Topic: foobar2000 0.9.4 beta (Read 63942 times) previous topic - next topic
Reply #75
Is "Fix vbr mp3 header" a subset of "Rebuild mp3 stream"?
Reply #76
How would it be? Whereas the first just fixes the headers the second rewrites the whole file (stripping any bad stuff). Hover the mouse over the commands and look in the status bar for more details.
Reply #77
man subset
A = Fix vbr mp3 header
B = Rebuild mp3 stream
Does "rebuild mp3 stream" include "fix mp3 vbr header"?
The question is, if I have e.g. time calculation problems in an mp3 and perform the rebuild mp3 stream function, I will probably not have to "fix the vbr header"?
EDIt: typo
Reply #78
No.
Reply #79
No.
Hm, well, yes. Thanks for clearing this up.
Reply #80
Ah, fb2k devs. Abrupt as ever. I love it.
Is that "No" as in "No, you won't have to fix it" or "No, the assumption that you won't have to fix it is wrong"?
Reply #81
Any chance 0.9.4 could allow you to set the number of rereads to perform, when a crc mismatch is found during a cd rip?
Reply #82
Long time user, first time caller.
I know at least a dozen people are taken aback by the 'Updating Files -> Processing' popup that foobar 0.9 has when dealing with ID3 tags. This is particularly frustrating when using the official playcount plugin, with the 'synchronize with id tags' option enabled, as every song pops up this dialogue.
Is it possible to include an option to 'disable' this popup. Particularly the fact it's popping up even if foobar is minimized to the system tray.
This minor issue, for some, is a major issue stopping people from moving from 0.8 -> 0.9
Just thought I'd mention it.
Reply #83
How come I don't see the pop-up everyone is complaining about? I'm using 0.9.4 Beta 2 and the official Playback Statistics plugin. The pop-up did occur when I first upgraded to 0.9.x but since 0.9.3 final version, it has not appeared.
Reply #84
Have you got it set to synchronise the tags with the database? Or whatever the setting was...I changed to the unofficial version so I could set the point at which the tags were written i.e not halfway through the bloody song
My Name is Sean and I'm here to leech off your genius.
Reply #85
Yes, set to sync automatically. And yes, cannot control when it decides to write the tags. I used the unofficial version for a while and have some issues with it on 0.9.3 - though I can't remember what it was.
Switching over to using this version of Playback Statistics has its problems like a different tag name and the coded timestamp. But that's a issue discussed on another thread
Reply #86
You think too much.
Reply #87
Yeah the issues were the incompatibility with v0.9.3 onwards but that was fixed shortly. You should venture back in my opinion its worth it just to determine when the tags are applied and you can use the masstagger to change the field names for playcounting.
Reply #89
Well, actually i have set Foobar to read both play_counter and play_count. Anyway, once the track is played, the Playback Statistics re-writes the tag into the new format while preserving the actual count - so i figure at some point when all the tracks have been played under the new plugin, all the tags will be updated.
Reply #90
Yes, probably no.  Well, if mp3 stream rewriting and tag writing both are deterministic, we could do exact comparison of files to get the answer.
Reply #91
beta3.
Release highlights:
- ABX bugfixes
- Added WMA tag editing support
Reply #93
[/quote]
Ive just tried beta 3 and WMA tag editing does not appear to be working.
[/quote]
I created a test file with WMP11 beta 2 and for me it works.
Reply #94
Deleted foo_input_std and installed over the top again and its now working. I think something may of just gone wrong when i installed the first time round.
