Topic: Remove field name history under "Add New Field" in Propertie (Read 3121 times) previous topic - next topic
Is there a way to clear the history of fields I've entered in the Field name input of Add New Field in the Properties menu?
Here is a screenshot.  Foobar fills the Field name input box with ORIGINAL RELEASE as soon as I type 'O' in the  input box.  I don't want to use this field any more so I'd like to remove it from the autofill / dropdown options.
Right click that little arrow and select Wipe history
Shine from the inside to light up the dark night.
omg, so easy.  yet so hidden.
thanks!!!
i was wondering this for a while, thanks  it would be great if you could delete individual ones though
select the field name you want to remove, then right-click on the arrow and select "Remove this history item"
Re: Remove field name history under "Add New Field" in Propertie
with the latest fb2k, you no longer get a drop down list with arrow. you have to go for the advanced config to delete the entry
Hello, I've been trying to do this for a while (having drop-down entries with typos i'd like to get rid of) and finally thought i found the right forum discussion...
But i'm unable to find where this advanced config item is.
I've tried File / Preferences that opens the Media Library Preferences window. Browsed all menus and sub-menus without success.
Any help would be greatly appreciated, thanks
