[!--sizeo:6--][span style=\"font-size:24pt;line-height:100%\"][!--/sizeo--]K U N G - F O O[/size]
ColumnsUI & Panel Stack Splitter config for foobar2000 (adapted for fullscreen view)
[!--sizeo:3--][span style=\"font-size:12pt;line-height:100%\"][!--/sizeo--]/// CHANGES LOG ///[/size]
v1.3a : added transparency support in ELPlaylist (cover or artist photo) + rating engine at bottom screen + stars as images in ELPlaylist + new colors + 2 resize mode added : vis at top corners + tweaks ...
v1.2a : added folder icons in ELPlaylist + added a new black layout (newbuttons ...) + kroegger font replace by a free one : Uni 05_x+ tweaks
v1.1a : added a new index alphabetical to navigate more easily in large playlist or Coverflow + fix time length for streaming entries + tweaks
v1.0c : trackinfo_mod panel (in Now Playing tab panel, at the top of the blue spectrum) used for rating music files hidden because of a bad path for images => fixed
v1.0b : flash of the playlist scrollbar when changing layout fixed + color of the left Spectrum channel at the bottom fixed (darker than the rigth one)
It looks great Br3tt, do you have Kung Fu and Ibiza loaded on the same installation and just switch between them or will loading Kung Fu mess up the Ibiza config?
not in the same .fcl file, it is not a pack
so ... loading Kung Fu mess up the Ibiza config, be careful (make an export of your actual CUI config before importing Kung-Foo .fcl file
Thanks, i'll be testing this awesome config out!!!
Thanks, it's just an alpha version of the config ... many things are to be added
Great release!
Question, I manage to make chronflow work for my cover scheming name with this syntax:
$replace(%path%,%filename_ext%,)"%artist% - %album%.jpg"
But I do not succeed with the same syntax in IBIZA. Why ?
Little edit: infact it's not working anymore in KungFOO too. Strange it works for one session, I close the app, restart and then it's not working...
When you change, the playlist view, or click on menu, the scroll bar quickly comes and goes real quick. Not a problem really, thought i'd let you know, incase i'm the only one experiencing this. Still testing it out.
Edit: Just a thought, i think stars in the playlist views would look really nice compared to the cool circles.
Great release!
i think it's just because your code is bad, try this :
$replace(%path%,%filename_ext%,)%artist%' - '%album%'.jpg'
fixed, v1.0b released. thanx.
This did fix it thank you. When you go to the third playlist view the top box, where the genre is ect... has a quick lag in it, you can see the playlist behind it real quick
anyone have the HelvCondensedCaps font? a quick google search turns up websites in chinese or something and I can't figure out how to download it.
this font is optionnal, you can use another one like i have said in 1st post
This happens when I am dealing with playlists. Something in this theme is causing crashes on my x64 system. ibiza was working just fine, all I added was the peakmeter plugin and then this theme. Any ideas?
Problem signature:
Problem Event Name: APPCRASH
Application Name: foobar2000.exe
Application Version: 0.9.5.5
Application Timestamp: 48962e34
Fault Module Name: StackHash_3294
Fault Module Version: 6.0.6001.18000
Fault Module Timestamp: 4791a783
Exception Code: c0000374
Exception Offset: 000aada3
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 3294
Additional Information 2: 475220807b3ae7f64a28240aa2db0573
Additional Information 3: d458
Additional Information 4: 972d9423b0603a3fd7afe9f6b03ad36a
no, could you post the whole dump in codebox anchors please ?
Thanks, it now works perfectly. And thanks to your help I manage to make GFX Browser and Splitter display covers correctly.
May I also ask for the correct syntax in playlist config ?
I tried that, but seems to have trouble to make understand the "OR" operator:
// paths
$if($findfile(%__ART_PATH__%),
$puts(cover.path,%__ART_PATH__%)
$puts(cover.path,'%artist% - %album%.jpg)
$puts(cover.path,./images/kung-foo/cover/nocover.png)
Just succeed in bugging the display
I don't know how to post a full dump, what I pasted above is all that vista shows me, but now it seems to be behaving so far. If it crashes again I will look to see if there is a way to post the whole dump.
// paths
like as said in INSTALLATION notes : "IMPORTANT : for ELPlaylist, the cover path is set in a variable handled by ELPlaylist __ART_PATH__ (by default, it's setted to folder.jpg in songs directory) --> go to ELPlaylist Settings (rigth click on it -> settings), tab 'genral' and just double-click on the var name to update the path used!"
so nothing to change in the code in ELPlaylist, just go to settings of ELPlaylist, tab 'General', and change the path value for __ART_PATH__
thanks for this... its working fine for me, but the volume button wont show
love it!!! so much better than ibiza
thank you
When i select the tabs, for Genre, Artist, Album, Album List, my Artist column is sorted by my decade, instead my artist any reason why? I can't seem to fix this.