Edit:And now its not working, just had 2 crashes whilst tagging the same set of WMA's
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0B703FF2h
Access violation, operation: read, address: 0AA63D70h
Call path:
entry=>app_mainloop
Code bytes (0B703FF2h):
0B703FB2h:  1A 7A FF FF 8B F0 85 F6 89 75 FC 0F 84 F6 7F FF
0B703FC2h:  FF FF 46 04 8B 46 04 3B 47 10 0F 84 00 83 FF FF
0B703FD2h:  8D 45 FC 50 53 8B CF E9 BD 7F FF FF 8B FF 55 8B
0B703FE2h:  EC 8B 45 08 8B 48 34 8B 55 08 8B 42 34 8B 09 50
0B703FF2h:  FF 51 40 5D C2 04 00 6A 28 E8 B4 75 FF FF 85 C0
0B704002h:  59 0F 84 0D FE 03 00 8B C8 E8 21 00 00 00 85 C0
0B704012h:  89 45 FC 0F 84 28 19 06 00 89 70 20 8B 06 56 FF
0B704022h:  50 04 8B 45 08 8B 4D FC 89 08 E9 8D C0 FF FF 33
Stack (0012F474h):
0012F454h:  85BE5584 BF82AD00 B8313B80 B8313B80
0012F464h:  BF800B3B 84723020 BF82AE47 BBF42DF8
0012F474h:  0B041688 0012F494 0B71CDF7 0B0670D0
0012F484h:  0034A0E0 0034C4E8 0034A110 0034F998
0012F494h:  0012F4AC 0B71D5F6 00000000 0B0670D0
0012F4A4h:  0034C510 0012F5F0 0012F4BC 0B707174
0012F4B4h:  0034C4E8 00000000 0012F4E0 0B71CC79
0012F4C4h:  0034C510 00000058 00000004 0B71D5A2
0012F4D4h:  0034C4E8 0B066DA8 0B047D00 0012F4EC
0012F4E4h:  0B71CC96 0034C4E8 0012F510 0B71C330
0012F4F4h:  00000001 0B0435C0 0B71C34E 0B0435C0
0012F504h:  00000001 0B71C3DF 003492E0 0012F53C
0012F514h:  0B71C421 00000001 0B058CF8 0B067FD0
0012F524h:  003492E0 00000000 00000001 0B0435C0
0012F534h:  0B0435C0 00000000 0012F56C 0B71A07D
0012F544h:  003492E0 003492E0 0012F534 0012F564
0012F554h:  0012F558 00000068 00000001 00000000
0012F564h:  00000001 001BFDC0 0012F580 0B78FCB2
0012F574h:  001BFE60 00000000 003492E0 0012F5A0
0012F584h:  0B71B8BA 001BFE60 00000002 003492E0
Registers:
EAX: 0B041688, EBX: 00000000, ECX: 0AA63D30, EDX: 0B0670D0
ESI: 00000001, EDI: 0034C510, EBP: 0012F478, ESP: 0012F474
Crash location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Loaded modules:
foobar2000                      loaded at 00400000h - 004F3000h
ntdll                            loaded at 7C900000h - 7C9B0000h
kernel32                        loaded at 7C800000h - 7C8F4000h
COMCTL32                        loaded at 773D0000h - 774D2000h
msvcrt                          loaded at 77C10000h - 77C68000h
ADVAPI32                        loaded at 77DD0000h - 77E6B000h
RPCRT4                          loaded at 77E70000h - 77F01000h
GDI32                            loaded at 77F10000h - 77F57000h
USER32                          loaded at 77D40000h - 77DD0000h
SHLWAPI                          loaded at 77F60000h - 77FD6000h
SHELL32                          loaded at 7C9C0000h - 7D1D5000h
ole32                            loaded at 774E0000h - 7761D000h
shared                          loaded at 10000000h - 10029000h
comdlg32                        loaded at 763B0000h - 763F9000h
IMM32                            loaded at 76390000h - 763AD000h
LPK                              loaded at 629C0000h - 629C9000h
USP10                            loaded at 74D90000h - 74DFB000h
msctfime                        loaded at 755C0000h - 755EE000h
foo_abx                          loaded at 009E0000h - 00A13000h
foo_albumlist                    loaded at 00A20000h - 00A60000h
foo_audioscrobbler              loaded at 00A80000h - 00AB0000h
WS2_32                          loaded at 71AB0000h - 71AC7000h
WS2HELP                          loaded at 71AA0000h - 71AA8000h
foo_autoplaylist                loaded at 00B10000h - 00B40000h
foo_bitcompare                  loaded at 00B60000h - 00B87000h
foo_cdda                        loaded at 00BB0000h - 00BE6000h
foo_common                      loaded at 00C10000h - 00C4A000h
foo_converter                    loaded at 00C70000h - 00CD9000h
foo_dbsearch                    loaded at 00D00000h - 00D5C000h
foo_dsp_skip_silence            loaded at 00D80000h - 00D8A000h
MSVCR80                          loaded at 78130000h - 781CB000h
foo_dsp_std                      loaded at 00DB0000h - 00DF1000h
foo_freedb2                      loaded at 00E20000h - 00E60000h
foo_input_std                    loaded at 00E80000h - 00F94000h
foo_masstag                      loaded at 00FC0000h - 01010000h
foo_playcount                    loaded at 01030000h - 01058000h
foo_playlist_manager            loaded at 01080000h - 010C7000h
foo_pqview                      loaded at 010F0000h - 0110C000h
foo_random                      loaded at 01130000h - 0116F000h
foo_rgscan                      loaded at 01190000h - 011D8000h
