Topic: JScript Panel + other components (Read 9637 times) previous topic - next topic
foo_musicbrainz has some TOC lookup/disc matching fixes since the last public release, other components are unchanged.
Re: JScript Panel + other components
I've attached a dump of the old website which has requirements/usage instructions but all files are in markdown format.
Not sure what other markdown readers are available - I used Visual Studio Code.
Thanks for everything, nice work, greatly appreciated!  :)
Thanks for the website dump. I've put it back online.
Also added 2.3.5 release as well. Will put up a final 2.3.6 shortly.
Runs main menu commands from the command line. Unlike native command line handling/foo_runcmd, this supports dynamic menu items. Also, you must supply the full path.
foobar2000 /run_main:Edit/Sort/Randomize
foobar2000 /run_main:"Playback/Device/Primary Sound Driver" << use double quotes when command contains spaces
foobar2000 /run_main:Edit/Search
foobar2000 /run_main:Library/Search
The version of JScript Panel attached to the first post is not compatible with fb2k v1.6. It crashes when you try to use utils.CheckFont.
The attached version fixes it. Since fb2k v1.6 requires Windows 7 or later, so does this updated component.
I'm curious to know why was the listebrainz2 plugin deleted? I mean the repo.
Open sourced it again
https://github.com/marc2k3/foo_listenbrainz2
Changes:
removed option to skip submitting tracks by query
tracks must be at least 5 seconds long
add support for submitting work MBIDs
add support for submitting multi-value artist/work MBIDs
sets "listening_from" to "foobar2000"
