Topic: FTP plugin to get cloud-streaming? (Read 5771 times) previous topic - next topic
Hi, I thought about making my own little "cloud syncing" program on windows which will make it possible to sync what ever you want on your own ftp. So I would upload my music on my own ftp server. Is there a plugin to play music from an ftp server in foobar?
If HTTP serving is OK for you, then take a look at edna, which I use to serve my collection.
thanks i will try it out.. how exactly does that work? i install it on the ftp-server but how do i use it with foobar? is it a streaming file which i open with foobar? but how do i change tracks/browse the music library on the server?
thanks
It’s an HTTP serving program, so you would need to run it on an HTTP server.
http://edna.sourceforge.net/
The server should work for any platform. I've tested it on Linux and Windows. I've been using Internet Explorer and WinAmp (on Windows) to navigate the pages and play the files.
Using edna is boringly simple. Make sure you have (at least) Python 1.5.2 installed on your system. Edit the edna.conf file with your setup. This is simple to do, as all you need to tell it is:
what port to run on
the directories for your MP3 files
optionally, how to log requests
Then, simply run edna.py. This can be done using:
% python edna.py
It will then go into an infinite loop, serving up pages and files. Hit ctrl-C to stop it.
So it won’t be drag-and-drop as FTP would, but it’s a possible alternative.