foo_sic                          loaded at 01200000h - 01257000h
foo_uie_albumart                loaded at 01380000h - 013B8000h
gdiplus                          loaded at 4EC50000h - 4EDF3000h
OPENGL32                        loaded at 5ED00000h - 5EDCC000h
GLU32                            loaded at 68B20000h - 68B40000h
DDRAW                            loaded at 73760000h - 737A9000h
DCIMAN32                        loaded at 73BC0000h - 73BC6000h
foo_uie_albumlist                loaded at 093F0000h - 0942F000h
foo_uie_console                  loaded at 09450000h - 0946C000h
foo_uie_quicksearch              loaded at 09490000h - 094D8000h
foo_uie_tabs                    loaded at 09500000h - 09526000h
foo_uie_trackinfo_mod            loaded at 09550000h - 0959A000h
MSVCP80                          loaded at 7C420000h - 7C4A7000h
foo_ui_columns                  loaded at 095B0000h - 0964B000h
foo_ui_std                      loaded at 09670000h - 096C7000h
foo_utils                        loaded at 096F0000h - 09729000h
foo_verifier                    loaded at 09750000h - 09780000h
foo_version                      loaded at 097A0000h - 097C6000h
dbghelp                          loaded at 59A60000h - 59B01000h
VERSION                          loaded at 77C00000h - 77C08000h
uxtheme                          loaded at 5AD70000h - 5ADA8000h
IMGHOOK                          loaded at 30000000h - 30047000h
netapi32                        loaded at 5B860000h - 5B8B4000h
appHelp                          loaded at 77B40000h - 77B62000h
CLBCATQ                          loaded at 76FD0000h - 7704F000h
COMRes                          loaded at 77050000h - 77115000h
OLEAUT32                        loaded at 77120000h - 771AC000h
CRYPT32                          loaded at 77A80000h - 77B14000h
MSASN1                          loaded at 77B20000h - 77B32000h
WINTRUST                        loaded at 76C30000h - 76C5E000h
IMAGEHLP                        loaded at 76C90000h - 76CB8000h
WLDAP32                          loaded at 76F60000h - 76F8C000h
SETUPAPI                        loaded at 77920000h - 77A13000h
urlmon                          loaded at 77260000h - 77300000h
Secur32                          loaded at 77FE0000h - 77FF1000h
SSSensor                        loaded at 0A9A0000h - 0A9B5000h
WINMM                            loaded at 76B40000h - 76B6D000h
DrvTrNTm                        loaded at 6BC00000h - 6BC1A000h
DrvTrNTl                        loaded at 6BC20000h - 6BC3D000h
msdmo                            loaded at 736B0000h - 736B7000h
mswsock                          loaded at 71A50000h - 71A8F000h
DNSAPI                          loaded at 76F20000h - 76F47000h
winrnr                          loaded at 76FB0000h - 76FB8000h
wshbth                          loaded at 751D0000h - 751EE000h
rasadhlp                        loaded at 76FC0000h - 76FC6000h
hnetcfg                          loaded at 662B0000h - 66308000h
wshtcpip                        loaded at 71A90000h - 71A98000h
DSOUND                          loaded at 73F10000h - 73F6C000h
wdmaud                          loaded at 72D20000h - 72D29000h
msacm32                          loaded at 72D10000h - 72D18000h
MSACM32                          loaded at 77BE0000h - 77BF5000h
midimap                          loaded at 77BD0000h - 77BD7000h
KsUser                          loaded at 73EE0000h - 73EE4000h
wmvcore                          loaded at 0B6F0000h - 0B936000h
WMASF                            loaded at 0BB40000h - 0BB7A000h
Stack dump analysis:
Address: 0B71CDF7h, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+000133EAh)
Address: 0B71D5F6h, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+00013BE9h)
Address: 0B707174h, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCheckURLScheme" (+00001BDFh)
Address: 0B71CC79h, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+0001326Ch)
Address: 0B71D5A2h, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+00013B95h)
Address: 0B71CC96h, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+00013289h)
Address: 0B71C330h, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+00012923h)
Address: 0B71C34Eh, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+00012941h)
Address: 0B71C3DFh, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+000129D2h)
Address: 0B71C421h, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+00012A14h)
Address: 0B71A07Dh, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+00010670h)
