Image(images_path + "playlist.png");
var stat_img = gdi.Image(images_path + "stat.png");
// test
//var chartsArray = csvArray("2|Inouk ~ No Danger|350263707\n2|Inouk ~ Elected|594016820\n2|Inouk ~ With The Birds|2574961760\n2|Inouk ~ Somewhere In France|3721457220\n1|Inouk ~ Victory|62160163\n1|Uke Of Spaces Corners County ~ This Old World|311760166\n1|Motorama ~ Letter Home|1144510168\n1|Uke Of Spaces Corners County ~ Bird On A Wire|1178016057\n1|Uke Of Spaces Corners County ~ Flotilla|1791777379\n1|Motorama ~ Compass|2013908431\n");
// helper
var offset = 0;
var time_elapsed = 0;
var target_time = 0;
// let the charts begin!
on_item_focus_change();
show(show_charts);
// -- FUNCTIONS
function init_playcount(){
if(!fso.fileExists(sqlite3exe)){
var BtnCode2 = WshShell.Popup("sqlite3.exe not found in foobar2000 program folder.\nPress Ok to open the folder.", 0 ,"Error",1+16);
switch(BtnCode2) {
case 1: //ok
WshShell.Run('"'+os_escape(fb.FoobarPath)+'"');
fb.trace("SQLite.exe not in "+fb.FoobarPath);
return false;
break;
case 2: //cancel
return false;
break;
return false;
if(!fso.fileExists(db_file)) {
try{
// keep window open for msg
//WshShell.Run('%comspec% /k sqlite3.exe "' + os_escape(db_file) + '" < "' + os_escape(init_sql) + '"', 0, true);
//test for sqlite3.exe
var BtnCode = WshShell.Popup("Install custom playcount statistic database?", 0 ,"Setup",4+32);
switch(BtnCode) {
case 6: //yes
WshShell.Run(batch_cmd + ' < "' + os_escape(init_sql) + '"', 0, true);
break;
case 7: //no
return false;
break;
var i = read_textfile(info_txt);
if(init_playcount()) fb.ShowPopupMessage(i,"Custom playcount statistic info");
} catch(e){
fb.trace('SQLITE: Error creating DB!');
return false;
}else{
fb.trace("SQLITE: DB already exist!");
return true;
function disable_custom_playcount(){
var BtnCode = WshShell.Popup("Disable custom playcount statistic?", 5 ,"Setup",4+32);
switch(BtnCode) {
case 6: //yes
// rename playcount db file!
var error = 0;
try{fso.MoveFile(db_file, fb.ProfilePath+'playcount.disabled.'+playtime("datetime")+'.sqlite')}catch(e){error = 1};
try{fso.DeleteFile(pc_file)}catch(e){};
try{fso.DeleteFile(chart_file)}catch(e){};
if(error == 1)
fb.ShowPopupMessage('Custom playcount DB cannot be renamed to playcount.disabled.'+playtime()+'.sqlite - please rename or delete it manually');
else
fb.ShowPopupMessage('Custom playcount DB renamed to playcount.disabled.'+playtime()+'.sqlite');
return (window.Repaint());
break;
case 7: //no
return false;
break;
function show(mode){
return (mode == 1) ? build_charts() : build_stat();
function on_playback_stop(reason) {
//fb.trace("Playback Stop "+reason);
function on_notify_data(name, data) {
if(name == "lastfm_update" && data == 1) {
get_lfm_charts();
window.Repaint();
// build statistic based playlist via foo_httpcontrol
function check_enable_playlist(){
return (foo_httpcontrol_exist && playlistEnabledArr.exists(chart_mode) && show_charts == 1);
function build_playlist(){
var playlist_queryArray = [];
