Topic: Personal Listening Test of LAME, iTunes and Helix MP3 encoders (Read 18162 times) previous topic - next topic
Abstract:
Blind sound quality comparison between MP3 encoders at 192 kbps.
Encoders:
Helix mp3 encoder v5.1 -V111 -HF2
LAME 3.99.5 -V2.3
LAME 3.100.alpha2 -V2.75
iTunes 12.4.2.4 high quality default, vbr enabled
Samples:
Total 15 samples from my corpus, tested twice per sample.
Total 12 samples from IgorC's test tracks, tested twice per sample.
Hardwares:
Sony PSP-3000 + RP-HT560(1st), RP-HJE150(2nd).
Results:
I will post the bitrate of those settings over diverse albums in 2016 Dec 31. The average bitrate of the album and sample bitrate is very close to 192kbps and equal.
Conclusions & Observations:
The superiority of the Helix mp3 encoder is effectively proved in this test. Helix encodes diverse music tracks at better audio quality using the same bitrate compared to the LAME.
The experimental version LAME 3.100.alpha2 does not offer significantly better average quality, compared to the current stable version of the LAME 3.99.5.
The iTunes has not caught up to the quality of LAME encoders in the mp3 encoding, as of August 2016.
Anova analysis:
FRIEDMAN version 1.24 (Jan 17, 2002) http://ff123.net/
Blocked ANOVA analysis
Number of listeners: 27
Critical significance:  0.05
Significance of data: 1.42E-009 (highly significant)
ANOVA Table for Randomized Block Designs Using Ratings
Source of         Degrees     Sum of    Mean
variation         of Freedom  squares   Square    F      p
Total              107           8.62
Testers (blocks)    26           4.02
Codecs eval'd        3           1.98    0.66   19.62  1.42E-009
Error               78           2.62    0.03
Fisher's protected LSD for ANOVA:   0.099
Means:
helixv   l3995v   l100a2   itunes
  4.46     4.35     4.32     4.09
---------------------------- p-value Matrix ---------------------------
helixv   0.029*   0.005*   0.000*
l3995v            0.530    0.000*
l100a2                     0.000*
helixv is better than l3995v, l100a2, itunes
l3995v is better than itunes
l100a2 is better than itunes
Raw data:
LAME3.100α2	LAME3.99.5	HelixV5.1	iTunes12.4.2.4
%feature 10 -V2.75 -V2.3 -HF2 -V111 High Quality VBR
%feature 11 201k 201k 197k 194k
4.400 4.450 4.350 3.900
4.300 4.200 4.500 4.150
4.400 4.100 5.000 4.400
4.450 4.250 4.800 4.400
4.350 4.250 4.050 3.850
4.400 4.150 4.300 3.900
4.250 4.300 4.550 4.200
4.500 4.350 4.700 4.200
4.200 4.050 3.950 3.700
4.250 4.500 4.750 3.950
4.250 4.250 4.150 4.200
3.800 3.850 4.200 3.950
4.100 4.400 4.500 4.150
4.000 4.300 4.400 3.750
4.400 4.400 4.700 3.950
4.100 4.150 4.350 3.750
4.350 4.450 4.750 3.750
4.100 4.250 4.350 3.650
4.350 4.450 4.450 4.300
4.300 4.250 4.400 4.300
4.350 4.600 4.450 4.050
4.100 4.150 4.250 4.100
4.800 5.000 4.850 4.300
4.600 4.600 4.050 4.300
4.100 4.350 4.500 4.550
5.000 4.900 4.750 4.600
4.450 4.550 4.450 4.150
%samples 10.41_30sec hihats
%samples 11.finalfantasy cemb.
%samples 12.ATrain Jazz
%samples 13.BigYellow Pops
%samples 14.FloorEssence Techno
%samples 15.macabre orch
%samples 16.mybloodrusts guitar
%samples 17.Quizas Latin
%samples 18.VelvetRealm Techno
%samples 19.Amefuribana Pops
%samples 20.Trust Gospel
%samples 21.Waiting Rock
%samples 22.Experiencia Latin
%samples 23.Heart to Heart Pops
%samples 24.Tom's Diner Vocal
%samples 01 castanets inst.
%samples 02 fatboy_30sec Techno
%samples 03 eig Techno
%samples 04 Bachpsichord inst.