Edit: Reinstalled the config from scratch and edited to my paths etc.... again, and NOW the artist tab shows the artist column. Some how that had got corrupted.
Edit2: Also when switching from Browser 2 and Browser 3 with Album List enable you will see a weird instance of the album art messed up "mixed in with the playlist" only happens when Album list is enabled all other tabs work fine with Browser 2 and 3 when switching them
EDIT: I noticed something odd, when using this kung-foo config, windows vista volume mixer will not open if the Player is up, when minimized the volume mixer works fine.
Problem signature:
Locale ID: 1033
I think it's because you keep "foo_uie_peakmeter.dll" in your component folder. If you put out, everything will be OK... (i had the same trouble...)
Wow, this config looks pretty cool.. To fix the coverart problem in ELPlaylist: it is now possible to use the core artreader of foobar or columnUI. Now when you use $imgabs(blabla, %path%,artreader) you don't have to use the Art_path variable anymore. You can use the columnUI-setup now and also have the advantage that embedded artwork can be displayed...
nice config, thx Br3tt
but what's wrong with rating? :/
(http://i37.tinypic.com/2naigdl.jpg)
it's great! thanks a lot!
nice dude. kinda bug i get is the tab to change the features like coveflow etc is missing,not permanently,but i need to click on it's place only to make it visible. after that it will vanish again
just a question :
do you launch foobar from a music file (under windows explorer for example) or do you launch foobar directly ?
'Wingdings 2' font needed, that's only that
oops, my fault, thanks!
Under the pause button the time is not there on my end, with the latest config. Your screen shot shows this, and i can't seem to fix this?
is it he only thing that does not appear ?
i launch foobar directly, desktop double click. as far as i can tell that time under the pause button is the only thing i can't see, i'm still testing the config out.
very VERY strange ... never see that
well i can confirm this happens on the first release, and the current second release on my end. Anyone else experiencing this? " No time display under pause button," under the volume button time display is fine.
PROBLEM still present in v1.0c A screen shot of what i'm talking about is here, the green box is where a time display should be as yours is.
(http://xs231.xs.to/xs231/08361/kungfooscreen832.png.xs.jpg) (http://xs231.xs.to/xs231/08361/kungfooscreen832.png)
v1.0c released, fix a bug (rating system hidden due to bad path for images (stars))
Well there have been no more crashes, so I don't know what that was about. Anyway I was replying to the issues of time display under the pause button and was just posting a screenshot showing mine seems to be working just fine.
http://img522.imageshack.us/img522/5002/09...08171358qp6.jpg (http://img522.imageshack.us/img522/5002/09012008171358qp6.jpg)
RavenSoft thank you for replying, i see yours looks fine. i wonder if i need a special font for it too show, i used the original file with no mods to it, and it don't show. hmmm. will look into this a little further. thank you for at least letting me know that it should work fine. take care
EDIT: in fact lcd font needed to be installed, seen that in the code, and changed that to my desired font and ALL IS GOOD NOW~ something as silly as me overlooking the lcd font name was a first, usually i find these things easy and fix them quick, thanks again though raven, got me thinking some how
I figured I would also report that when I loaded 1.0c and tried to play music foobar2000 immediately crashed. When I restarted it, it seems to be working fine. Also if anyone has the optional font HelvCondensedCaps could you pm me? Either that or a very similar font as there is a reason falstaff is using it in his config. thanks.
Great config!! Love it.
Problem for me though. Whenever i click on the arrow that reveals coveflow it disappears unless i scroll it with the mouse wheel. Then it disappears again. This only happens in windowed mode, even if it is stretched to the max. In fullscreen it works fine.
just a question :
directly. what i do to fix is reimporting the .fcl and it fix it. =)
hum, surely a chronflow / 3Dvideo card problem.
Firstly, thank you so very much for this config!!!
It`s very strange, but I have the same problem and I`ve tried to reinstall windinds 2 font (I use Win.Vista)
Also, every time, then I restart foobar, it`s returns to the first position (elplaylist and track info).... so, but I like more third position (there can see three panels), how can I fix that?
Many thanks Falstaff !!!!
Br3tt,
I've always enjoyed you configs, and find they make Foobar even more usable. One request, can you add a button that searches for covers using AlbumArtDownloaderXUI. It's a great tool and I think will even enhance your creation.
NH
bah, damn you 8800gt card!!
Thanks once again. It's the first config that doesn't lag at all while scrolling through the playlist very fast.