var playlist_sortArray = [];
var playlist_query = '';
var m3u ='';
var url='';
var url_param = "?cmd=Search¶m3=state.json¶m1=";
if(chartsArray.length > 0){
for (var i = 0; i != chartsArray.length; i++){
if(chartsArray[2] != undefined)
playlist_queryArray.push("FOO_ID IS "+chartsArray[2]);
playlist_sortArray.push(chartsArray[2]);
if(playlist_queryArray.length > 0){
playlist_query = playlist_queryArray.join(" OR ");
url = playlist_query_url+url_param+encodeURIComponent(playlist_query);
foo_httpcontrol(url, "stat", function() {save_playlist_json()});
// maybe playlist is not saved at this point
// we have to check if it's ready... :-(
parse_httpcontrol();
outer_loop:
for (var i = 0; i != playlist_sortArray.length; i++){
inner_loop:
for(var j in playlistObj.playlist){
if(playlistObj.playlist[j].track_id == playlist_sortArray){
//fb.trace(playlistObj.playlist[j].track_id + " / " +playlistObj.playlist[j].p);
m3u += playlistObj.playlist[j].p+"\n";
break inner_loop;
if(debug)fb.trace("M3U content\n"+m3u);
try {
ts = fso.OpenTextFile(playlist_m3u, 2, true, -2);
ts.Write(m3u);
ts.close();
} catch(e) {
fb.trace("M3U: Error save charts "+e);
// load sorted playlist
WshShell.Run('"foobar2000.exe" "' + playlist_m3u + '" ', 0, true);
function save_playlist_json() {
xmlDoc = xmlhttp.responsetext;
try {
ts = fso.OpenTextFile(playlist_json, 2, true, -1);
ts.Write(xmlDoc);
ts.close();
return true;
} catch(e) {
fb.trace("WSH foo_httpcontrol: Error save playlist \n"+e);
return false;
function parse_httpcontrol(){
if(fso.fileExists(playlist_json)) {
json_response_String = read_textfile(playlist_json);
playlistObj = JSON.parse(json_response_String);
function foo_httpcontrol(url, user_agent, func) {
xmlhttp.open("GET", url, true);
xmlhttp.setRequestHeader('User-Agent',user_agent);
xmlhttp.setRequestHeader("If-Modified-Since", "Sat, 1 Jan 2000 00:00:00 GMT");
xmlhttp.send();
xmlhttp.onreadystatechange = function() {
if(debug) {
switch( xmlhttp.readyState ) {
case 0: fb.trace("WSH foo_httpcontrol: readystate "+xmlhttp.readyState+" Uninitialized"); break;
case 1: fb.trace("WSH foo_httpcontrol: readystate "+xmlhttp.readyState+" Open"); break;
case 2: fb.trace("WSH foo_httpcontrol: readystate "+xmlhttp.readyState+" Sent"); break;
case 3: fb.trace("WSH foo_httpcontrol: readystate "+xmlhttp.readyState+" Receiving"); break;
case 4: fb.trace("WSH foo_httpcontrol: readystate "+xmlhttp.readyState+" Ready");
fb.trace("WSH foo_httpcontrol: Status "+xmlhttp.status);
break;
if (xmlhttp.readyState == 4) {
if (xmlhttp.status == 200) {
func();
} else {
fb.trace("WSH foo_httpcontrol: Connection Problems");
//window.Repaint();
// called from build_charts();
function get_lfm_charts() {
var period = dateRangeObj[dateRangeIdx].lfm;
if(username.length == 0 || api_key.length != 32) return(fb.trace("WSH Last.fm Charts: Can't contact Last.fm. Check your username / API KEY settings."));
lastfm("&format=json&user=" + username + "&method=user."+lfm_chart[chart_mode]+"&period="+period, "foo_wsh_lastfm_charts", function() {save_file(chart_mode);});