%samples 05 Enola Techno
%samples 06 trumpet inst.
%samples 07 applaud Live
%samples 08 velvet perc.
%samples 09 Linchpin Rock
%samples 10 spill_the_blood guitar
%samples 11 female_speech Speech
%samples 12 French_Ad Speech
Bitrates:
%bitrate
212892 213747 237940 192993
168438 155646 165261 192912
192156 192103 209717 193442
204127 205068 203986 193170
232176 233635 188200 193399
194632 186036 195050 193630
190862 202640 184752 193518
202882 200424 205121 193007
234691 231216 207721 194882
180358 180686 181454 193118
203168 206754 201816 192950
186724 189212 210432 193448
197553 195467 192937 193377
194530 194412 205535 193053
163321 166355 189490 193560
203531 209582 201625 196098
272590 277249 283337 193087
212430 217041 216048 194049
192217 176450 186486 193275
198941 190717 199853 193050
236340 228336 202575 194692
234272 230913 216725 195333
240073 247948 240665 194388
193818 198111 167236 193980
180981 180072 180092 192959
139441 145012 112302 193536
177329 180439 146029 194422
Re: Personal Listening Test of LAME, iTunes and Helix MP3 encoders
Thanks for the test, Kamedo!
I wonder what the authors of Helix did to make it so damn good.
How about encoding speed? As far as I remember, Helix was also significantly faster than Lame.
great Kamedo2.
Interesting test. Oldies never die (as of Helix)
I wonder how LAME and Helix scale up to  256 kbps VBR.
I added the album bitrates of all encoder settings to the graph image.
Hi Kamedo2,
thank you for testing these mature codecs. The results are still surprisingly - at least to me.
Could you please tell me why you have choosen the -HF2 switch in case of the Helix codec?
I just did a short test and found out that -HF2 emphasizes the coding of signals >16 kHz more than the alternative -HF switch?
Doesn't this automatically lead to a lower coding quality in the "important" region <16 kHz where other codecs often apply
their low-pass filters? Have you testet -HF2 vs. -HF switch?
... and a Happy New Year!
For anyone who would like to try Helix, I have found these parameters work fine in foobar2000 converter:
- %d -V150 -HF2 -X2 -U2
-Vn is the VBR quality: 0-150 (150 is about 235 kpbs)
-HF2 is optional; I used it to be consistent with what OP did
-X2 I found necessary otherwise you get a bad VBR header; foobar2000 reports wrong track length and kbps
-U2 tells the encoder to use SSE (Pentium II and above)
-h will give you the detailed help page including all available switches
You can find the encoder at RareWares: http://www.rarewares.org/mp3-others.php
Development appears to have stopped in 2005.
Actually, I tested the Helix without the -HF2 option on 224kbps, and it was not significantly better than the Lame.
https://hydrogenaud.io/index.php/topic,100896.0.html
So I needed something different to get some clearer results. Desteroid's comment sounds like using -HF1 or -HF2 on high bitrates is a good idea.
https://hydrogenaud.io/index.php/topic,100896.msg834601.html#msg834601
For those who need or prefer to use constant bit rate with the Helix mp3 encoder, these parameters work fine in foobar2000:
-X2 -U2 -B128 -HF2 -F18500 - %d
B128 corresponds to 256kbps CBR.  Use B160 if 320kbps is desired.  The -F command sets the lowpass filter.  Adjust or omit as preferred.
The Helix encoder is lightning fast on my older laptop.  It will encode 500 songs from FLAC in about 10 minutes.  Perfect for a quick playlist switch on a micro SD card I use in an old flip phone with buggy software that doesn't like VBR and doesn't play gapless.  Lack of gapless encoding is the only drawback I know of in the Helix encoder.
Best regards.  LedHed8
I also noticed that Helix introduces sector boundary errors; LAME does not.
Lame 3.99 / 3.100 is very fast with -f and can be gapless with certain players. The quality of -f is fine and some problematic samples are  better strangely.  One could assume using --noreplaygain -f -V2 ..1.5..1.0  will bring it on-par.
The score improvement of each encoders, relative to the LAME 3.99.5 VBR.
Unfortunately, LAME 3.100 alpha2 is more likely to degrade quality than to improve quality.
RareWares hosts a newer version of Helix than you used back in 2017, namely 5.2.1 2022-12-19.