Br3tt,
NH
second that and im quite sure Br€tt had this feature in earlier releases.
update the last video driver if not already done
hi all,
take care with ELPlaylist versions, recents versions 0.6.x.x are slow on refreshing tracks (especially for covers like used in Kung-Foo in Album display)
1st post updated :
- ELPlaylist 0.6.1.0b or higher - but i recommand antieriors version like 0.5.x.xb (0.5.2.1b for example)
cause of lag when refreshing list on track change (quite smooth line refresh )
the playlist manager is not very handy...
Very interesting setup! I like your technical approach very much, though i think the color config isn't too cool (gray on gray and white on white isn't too readable..) Anyhow some pretty cool stuff like the menu on the top and I love the switching of the graphical browser. Great!
PREVIEW OF V1.1
added a pager alpha-index to jump easyly and fast in coverflow or playlist, ... works great (binded with playlist and coverflow)
Can you please add the edit menu option please.
NH
nice!
i like this one more.
can you do a plugin pack along with each release I think it will help out al ot of people
Great config, but I'm having a problem.
(http://img402.imageshack.us/img402/6364/kungfookedupmx4.jpg)
Why is there a black border around my buttons/the track timer at the bottom?
help already given with the link for each component to download, don't be so lazy dude
thanks for enjoying this config ;)
Hi Br3tt:
I meet some problems while using your awesome config:
It takes significant high CPU usage, I solved it by just set two horizontal spectrum panels(under ELplaylist) to "fast pesudo-transparent mode"(which only set "transparent" before) in their separate config window.
Regards.
Hi Falstaff thanks for this great config .
When i add 2 internet streams to an empty playlist and then reboot foobar it shows a strange total time.
(http://img231.imageshack.us/img231/1975/67759223mo3.jpg)
is it possible to show the infinity symbol or maybe 0:00?
yes it's possible, i'll do that.
EDIT: done in v1.1a, check 1st post to get it
Hi Br3tt:
Regards.
How low do you have it? Mine's at a little over 100MB.
Hi Br3tt:
Regards.
TP Wang talk about CPU Usage and not Memory Usage just read carefully
and just learn that Memory usage depend on the library size you have and playlist size too (for ELPlaylist part)
so, it is various ;)
Kung-Foo v1.1a released, check 1st post
Hey, i found a bug, or something odd. When i enable playlist album list then there becomes and invisible option, look at screen shot, you'll see the option to sort by singles is there but hidden by some sort of bug>? causing it to not show up in the menu.
(http://xs231.xs.to/xs231/08364/fbarbugkunfgoo973.png.xs.jpg) (http://xs231.xs.to/xs231/08364/fbarbugkunfgoo973.png)
[a href="http://xs231.xs.to/xs231/08364/fbarbugkunfgoo973.png" target="_blank"]
a version of kung-foo = .fcl + folder images, take care
quick question, is there somewhere in the code that says what version you have loaded?
quick answer : no
no bug at all, it is just you that has missed to update the images/kung-foo folder after having installed v1.1a
Thanks, that was all it was, i do apologies i assumed i didn't need too. Thanks it's all good, i also like the color for the spectrum display
Hello,
Is there any way to make the browser start with Artist instead of Genre?
Sorry, I found it
Nice config
About rating - I cannot change rating neither in the bottom part (info display) nor in the playlist.
Should any of them work for modify, or just for display?
Thank you
you need to use the now playing tab, and choose the white stars, however the bottom info display wont show the updated tag unless you click another tab or stop and restart the song. It will be rated though
Thank you, I didn't see it before.
Is it possible to release a version independent of WSH Panel 0.7.2 (still crashes for me)?
Yes, this is possible. Now if br3tt will release this alternative version or allows someone else too we'll see.
Br3tt this is another brilliant configuration by you! Thanks so much man!
ty
hi all,
1st post updated :
fixed in lastest version released today : v0.6.1.2b
very nice config!
I intend to use it, but i really like to get that cover art working! And i dont seem to get what youre saying.
How should i change the path in the settings? I found the settings you mean and tried the following:
Renaming the name from __ART_PATH__ --> EL_playlist__ART_PATH__
Renaming the variable from $replace(%path%,%filename_ext%,)'%artist%' - '%album%'.jpg
(as you posted somewhere here in this forum)
What do you mean by adjusting the path? can someone show me with a screenshot or something, the actual setting instead of describing it?
And last but not least, how should i call the cover in my folder of the cd? In the case above is it like e.g.:
Buddy Guy - Skin Deep.jpg ??
Sorry for all these questions(noobish i know, but i want to learn it) but i really want to get this working.
I'm having a "glitch" with the configuration
The panel with album ,genre and all those stuff has a white line of 1px round it... what the heck?