function save_file(chart_mode) {
//fb.trace("JSON: get_lfm_charts"+lfm_chart_json);
try {
ts = fso.OpenTextFile(lfm_chart_json, 2, true, -1);
ts.WriteLine(xmlDoc);
ts.close();
} catch(e) {
fb.trace("WSH Last.fm Charts: Error save charts \n"+e);
parse_lfm_charts(chart_mode);
// build display array from json result
function parse_lfm_charts(chart_mode){
if(fso.fileExists(lfm_chart_json)) {
chartsArray = []; //reset array
lfm_charts_json_string = read_textfile(lfm_chart_json);
chartsObj = JSON.parse(lfm_charts_json_string);
try{
var j=0;
if(chart_mode == 157){
for(var i in chartsObj.topartists.artist){
j++;
chartsArray.push([chartsObj.topartists.artist.playcount,chartsObj.topartists.artist.name]);
if(j == limit)
break;
if(chart_mode == 158){
for(var i in chartsObj.toptracks.track){
j++;
chartsArray.push([chartsObj.toptracks.track.playcount,chartsObj.toptracks.track.artist.name+" - "+chartsObj.toptracks.track.name]);
if(j == limit)
break;
if(chart_mode == 159){
for(var i in chartsObj.topalbums.album){
j++;
chartsArray.push([chartsObj.topalbums.album.playcount,chartsObj.topalbums.album.artist.name+" - "+chartsObj.topalbums.album.name]);
if(j == limit)
break;
}catch(e){
fb.trace("JSON: Error Json");
}else{
fb.trace("JSON: no json file");
window.Repaint();
// paint track statistic
// called from on_paint()
function paint_stat(gr){
var highestValueArray = [];
var pc_data_length = pc_data2.length;
var slice_x = statfield_ww/pc_data_length;
highestValueArray = countArray;
var maxpeak = highestValueArray.max();
var minpeak = highestValueArray.min();
var avgpeak = parseInt((maxpeak+minpeak)/2);
var maxpeakPos = (statfield_wh*maxpeak)/maxpeak;
maxpeakPos = (statfield_top+statfield_wh)-maxpeakPos;
var minpeakPos = (statfield_wh*minpeak)/maxpeak;
minpeakPos = (statfield_top+statfield_wh)-minpeakPos;
var avgpeakPos = (statfield_wh*avgpeak)/maxpeak;
avgpeakPos = (statfield_top+statfield_wh)-avgpeakPos;
// default curvedraw
var old_date_x = statfield_left;
var old_peakPos = statfield_top+statfield_wh;
var last_date_x = statfield_ww+15;
var last_date_y = statfield_top+statfield_wh;
ttMarks = [];
gr.DrawLine(statfield_left, maxpeakPos, statfield_ww+15, maxpeakPos, 1, stat_line);
gr.DrawLine(statfield_left, avgpeakPos, statfield_ww+15, avgpeakPos, 1, stat_line);
gr.DrawLine(statfield_left, minpeakPos, statfield_ww+15, minpeakPos, 1, stat_line);
gr.DrawString(maxpeak, s_font, stat_legend, 15, maxpeakPos-16, 16, 16, StringFormat(StringAlignment.Center, StringAlignment.Center, StringTrimming.EllipsisCharacter));
gr.DrawString(avgpeak, s_font, stat_legend, 15, avgpeakPos-16, 16, 16, StringFormat(StringAlignment.Center, StringAlignment.Center, StringTrimming.EllipsisCharacter));
gr.DrawString(minpeak, s_font, stat_legend, 15, minpeakPos-16, 16, 16, StringFormat(StringAlignment.Center, StringAlignment.Center, StringTrimming.EllipsisCharacter));
//draw first zero point