Address: 0B78FCB2h, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateSyncReader" (+000029D1h)
Address: 0B71B8BAh, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateEditor" (+00011EADh)
Address: 0B6FB88Ah, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Address: 0B78EDEAh, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateSyncReader" (+00001B09h)
Address: 0B78D54Eh, location: "wmvcore", loaded at 0B6F0000h - 0B936000h
Symbol: "WMCreateSyncReader" (+0000026Dh)
Address: 00ECB126h, location: "foo_input_std", loaded at 00E80000h - 00F94000h
Address: 00F44BFCh, location: "foo_input_std", loaded at 00E80000h - 00F94000h
Address: 00ECD77Bh, location: "foo_input_std", loaded at 00E80000h - 00F94000h
Address: 00F47A38h, location: "foo_input_std", loaded at 00E80000h - 00F94000h
Address: 00ECD603h, location: "foo_input_std", loaded at 00E80000h - 00F94000h
Address: 00F46360h, location: "foo_input_std", loaded at 00E80000h - 00F94000h
Address: 0119E149h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 7C809B47h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "CloseHandle" (+00000000h)
Address: 011BE298h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 0119EDBEh, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 011BF483h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 011AF010h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 011B1220h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 0119814Ah, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 0119ED50h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 011BFF9Dh, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 01198049h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 011A0877h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 011A0819h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 011A07C0h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 77D48734h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000006Dh)
Address: 77D5418Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002B2h)
Address: 77D70467h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DeregisterShellHookWindow" (+000001CFh)
Address: 77D541B0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000002D5h)
Address: 77D53FD9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+000000FEh)
Address: 77D4D0A5h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "EnumDisplayMonitors" (+00000142h)
Address: 77D4B50Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000001D0h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 77D53F5Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "PrivateExtractIconExW" (+0000007Fh)
Address: 77D4DAF6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DestroyWindow" (+0000000Ch)
Address: 01197899h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 77D488DAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 011C0148h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 011A0892h, location: "foo_rgscan", loaded at 01190000h - 011D8000h
Address: 77D541E2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77D484FCh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D485A4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D54204h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D48816h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+0000014Fh)
Address: 77D48830h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000169h)
Address: 77D489CDh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+00000127h)
Address: 77D4EC03h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CallNextHookEx" (+00000100h)
Address: 77D61B4Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "AppendMenuA" (+0000006Eh)
Address: 77D489F0h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongW" (+0000014Ah)
Address: 77D48A10h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DispatchMessageW" (+0000000Fh)
Address: 77D5E097h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsDialogMessageW" (+000000DBh)
Address: 0042FC8Eh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 77D4DAEAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DestroyWindow" (+00000000h)
Address: 004BEBA0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0042FD00h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002DD2h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uCallStackTracker::uCallStackTracker" (+00000032h)
Address: 004C0520h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00D4DAEAh, location: "foo_dbsearch", loaded at 00D00000h - 00D5C000h