Otherwise excellent config but I prefer blue so I'm going to customize it
Nicely done
(http://img144.imageshack.us/img144/2995/sanstitrezw7.th.jpg) (http://img144.imageshack.us/my.php?image=sanstitrezw7.jpg)
core, go into file prefrences and go to columns ui, then go to the filter tab, and make sure edge style is set on "none" (near the bottom right)
Hey Br3tt any chance you can/or will support embed images? for cover art. That would be nice.
Wow... so long searching for a easy thing
Thx a lot
Hello :-)
I have the same problem (i use windows vista x86 (default this font is installed)). Falstaff can you help fix this problem.
Ok i'm near the goal with my customization of your foo config!
I wanna know what you people are thinking about it? All blue... cause I love blue
Many things need some adjustement like the group header but I'll make it in time
Here it's!
(http://img337.imageshack.us/img337/9274/sanstitre2rv3.th.jpg) (http://img337.imageshack.us/my.php?image=sanstitre2rv3.jpg)
Here it's!
[a href="http://img337.imageshack.us/my.php?image=sanstitre2rv3.jpg" target="_blank"]
good mod, but this blue is a little too much flashy, i prefer a smooth blue ligther, but tastes and colors ...
Yep but the color depend on screen adjustement too! For me it's dark and smooth
I wil maybe do a another one with different color for each filter tab (artist; genre) & for the play mod =)
Here's the finished blue version -> (http://img170.imageshack.us/img170/2973/sanstitre2zh8.th.jpg) (http://img170.imageshack.us/my.php?image=sanstitre2zh8.jpg)
First of all, great script! I like it very much, but...
I have problems with the rating symbols like some of the people that posted above. I decided to debug the situation because I have all the fonts properly installed (Wingdings, Wingdings 2, Wingdings 3, etc.), but all I get are box-like characters. I tried messing with the 'Playlist Settings' under 'Track list' where the Wingdings characters are used to show the ratings of each song. I found out that if I changed the font (to Tahoma for example) the symbols were still not showing properly and I still got the darned boxes. So I returned to 'Wingdings 2' and decided to mess with the $char function... and it turns out that whenever I enter a number above 126 (for example: $char(127) or $char(166)) I still get the boxes. I don't know if it is a problem with the $char function or a component that I'm using, so I'm posting a list of all the components I have installed:
Core (2008-08-04 01:16:48)
foobar2000 core 0.9.5.5
foo_abx.dll (2008-05-24 18:23:50)
ABX Comparator 1.3.3
foo_albumlist.dll (2008-08-04 01:04:30)
Album List 4.3
foo_cdda.dll (2008-06-25 20:18:24)
CD Audio Decoder 2.1.3
foo_chronflow.dll (2008-04-14 00:16:00)
Chronial's Coverflow 0.3.0
foo_converter.dll (2008-08-04 01:04:34)
Converter 1.1.2
foo_convolve.dll (2006-06-26 22:52:14)
Convolver 0.3
foo_dsp_crossfader.dll (2008-07-25 04:59:28)
Gapless Crossfader 0.3.4.1 (Intel SSE)
foo_dsp_delta.dll (2006-03-21 17:16:22)
LPCM <--> delta-PCM converter 0.1.1
foo_dsp_ssrc.dll (2006-08-15 17:00:00)
Resampler DSP (SSRC) 0.57 SSE2
foo_dsp_std.dll (2008-08-04 01:10:54)
Standard DSP Array 1.0
foo_dsp_vlevel.dll (2006-07-19 23:37:29)
VLevel 20060324.0
foo_facets.dll (2008-09-01 10:58:16)
Facets 2008-02-25
foo_fileops.dll (2008-06-07 22:14:56)
File Operations 2.1
foo_freedb2.dll (2008-06-07 22:15:10)
freedb Tagger 0.6
foo_input_monkey.dll (2008-05-31 22:39:34)
Monkey's Audio Decoder 2.1.3
foo_input_std.dll (2008-08-04 01:04:56)
Standard Input Array 1.0
foo_playcount.dll (2008-07-09 22:00:12)
Playback Statistics 2.1.5
foo_quicktag.dll (2008-05-01 19:39:02)
Quick Tagger 1.0.1
foo_rgscan.dll (2008-06-11 21:30:18)
ReplayGain Scanner 2.0.8
foo_ui_columns.dll (2008-07-22 23:20:48)
Columns UI 0.3.4.1
foo_ui_std.dll (2008-08-04 15:09:14)
Default User Interface 0.9.5
foo_uie_albumlist.dll (2008-08-08 12:30:44)
Album list panel 0.3.1
foo_uie_elplaylist.dll (2008-09-06 21:25:10)
ELPlaylist 0.6.2.0(beta)
foo_uie_graphical_browser.dll (2008-04-19 22:37:53)
Graphical Browser rev015
foo_uie_lyrics.dll (2007-03-12 16:32:45)
Lyric Show Panels 0.3.1.1
foo_uie_panel_splitter.dll (2008-05-31 12:19:42)
Panel Stack Splitter 0.3.4(alpha)
foo_uie_playlists_dropdown.dll (2007-09-29 03:03:32)
Playlists Dropdown 0.6 alpha 4