gr.DrawEllipse(old_date_x-2, old_peakPos-2, 4, 4, 1, stat_item_color);
for (var i = 0; i != pc_data_length; i++){
var date_w = 0;
var peakPos = (statfield_wh*pc_data2['count'])/maxpeak;
peakPos = (statfield_top+statfield_wh)-peakPos;
//get date width
date_w = gr.CalcTextWidth(pc_data2['date'], g_font);
// add width to calc position on x axis
date_x +=(i != 0)?slice_x:0;
//fb.ShowConsole();
var normalizedXPos = date_x+(slice_x/2);
var isEven = function(someNumber){return (someNumber%2 == 0) ? true : false;};
switch(isEven(pc_data_length)){
case true:
var modulo = parseInt(pc_data_length/8);
var c = pc_data_length-1;
break;
default:
var modulo = parseInt(pc_data_length/7);
var c = pc_data_length;
//fb.trace(date_range);
if(i%modulo==0 || i == c)
gr.DrawString(pc_data2['date'], m_font, g_textcolor, normalizedXPos-(date_w/2), date_y, date_w, 18, StringFormat(StringAlignment.Center, StringAlignment.Center, StringTrimming.EllipsisCharacter));
// draw points
if(pc_data_length < 100)
gr.DrawString(pc_data2['count'], s_font, stat_item_color, normalizedXPos-7, peakPos-16, 16, 16, StringFormat(StringAlignment.Center, StringAlignment.Center, StringTrimming.EllipsisCharacter));
gr.DrawEllipse(normalizedXPos-2, peakPos-2, 4, 4, 1, stat_item_color);
gr.DrawLine(old_date_x, old_peakPos, normalizedXPos, peakPos, 1, stat_item_color)
// draw circles from class
var stc = (pc_data_length < 100)? stat_item_color : stat_item_t;
var vp = (pc_data_length < 100)? 4 : 10;
ttMarks.push(new ttMark(normalizedXPos-2, peakPos-2, vp, vp, 1,stc,pc_data2['count'], null,pc_data2['count']+" / "+pc_data2['date']+"/"+pc_data2['artist']));
var old_date_x = normalizedXPos;
var old_peakPos = peakPos;
//draw last points
gr.DrawLine(old_date_x, old_peakPos, last_date_x, last_date_y, 1, stat_item_color);
gr.DrawEllipse(last_date_x-2, last_date_y-2, 4, 4, 1, stat_item_color);
var meta = sprintf(lang.stat_meta_text.def,highestValueArray.sum(),fp,lp);
gr.DrawString(meta, g_font, stat_meta_color, 6, 34, ww-16, 16, StringFormat(StringAlignment.Near, StringAlignment.Near, StringTrimming.EllipsisCharacter));
function on_mouse_move(x, y) {
var ttm = ttMarksTraceMouse(x, y);
window.SetCursor((y > 8 && y < 26 && x < ww-60 ) || (check_enable_playlist() && (x > ww-60 && x < ww-10 && y > 8 && y < 26)) || ttm ? IDC_HAND : IDC_ARROW);
if (ttm != cur_ttm) {
cur_ttm && cur_ttm.onMouseOut();
ttm && ttm.onMouseIn();
if (ttm != ttm_down) {
ttm_down = null;
cur_ttm = ttm;
// paint bar charts
function paint_charts(gr){
gr.FillSolidRect(statbox_left, statbox_top, statbox_ww, statbox_wh, g_backcolor);
var chartslength = chartsArray.length;
var row_h = (statfield_wh-10)/chartslength;
// var row_h = 20;
var row_y_pos = (statfield_top-0);
var maxPeak = chartsArray[0][0];
var bar_max_w = statfield_ww-180;
var bar_left = statfield_left+200;
//fb.trace(maxPeak);
// get build array from count values
var maxValueArray = new Array();
for (i = 0; i != chartslength; i++){
maxValueArray.push(chartsArray[0]);
// find min count to set min barsize.