Address: 0043085Fh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C03BCh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004BFB18h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 00400000h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C7690h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C911538h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000AA9h)
Address: 7C911596h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "wcsncpy" (+00000B07h)
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+00000117h)
Address: 004E41C0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 1000C391h, location: "shared", loaded at 10000000h - 10029000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 004939FDh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4240h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 0044E438h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00447CCBh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00498E3Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496B40h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004C0530h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 10002D87h, location: "shared", loaded at 10000000h - 10029000h
Symbol: "uPrintCrashInfo_SetDumpPath" (+000000A7h)
Address: 004AF185h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00430A66h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E09B0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00496844h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00491D3Ch, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00491D36h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B49F0h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B3960h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E4238h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004AF578h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 00495FA4h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 7C816FD7h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000049h)
Address: 7C839AA8h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "ValidateLocale" (+000002B0h)
Address: 7C816FE0h, location: "kernel32", loaded at 7C800000h - 7C8F4000h
Symbol: "RegisterWaitForInputIdle" (+00000052h)
Address: 0049600Dh, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004E0049h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004F0044h, location: "foobar2000", loaded at 00400000h - 004F3000h
Address: 004B0063h, location: "foobar2000", loaded at 00400000h - 004F3000h
Version info:
foobar2000 v0.9.4 beta 3
UNICODE
Additional info:
Playlist Manager 1.0.2  (foo_playlist_manager)
Common services 0.1  (foo_common)
foobar2000 core v0.9.4 beta 3  (Core)
Converter 1.0.1  (foo_converter)
Playlist tools 0.5.8  (foo_utils)
Console panel 0.2  (foo_uie_console)
Masstagger 1.6  (foo_masstag)
CD Audio Decoder 2.1.1  (foo_cdda)
Audioscrobbler 2.1  (foo_audioscrobbler)
Album Art Panel 0.2.3  (foo_uie_albumart)
Binary Comparator 1.1  (foo_bitcompare)
Randomized playlist entry 1.2.3  (foo_random)
Default User Interface 0.9acc  (foo_ui_std)
WMA Decoder 1.1  (foo_input_std)
Tabbed panel modifyed 0.2.1  (foo_uie_tabs)
ReplayGain Scanner 2.0.2  (foo_rgscan)
Database search 1.3.1 beta 11  (foo_dbsearch)
Playback Statistics 1.3.1  (foo_playcount)
Components versions viewer 0.3  (foo_version)
foosic music database 1.0 beta 11  (foo_sic)
Track info panel mod 0.5 beta [Aug 30 2006 - 16:35:44]  (foo_uie_trackinfo_mod)
freedb Tagger 0.5.2a  (foo_freedb2)
FLAC decoder 1.1.0  (foo_input_std)
Standard DSP array 1.0  (foo_dsp_std)
Skip silence 0.1  (foo_dsp_skip_silence)
File Integrity Verifier 1.0.1  (foo_verifier)
ABX Comparator 1.3.1  (foo_abx)
Quick Search Toolbar 2.8h  (foo_uie_quicksearch)
Columns UI 0.1.3 beta 1v5  (foo_ui_columns)
Album List 3.2.0  (foo_albumlist)
Autoplaylist Manager 1.0  (foo_autoplaylist)
Album list panel 0.2.1 beta 4  (foo_uie_albumlist)
Edit again make that 5 crashes that have occured because of this now, im gonna stop trying.
Reply #95
The problem is in MS WMA runtime and not on our side, there's very little we can do about it. You can try updating Windows Media Player etc to the latest version.
Reply #96
thanks peter for finally adding wma tag editing - nice to know you listen to what people want  keep up the good work!!!
what are the plans for the next release just fixes or features?
Reply #97
Thanks for all your work Peter.
foobar2000 + EAC + Burrrn = Happiness
Reply #98
Ok thanks, by latest version do you mean WMP 10 or 11 beta 2