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
Quick Search Toolbar 2.8l
foo_uie_trackinfo.dll (2008-09-01 11:12:07)
Track info panel 0.8
foo_uie_trackinfo_mod.dll (2007-01-05 13:36:20)
Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12]
foo_uie_vis_channel_spectrum.dll (2008-05-18 03:02:12)
Channel Spectrum panel 0.17.2
foo_uie_vis_peakmeter_spectrum.dll (2008-04-19 20:18:50)
Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_wsh_panel.dll (2007-07-21 20:16:08)
WSH Panel (uie) 0.7.2
foo_unpack.dll (2008-08-04 01:04:20)
RAR reader 1.1
ZIP/GZIP reader 1.0
foo_utils.dll (2008-02-08 23:26:58)
Playlist Tools 0.6.2 beta 6
foo_whatsnew.dll (2008-08-30 15:45:00)
Feature Watcher 1.0.6
I hope someone out there could help me get my neat rating characters showing.
hello! good, perfect almost setup Br3tt. good work. but 3 things bothers me: i can't get play count to work -in ibiza all was ok (i am using my ibiza foobar folder for kung-foo). another thing is how to show vbr bitrate not average
// Tech. Infos
$font(LCDMono,8,normal)
$drawtextex($caps2(%__codec%)' - '$get(bit.rate)' - '%__samplerate%' Hz - '$get(channel.type),296,$sub(%_height%,35),$sub(%_width%,380),20,$get(botscr.green.color),hleft vtop)
%bitrate% isn't working . and last thing rating not showing propertly. (http://i382.photobucket.com/albums/oo264/KremX/dsk.jpg) thanks in advance!
someone mind uploading the WSH plugin? the sites with it are all under maintanence =(
http://rapidshare.com/files/146788441/foo_...h_panel.7z.html (http://rapidshare.com/files/146788441/foo_uie_wsh_panel.7z.html)
thanks mate! but i cant use rapidshare my ISP uses dynamic ip so rapidshare detects my ip having downloaded a file already ><
managed to download it somewhat. but sighh wsh crashes on my athlonxp =(
I've built one without SSE2 before, I don't know if it legal to put here:
http://theo.foobar2000.com.cn/projects/foo...e_wsh_panel.zip (http://theo.foobar2000.com.cn/projects/foo_uie_wsh_panel/foo_uie_wsh_panel.zip)
Thank you very much!!
I've got the same problem, and I have that font installed. I've investigated it further and found out that this config displays Windings characted up to $char(127), but no further. Any character with bigger number gets rendered as that kind of square. Is it a ELPlaylist bug?
Also, can someone point to me the portion of the code where the flip switches (repeat track, shuffle) are described? I'd like to change "shuffle tracks" to "shuffle albums".
Any chance this can be done?, and would you implement this? Or if anyone else knows?
embedded images display is only possible in ELplaylist for Kung-Foo config, and this is not the only way where covers are displayed in the config, so i'll not support it in my config.
Would it be possible to make further versions come with two (or more) colour schemes (like FofR's PUI config did)? Because I see you're planning to make v1.2 completely black, while I'd love to at least keep that white border and panel (like in v1.1) or even have a completely white version.
white border color scheme will be released cause it's the default theme, the black one is just an add
v1.2a released, check the 1st post to grab it on DA
screenshot:
[a href="http://xs232.xs.to/xs232/08403/kung-foo-1.2a848.png" target="_blank"]
screenshot:
it's very cool,THX!
cool update, testing now
Really nice update. I'd generally shy away from the darker scheme and stick with the lighter one, but in this case it's the exact opposite. The dark scheme is great.
Really nice update. I'd genuinely shy away from the darker scheme and stick with the lighter one, but in this case it's the exact opposite. The dark scheme is great.
thank you, and what about some
TRANSPARENCY background , just like that
[a href="http://xs232.xs.to/xs232/08404/kf-transp385.png" target="_blank"]
TRANSPARENCY background looks very good.
Are there any plans to create more color schemes? I like the Kung-Foo very much, its the best designed scheme I would say (like Ibiza was before).
In terms of readability I dont like the black font on brown background because its somethime difficult to read. Therefore I would like to have a more whiter scheme :-)
thank you, and what about some TRANSPARENCY background , just like that
Your Kung-Foo is very strong, Br3tt...