var min_widthValue = maxValueArray.max();
var min_width = gr.CalcTextWidth(min_widthValue, g_font);
// min_width = 135;
switch(chart_mode){
case 150:
case 154:
case 157:
var bar_width = (bar_max_w*chartsArray[0])/maxPeak;
bar_width = (bar_width < min_width)?min_width:bar_width;
gr.DrawString(chartsArray[1], n_font, g_textcolor, 20, row_y_pos, 150, row_h-2, StringFormat(StringAlignment.Near, StringAlignment.Center, StringTrimming.EllipsisCharacter));
gr.FillSolidRect(200, row_y_pos, bar_width, row_h-2, stat_item_color);
gr.DrawString(chartsArray[0], nb_font, stat_hl_color, 205, row_y_pos, bar_width-10, row_h-2, StringFormat(StringAlignment.Near, StringAlignment.Center, StringTrimming.EllipsisCharacter));
row_y_pos += row_h;
break;
case 151:
case 158:
var chartsitem = chartsArray[1].split(" - ");
gr.DrawString(chartsArray[1], n_font, g_textcolor, 20, row_y_pos, 275, row_h-2, StringFormat(StringAlignment.Near, StringAlignment.Center, StringTrimming.EllipsisCharacter));
gr.FillSolidRect(300, row_y_pos, bar_width-100, row_h-2, stat_item_color);
gr.DrawString(chartsArray[0], nb_font, stat_hl_color, 305, row_y_pos, bar_width-10, row_h-2, StringFormat(StringAlignment.Near, StringAlignment.Center, StringTrimming.EllipsisCharacter));
row_y_pos += row_h;
break;
case 152:
case 159:
gr.DrawString(chartsArray[0], nb_font, stat_hl_color, 305, row_y_pos, 20, row_h-2, StringFormat(StringAlignment.Near, StringAlignment.Center, StringTrimming.EllipsisCharacter));
row_y_pos += row_h;
break;
case 153://break;
case 160:
default:
gr.DrawString(chartsArray[1], n_font, g_textcolor, 10, row_y_pos, 150, row_h-2, StringFormat(StringAlignment.Near, StringAlignment.Center, StringTrimming.EllipsisCharacter));
row_y_pos += row_h;
function on_size() {
ww = window.Width;
wh = window.Height;
offset = 0;
function on_paint(gr) {
//fb.trace("on_paint");
offset = Math.round(offset);
gr.SetTextRenderingHint(5);
statbox_left = 60;
statbox_top = 40;
statbox_ww = ww-16;
statbox_wh = wh-68;
textheight = 0;
pos = statbox_top;
date_x = statbox_left+10;
date_y = statbox_wh+statbox_top-20;
statfield_left = statbox_left+10;
statfield_top = statbox_top+20;
statfield_ww = statbox_ww-20;
statfield_wh = statbox_wh-10;
headline_left = 30;
point_x = 0;
point_y = 0;
// stat background
gr.FillSolidRect(statbox_left, statbox_top, statbox_ww, statbox_wh, stat_bg_color);
gr.DrawImage(stat_img, 6, 6, 18, 18, 0, 0, 18, 18);
if(g_metadb) {
if(fso.fileExists(db_file) || username.length > 0 && api_key.length == 32){
// show all charts
if(chartsArray.length == 1 && chartsArray[0][0] == 0){
gr.DrawString(lang.no_stat, g_font, g_textcolor, statbox_left, statbox_top, statbox_ww, statbox_wh, StringFormat(StringAlignment.Center,StringAlignment.Center));
}else{
paint_charts(gr);
}else{
// show trackstat
if(pc_data.length > 0){
// check if real data not from fake array
if(pc_data.length == 1 && pc_data[0]["count"] == 0){
}else{
//draw markers
paint_stat(gr);
ttMarksDraw(gr);
}else{
stat_headline = "";
meta = "";
var _date_range = dateRangeObj[dateRangeIdx].text;
switch(chart_mode){
case 150:
stat_headline += sprintf(lang.chart_mode_text[chart_mode],_date_range);
break;
case 151:
break;
case 152:
break;
case 153:
stat_headline += sprintf(lang.chart_mode_text[chart_mode],artist,_date_range);
break;
case 154:
break;
case 155:
stat_headline += sprintf(lang.chart_mode_text[chart_mode],artist,album,_date_range);
break;
case 156:
break;
case 157:
break;
case 158:
break;
case 159:
break;
case 160:
stat_headline += sprintf(lang.chart_mode_text[chart_mode],sort1,_date_range);
break;
default:
stat_headline += sprintf(lang.chart_mode_text.def,_date_range);
meta += lang.chart_meta_text.def;
}else{
stat_headline = sprintf(lang.stat_mode_text[which_stat],artist,title,album);
// draw headline
if(check_enable_playlist())
gr.DrawImage(playlist_img, ww-28, 6, 18, 18, 0, 0, 18, 18);