@Kamedo2 @LedHed8 @Apesbrain Could you please check if there has been any improvement since you commented?
• Join our efforts to make Helix MP3 encoder great again
• Opus complexity & qAAC dependence on Apple is an aberration from Vorbis & Musepack breakthroughs
• Let's pray that D. Bryant improve WavPack hybrid, C. Helmrich update FSLAC, M. van Beurden teach FLAC to handle non-audio data
I am aware of the thread Resurrecting/Preserving the Helix MP3 encoder and the maikmerten's Helix v5.2.1, 2022-12-19, but this thread is about the ancient Helix v5.1, and the modernized Helix version is out of the scope of this thread, sorry!
To the best of my recollection @maikmerten's work was about making both the encoded and decoded files more standards compliant and had nothing to do with tuning of the encoder. I stand to be corrected, but I believe that is the case.
No change. Still creates SBEs.
@Apesbrain, could you explain what is a 'sector boundary error' and how to detect one?
Also, do you encounter such errors when encoding via pipe or when calling directly too (hmp3 in.wav out.mp3)?
I don't think Sector Boundary Error is correct term, that is related to incorrect writing of audio data to a CD.
This MP3 encoder just fails at being gapless. The way audio is sent to the encoder is irrelevant.
@ApesbrainAlso, do you encounter such errors when encoding via pipe or when calling directly too (hmp3 in.wav out.mp3)?
Encoding via pipe. I guess it doesn't matter that SBEs are created. I was just curious since LAME did not exhibit this behavior. TBH, I'd need to check that again.
EDIT: Confirming LAME (32bits version 3.100) does not create SBEs.
@Case, I hope you'll understand why the source storm.wv¹ is compressed with WavPack. My trust in FLAC has been shaken recently due to its inability to reliably preserve non-audio data.
No idea if WavPack always keeps all metadata. Better use zip.
This is getting off-topic, but:
WavPack does, it is designed as a "file compressor": Being "zip for wave" was WavPack's concept from day one as far as I know.  Storing headers and footers bit by bit (uncompressed!), and restoring files bit by bit. This makes it easier to use it as plug-in for audio editors, because the WAVE headers and footers - and metadata that might be there - are available.
That also goes for Monkey's, TAK, OptimFROG and MPEG-4 ALS. You can ask WavPack and TAK to discard non-audio, but AFAIK Monkey's doesn't have any such switch. (WavPack and Monkey's also support other formats than WAVE, and do the same thing there: store headers and footers.)
In FLAC, "foreign metadata" is a retro-fit that you must invoke both upon encoding and upon decoding. FLAC is - like Shorten - basically an audio compressor - for audio signals, not for audio files; yeah sure the signals typically come wrapped in a file, but FLAC wasn't designed to preserve files.
As for the "file compressor" formats, there have been ways ways to "fool" some of the encoders by feeding them non-compliant files, but most often they will give you your broken file back because well, they inherently process files. There are a couple of counterexamples where WavPack will fix a file and warn you about it (DSD terminating prematurely at odd bit or something), and in old days there was a counterexample where WavPack would fix a file without telling you.
And if the historical reference, kindly provided by @Porcus, does not sound convincing enough and you want to play it extra safe by using a more conservative approach to compression, then it makes more sense to consider alternatives to ZIP such as Nanozip, Bzip3, Zpaq, Zstandard, and 7-zip. Nanozip stands out here because, even on vintage hardware, it squeezes WAV files with comparable efficiency to La and OptimFROG in a period of TAK time, i.e. in a matter of seconds.
 3 647 040 = storm.v150hf2.mp3
11 618 112 = storm.la
11 874 364 = storm.ofr
11 961 887 = storm.nz
12 052 258 = storm.tak
12 651 934 = storm.hhx3.wv
17 960 850 = storm.bz3
18 025 854 = storm.m3.zpaq
18 678 360 = storm.mx.7z
20 997 602 = storm.10.zst
22 556 344 = storm.zip
30 203 996 = storm.wav
I guess nobody being in this audio forum longer as a week considers zip for anything. I only wondered why someone consider flac fails for him because some weird wav files metadata.
Helix was one of the best MP3 encoder in 2008, also. (What I did in this image below is to redo the visualization, that's all.)
https://listening-tests.hydrogenaud.io/sebastian/mp3-128-1/results.htm
Spoiler (click to show/hide)