Awesome. Simply awesome.
Hey Guys
Great config but i have a problem. Whenever i try to play a mp3 the foobar crushesh any idea why ?? and i dont know how to make a dump file or something like that
Hey Guys
Dumps are automatically generated on crash in the foobar2000 folder.
Merci beaucoup pour cette config, toujours du bon boulot!
I wanted to know how chronflow can display only the image inside a folder ? I mean it show all the track of a folder with the same jpg instead of showing only the image of this folder. In my playlist its sorted by folder structure because i have different tag inside the same folder (almost vynil rip). Dunno if im clear?
anyway thx again
hey guys~
everything is fine on my pc
there is only one thing i want to know if the rating can be chosen in the list..
i clicked the symbol and had no effect
my fault or it originally does
hope you understand what i mean.
hey guys~
rating songs from ELPlaylist is not possible (buttons not supported in ELPlaylist)
for now, the only way to rate songs is to use the track info mod panel in the option panel NOW Playling, just above the spectrum analyser (panel where you can see the CD box cover too)
hey guys~
thanks for your useful hint~
i found the star above the spectrum analyser
amazing config~
new functionnality to come : cover or artist photo background with transparancy for the playlist :
Yeah, i like that idea br3tt. Artist, or cover in the playlist background awesome with transparency.
Nice feature, can you add this to the next Ibiza build?
That is amazing.
Great
Can I give you a wish list of things I'd love to see in Ibiza?
Great
you can make a wish list ... it's free
That doesn't sound too hopeful
OK, I'll do one tomorrow, it isn't very long and you just KNOW what is in first place
i don't want to give you bad hopes, i'm not doing config to fit personnal uses of other people in priority. But if a request looks good to me, and can be appreciated by the majority of the foobar user, i'll implement it
preview before the release of the v1.3, many fixes (rating is now handling at the bottom screen + rating in the playlist now work for XP users (stars are now pictures, no more special characteres) + background transparency in ELPlaylist to display cover or artist photo + colour fixing + ...
[a href="http://xs232.xs.to/xs232/08413/preview13ablack986.png" target="_blank"]
Kung-Foo v1.3a just released
thanks for the update br3tt
Edit: Black layout no longer has blue genre boxes, or now playing boxes, etc... no big deal
yes, i have changed the blue color to a darker one that (according to me only) looks better
PS: added explanations in 1st post to find PATH to modify to activated the transparency in ELPlyalist (path for covers and artists photo)
thanks, for the answer. I have another question, where are the rating stars in the now playing tab? Can no longer rate? or are they moved, i can't find them lol.
EDIT: it was set to hide panel on startup, unchecked it any everything is ok, but my background is a blue bar behind the stars. Fixed it by changing the background to 45-45-42
rating star engine move to the permanent screen at bottom, now used to rate !!
lol, thanks br3tt. i didn't think to check, I like that feature a lot now i can use a compact design and rate. thanks
Would you consider implementing an album rating system?
In this version (1.3a) the letters on top do not work - I cannot jump to albums starting with a letter by clicking
Fixed it - the left click action was (none) instead of (default)
simple click setted to 'none' cause it lag for refreshing on large playlist, i only use double click to positionning and playing, with no lag at all
I just noticed the mini mode, lol. Thanks man that is pretty cool I was wondering why the screws were moving when i hovered over them lol
Great skin for foobar! Thanks you very much !
I use Your config. Its really good..
but how change code to see cover:
(http://img368.imageshack.us/img368/900/22501752sn0.th.jpg) (http://img368.imageshack.us/my.php?image=22501752sn0.jpg)(http://img368.imageshack.us/images/thpix.gif) (http://g.imageshack.us/thpix.php)
I try but nothing effect. sorry for my english.
btw. cover: \%artist% - %album%.jpg
rigth-click on the cd-box ---> enter 'Splitter steetings and then modify the second line of the script :
// Paths for Covers
$puts(cover.path,$directory_path(%path%)/folder.jpg)
... etc
by your path where covers are stored with the good filename ! if covers are in your music folder so :
// Paths for Covers
$puts(cover.path,$directory_path(%path%)'/'%artist%' - '%album%'.jpg')
... etc
or if covers are all in a specific folder :
// Paths for Covers
$puts(cover.path,'C:\specific_folder\'%artist%' - '%album%'.jpg')
... etc
you may need to restart foobar to make changes available.
looks great m8
gonna try it out asap
i've been using defaultUI forever!