gr.DrawString(stat_headline, bb_font, g_textcolor_hl, headline_left, 6, ww-headline_left-16,18, StringFormat(StringAlignment.Near, StringAlignment.Near, StringTrimming.EllipsisCharacter));
gr.DrawLine(5, 29, ww-10, 29, 1, g_color_hl);
// draw meta
}else{
gr.DrawString(stat_install_info, g_font, g_textcolor, statfield_left, statfield_top, statfield_ww, statfield_wh,StringFormat(StringAlignment.Near,StringAlignment.Near));
} else {
gr.DrawString("no selection", g_font, g_textcolor, 0, 0, ww, wh,StringFormat(StringAlignment.Center,StringAlignment.Center));
function on_metadb_changed() {
if(!g_metadb) return(window.Repaint());
var length = fb.TitleFormat("[%length%]").Eval();
artist = fb.TitleFormat(tf.artist).EvalWithMetadb(g_metadb);
title = fb.TitleFormat(tf.title).EvalWithMetadb(g_metadb);
album = fb.TitleFormat(tf.album).EvalWithMetadb(g_metadb);
artist_id = fb.TitleFormat(tf.artist_id).EvalWithMetadb(g_metadb);
album_id = fb.TitleFormat(tf.album_id).EvalWithMetadb(g_metadb);
id = fb.TitleFormat(tf.id).EvalWithMetadb(g_metadb);
rdate = fb.TitleFormat(tf.date).EvalWithMetadb(g_metadb);
if(length.length == 0 && fb.PlaybackTime > 0.1){
artist = "Radio";
album = "Radio";
artist_id = fb.TitleFormat("$crc32(radio)").EvalWithMetadb(g_metadb);
album_id = fb.TitleFormat("$crc32(radio)").EvalWithMetadb(g_metadb);
pc = fb.TitleFormat(tf.playcount).EvalWithMetadb(g_metadb);
fp = fb.TitleFormat(tf.first_played).EvalWithMetadb(g_metadb);
lp = fb.TitleFormat(tf.last_played).EvalWithMetadb(g_metadb);
sort1 = fb.TitleFormat(tf.sort1).EvalWithMetadb(g_metadb);
sort2 = fb.TitleFormat(tf.sort2).EvalWithMetadb(g_metadb);
tracktime = fb.TitleFormat(tf.tracktime).EvalWithMetadb(g_metadb);
// mask for sql inserts
album_sql = album.replace(/"/g,"\\\"");
album_sql = album_sql.replace(/'/g,"''");
title_sql = title.replace(/"/g,"\\\"");
title_sql = title_sql.replace(/'/g,"''");
artist_sql = artist.replace(/"/g,"\\\"");
artist_sql = artist_sql.replace(/'/g,"''");
sort1_sql = sort1.replace(/"/g,"\\\"");
sort1_sql = sort1_sql.replace(/'/g,"''");
sort2_sql = sort2.replace(/"/g,"\\\"");
sort2_sql = sort2_sql.replace(/'/g,"''");
// show charts on itemFocusChange but only if it's not playing
if(! fb.IsPlaying){
//if(debug) fb.trace("----- Force Show Charts");
show(show_charts);
window.Repaint();
// lean from marc2000 lfm script
function on_playback_new_track() {
time_elapsed = 0;
switch(true) {
case (fb.PlaybackLength == 0):
target_time = 240;
break;
case (fb.PlaybackLength >= 30):
target_time = Math.min(Math.floor(fb.PlaybackLength / 2),240);
break;
default:
target_time = 5;
show(show_charts);
function on_playback_time(time) {
time_elapsed++;
if(time_elapsed == target_time) {
//on_item_focus_change();
playcount();
show(show_charts);
try{
var query = "";
switch(chart_mode){
case 150:
break;
case 151:
break;
case 152:
break;
case 153:
break;
case 155:
break;
case 156:
break;
case 154:
break;
case 160:
break;
case 158:
case 159:
get_lfm_charts();
return;
break;
default:
if(debug){
fb.trace("++++SQL // START - Mode: "+chart_mode);
fb.trace(query);
fb.trace("++++SQL // END");
if(query.length > 0){
WshShell.Run(batch_cmd + query + ' > "'+chart_file+'"',0,true);
if(fso.fileExists(chart_file)) {
var charts_table = read_textfile(chart_file);
chartsArray = csvArray(charts_table);
}else{
CollectGarbage();
}catch(e){
fb.trace("WSH Charts: build charts went wrong "+e);
}else{
if(debug) fb.trace('No Custom Playcount DB (Build Charts)');
get_lfm_charts();
window.Repaint();
// generate statistic
function build_stat(){
var dateRangeSqlStr = (date_range) ? 'datetime(a.PLAYTIME) > datetime(\'now\',\''+date_range+'\',\'localtime\')' : "1=1";
var minDateSqlStr = (date_range) ? 'date(\'now\',\''+date_range+'\',\'localtime\')' : "b.MIN_QUERYDATE" ; // MIN_QUERYDATE is the row of MIN_DATE SQL view!