**trackinfo_mod dl seems to be down (badongo)
anyone have an alternative?
looks great m8
http://www.2shared.com/file/3560916/3a24ee...ckinfo_mod.html (http://www.2shared.com/file/3560916/3a24ee52/foo_uie_trackinfo_mod.html)
transparent cover is simply amazing, thanks
Love the update (specifically being to update my track rating from the bottom of the config), but I have a problem: suddenly my grouping doesn't work, and I'm not sure how to change it in ELPlaylist. I think it happened when I tried to change the Artist image path from a Z drive to a C drive, strangely enough. Now whenever I add an album, there's no header and all of the tracks are treated as singles.
Also: I really preferred the blueness in the 1.2 Black config to the brownish color here. Still, not a huge issue (though I am pretty confused at the issue I mentioned above).
EDIT: It works now.
EDIT: It works now.
no idea about this pb without a screenshot ... try to re-install the .fcl file and re-apply Paths modifs !oops, don"t see the edit, we post at the same time
EDIT: It works now.
I think it just required a restart after I changed the artist image path.
I shouldn't have struck my suggestion about going back to blue, though
i am loving this br3tt.
really great work!
Having a small problem.
I updated the ELplaylist cover path:
(http://xs432.xs.to/xs432/08410/f211.jpg)
and now I have this problem:
(http://xs432.xs.to/xs432/08410/g676.jpg)
Missing a lot of the buttons and the cover art works in the background but not for the small square?
really great work!
if buttons where ok before you modify the paths in ELPlaylist, it is that you have modified something else badly, cause there is no link between ELPlaylist code and the Panel SPlitter code in this config,
so i only see a way for you : import the .fcl file again, and try again to update the cover.path
bye
Preety good looking skin!
Thanks Br3tt!
.. and yeah, is there any way to see .jpg or .jpeg files regardless of their names, with covers always in the album folder... can anyone send me the code?
cheers
Definitely, the best config I`ve ever used, and you Falstaff the best foobar skins developer if I would to say so!!!
I am glad to see your progress, from one skin to another and foobar is getting more and more comfortable for me.
Thank you so much!!!
it's too much, but thanx
simply impressive, by far the best music player i ever witnessed. i've gone trough a ton of shitplayers and even more foobarthemes, there where a lot of good ones but none was so dedicated und detailed like this great work
if it wouldnt be such a hassle to get all the artwork straight i would recommend this thing to everyone
but i take it as it is and say thanks, well ok... i changed the noalbum.png to keep up with the good looks
Hello,
Previously I was able to browse the chronflow with arrows and to make quick search with keyboard, is it possible to put on these options ?
Hello,
This is not a KUNG FOO problem, read here...
http://www.hydrogenaudio.org/forums/index....st&p=593197 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=62114&view=findpost&p=593197)
Hello,
Oh, ok thx a lot
I liked the album art reflections in previous versions, though...
My foobar crashes at start up
troubleshooting?
thanks
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 0FE54EBDh
Access violation, operation: write, address: 7FFE0090h
Call path:
entry=>app_mainloop=>Create splitter host=>Create splitter host
Code bytes (0FE54EBDh):
0FE54E7Dh: FC 75 2E 68 B8 3F EB 0F 6A 08 8D 85 FC FE FF FF
0FE54E8Dh: 68 C8 EF EA 0F 50 E8 7E 8C 02 00 83 C4 10 68 08
0FE54E9Dh: 00 07 C0 FF 15 A4 C0 E8 0F 5F 33 C0 5E 8B E5 5D
0FE54EADh: C3 64 A1 18 00 00 00 03 05 54 CB EB 0F 8B 4D FC
0FE54EBDh: 89 08 8B 0D 0C CB EB 0F 57 51 68 60 4C E5 0F 6A