var minDateSqlView = (date_range) ? '':', MIN_DATE b';
var query = '\"SELECT COUNT(a.TRACKID) AS COUNTER, date(a.PLAYTIME) as PT, '+minDateSqlStr+' AS START_DATE FROM playcount a '+minDateSqlView+' WHERE a.TRACKID = '+id;
query += ' AND '+dateRangeSqlStr+' GROUP BY PT;\"';
// album Query
if(which_stat == 2){
query = '\"SELECT COUNT(a.ALBUMID) AS COUNTER, date(a.PLAYTIME) as PT, '+minDateSqlStr+' AS START_DATE FROM playcount a '+minDateSqlView+' WHERE a.ALBUMID = \''+album_id+'\'';
// artist Query
if(which_stat == 3){
query = '\"SELECT COUNT(a.ARTISTID) AS COUNTER, date(a.PLAYTIME) as PT, '+minDateSqlStr+' AS START_DATE FROM playcount a '+minDateSqlView+' WHERE a.ARTISTID = \''+artist_id+'\'';
// Top per Day
if(which_stat == 4){
query = '\"SELECT a.artistcount AS COUNTER,date(a.PLAYTIME) as PT, '+minDateSqlStr+' AS START_DATE, a.artistname FROM TOP_ARTIST_PER_DAY a '+minDateSqlView;
query += ' WHERE '+dateRangeSqlStr+' GROUP BY PT;\"';
if(debug){
fb.trace("++++SQL // START");
fb.trace(query);
try{
// write query result to file
WshShell.Run(batch_cmd + query + ' > "'+os_escape(pc_file)+'"',0,true);
} catch(e){
fb.trace('WSH Charts: error writing to sqlite');
// try load the file
if(fso.fileExists(pc_file)) {
var pc_datastring = read_textfile(pc_file);
var pc_dataArrayRows = [];
pc_data = [];
pc_data2 = [];
countArray = [];
try {
if(pc_datastring.length > 0) {
pc_dataArrayRows = pc_datastring.split("\n");
for (i = 0; i != pc_dataArrayRows.length-1; i++)
pc_dataArray = pc_dataArrayRows.split("|");
// set start date
pc_start_date = pc_dataArray[2];
pc_data = new Array();
//pc_data1 = new Array();
pc_data["date"] = pc_dataArray[1];
pc_data["count"] = pc_dataArray[0];
pc_data["artist"] = pc_dataArray[3];
countArray.push(parseInt(pc_dataArray[0]));
//fb.trace(countArray);
// build datearray
var tempStartDate = pc_start_date.split("-");
// fb.trace("---"+tempStartDate);
var startDate = new Date(tempStartDate[0],tempStartDate[1]-1,tempStartDate[2]);
var endDate = new Date();
//fb.trace("---"+startDate);
var newDate = startDate;
dateStrings = [];
while (newDate <= endDate){
str = newDate.getFullYear() + "-" +
lz(newDate.getMonth() + 1) + "-" +
lz(newDate.getDate());
dateStrings.push(str);
newDate.setDate(newDate.getDate()+1);
for (i = 0; i != dateStrings.length; i++){
pc_data2 = [];
for (j = 0; j != pc_data.length; j++){
if(dateStrings == pc_data[j]["date"]){
pc_data2["date"] = pc_data[j]["date"];
pc_data2["count"] = pc_data[j]["count"];
pc_data2["artist"] = pc_data[j]["artist"];
break;
}else{
pc_data2["date"] = dateStrings;
pc_data2["count"] = 0;
pc_data2["artist"] = 'undefined';
}else{
if(debug) fb.trace("WSH Charts: making fake array?");
} catch(e) {
fb.trace('WSH Charts: error open playcount.txt');
}else{
if(debug) fb.trace('WSH Charts: no playcount.txt');
}else{
if(debug) fb.trace('No Custom Playcount DB (Build Statistic)');
window.Repaint();
// track playcount to playcount.sqlite
function playcount(){
fb.trace('WSH Charts: set playcount for:' + artist + " - " + title);
var pt = playtime('datetime');
// TODO - let Playtime calculate by sqlite on insert. query must be mit date(...,'localtime') because sqlite insert standard time without timezones
var query = 'INSERT INTO playcount(TRACKID,ARTIST,TITLE,ALBUM,FP,LP,PLAYTIME,PC,ARTISTID,ALBUMID,TRACKTIME,SORT1,SORT2) VALUES(\'' + id + '\',\''+artist_sql+'\',\''+title_sql+'\',\''+album_sql+'\',\''+fp+'\',\''+lp+'\',\''+pt+'\',\''+Number(pc)+'\',\''+artist_id+'\',\''+album_id+'\',\''+tracktime+'\',\''+sort1_sql+'\',\''+sort2_sql+'\');';
query += 'INSERT OR REPLACE INTO artist (artistname,artistid) VALUES (\''+artist_sql+'\','+artist_id+'\');';
query += 'INSERT OR REPLACE INTO album (albumname,albumid,artistid,year) VALUES (\''+album_sql+'\','+album_id+','+artist_id+',\''+rdate+'\');';
if(debug){
fb.trace(query);
try{
WshShell.Run('sqlite3.exe "' + os_escape(db_file) + '" "'+query+'"', 0, true);
} catch(e){
fb.trace('SQLITE: '+e);
fb.trace('SQLITE: '+query);
}else{
if(debug) fb.trace('WSH Charts: No Custom Playcount DB (Playcount)');
function on_mouse_lbtn_up(x, y) {
// playlist button
if(check_enable_playlist()){
if(x > ww-28 && x < ww-10 && y > 8 && y < 26){
build_playlist();
if(y > 8 && y < 26 && x < ww-28 ) {
var _menu = window.CreatePopupMenu();
var _child = window.CreatePopupMenu();
var _date = window.CreatePopupMenu();
var _limit = window.CreatePopupMenu();
var idx;
for (i=0;i<dateRangeObj.length;i++)
_date.AppendMenuItem(MF_STRING, 110 + parseInt(i), dateRangeObj.text);
_date.CheckMenuRadioItem(110, 115, window.GetProperty("date_range",110));
for (i=0;i<limitRangeArray.length;i++)
_limit.AppendMenuItem(MF_STRING, 120 + parseInt(i), limitRangeArray);
_limit.CheckMenuRadioItem(120, 125, window.GetProperty("limit_range",120));
_menu.AppendMenuItem(MF_DISABLED, 0, "Custom Statistic");
_menu.AppendMenuItem(MF_STRING, 1, "Show track statistic");
_menu.AppendMenuItem(MF_STRING, 2, "Show album statistic");
_menu.AppendMenuItem(MF_STRING, 3, "Show artist statistic");
_menu.AppendMenuItem(MF_STRING, 4, "Top per day statistic");
_menu.CheckMenuRadioItem(1, 4, window.GetProperty("which_stat",1));
_menu.AppendMenuItem(MF_SEPARATOR, 0, 0);
_menu.AppendMenuItem(MF_STRING, 150, "Show artist charts");
_menu.AppendMenuItem(MF_STRING, 151, "Show artist-track charts*");
_menu.AppendMenuItem(MF_STRING, 152, "Show artist-album charts");
_menu.AppendMenuItem(MF_STRING, 153, "Show most played album from artist");
_menu.AppendMenuItem(MF_STRING, 155, "Show most played track from artist album*");
_menu.AppendMenuItem(MF_STRING, 156, "Show most played track from artist*");
_menu.AppendMenuItem(MF_STRING, 154, "Show Genres from charts")