0FE54ECDh: 04 FF 15 C8 C1 E8 0F 85 C0 75 31 68 90 3F EB 0F
0FE54EDDh: 68 5A 04 00 00 8D 95 FC FE FF FF 68 C8 EF EA 0F
0FE54EEDh: 52 E8 23 8C 02 00 83 C4 10 68 5A 04 07 C0 FF 15
Stack (0012E780h):
0012E760h: A968EDD8 A968E770 805970ED 00000001
0012E770h: A968E9DC 0000003B 00000083 007BCB90
0012E780h: 001E29C0 001E2998 00000010 7C91003D
0012E790h: 00154A0A 7FFD8000 7FFDF000 00000000
0012E7A0h: 00000000 00000000 4D011A81 4D011A81
0012E7B0h: 0012E900 0FF926FC 4D011A81 0000000C
0012E7C0h: 00000000 7C90DA0C 7C8024C7 000004EC
0012E7D0h: 00000000 0012E900 0FE5310E 000004EC
0012E7E0h: 00000000 00010000 7FFD8000 000001A0
0012E7F0h: 7C9145E6 7C910440 7C97D600 7C914659
0012E800h: 7C8855F8 7C914579 000206C4 7C8855F8
0012E810h: 7C914579 00150000 0012E8E8 00000000
0012E820h: 5EDA3838 0012E8F2 5EDA2C90 0000015D
0012E830h: 0012E880 00000000 0012E8F2 00000170
0012E840h: 5ED00000 5EDA3278 0012E8EC 00000001
0012E850h: 5ED1C471 4D011A81 0012E8EC 5ED26208
0012E860h: 4D011A81 00000004 00000028 0012E9EC
0012E870h: 00000000 00000003 4D011A81 00000000
0012E880h: 0012E94C 7C917D9A 00229E68 0012E9C8
0012E890h: 0FE54E3F 0FE5248E 001E29C0 001E2998
Registers:
EAX: 7FFE0090, EBX: 0012E9E0, ECX: 00229E68, EDX: 00000008
ESI: 00229E68, EDI: 00000B1C, EBP: 0012E88C, ESP: 0012E780
Crash location: "iglicd32", loaded at 0FCA0000h - 0FED8000h
Symbol: "DrvGetLayerPaletteEntries" (+000016EDh)
Loaded modules:
foobar2000 loaded at 00400000h - 0052B000h
ntdll loaded at 7C900000h - 7C9AF000h
kernel32 loaded at 7C800000h - 7C8F6000h
COMCTL32 loaded at 773D0000h - 774D3000h
msvcrt loaded at 77C10000h - 77C68000h
ADVAPI32 loaded at 77DD0000h - 77E6B000h
RPCRT4 loaded at 77E70000h - 77F02000h
Secur32 loaded at 77FE0000h - 77FF1000h
GDI32 loaded at 77F10000h - 77F59000h
USER32 loaded at 7E410000h - 7E4A1000h
SHLWAPI loaded at 77F60000h - 77FD6000h
SHELL32 loaded at 7C9C0000h - 7D1D7000h
ole32 loaded at 774E0000h - 7761D000h
shared loaded at 10000000h - 1002A000h
COMDLG32 loaded at 763B0000h - 763F9000h
IMM32 loaded at 76390000h - 763AD000h
uxtheme loaded at 5AD70000h - 5ADA8000h
RocketDock loaded at 00A80000h - 00A92000h
PSAPI loaded at 76BF0000h - 76BFB000h
MSCTF loaded at 74720000h - 7476C000h
msctfime loaded at 755C0000h - 755EE000h
foo_abx loaded at 00B20000h - 00B51000h
foo_albumlist loaded at 00B80000h - 00BEC000h
foo_audioscrobbler loaded at 00C10000h - 00C47000h
WS2_32 loaded at 71AB0000h - 71AC7000h
WS2HELP loaded at 71AA0000h - 71AA8000h
foo_autoplaylist loaded at 00C70000h - 00CA0000h
foo_browser loaded at 00CC0000h - 00CF9000h
foo_burninate loaded at 00D20000h - 00D57000h
VERSION loaded at 77C00000h - 77C08000h
foo_cdda loaded at 00D80000h - 00DC0000h
foo_channel_mixer loaded at 00DE0000h - 00E1B000h
foo_chronflow loaded at 00E30000h - 00E91000h
WINMM loaded at 76B40000h - 76B6D000h
gdiplus loaded at 4EC50000h - 4EDF6000h
OPENGL32 loaded at 5ED00000h - 5EDCC000h
GLU32 loaded at 68B20000h - 68B40000h
DDRAW loaded at 73760000h - 737AB000h
DCIMAN32 loaded at 73BC0000h - 73BC6000h
OLEAUT32 loaded at 77120000h - 771AB000h
foo_controlserver loaded at 09050000h - 09089000h
foo_converter loaded at 090B0000h - 09117000h
foo_cwbowron loaded at 09140000h - 0916A000h
foo_dirwatch loaded at 09190000h - 091BE000h
foo_dockable_panels loaded at 091E0000h - 09214000h
foo_dsp_std loaded at 09240000h - 09289000h
foo_fileops loaded at 092B0000h - 092F6000h
foo_freedb2 loaded at 09320000h - 09360000h
foo_infobox loaded at 09380000h - 093C0000h
foo_info_samurize loaded at 093E0000h - 09402000h
foo_input_std loaded at 09540000h - 0966C000h
foo_lyricsdb loaded at 09690000h - 096BF000h
WININET loaded at 771B0000h - 7725A000h
CRYPT32 loaded at 77A80000h - 77B15000h
MSASN1 loaded at 77B20000h - 77B32000h
foo_masstag loaded at 096E0000h - 09730000h
foo_navigator loaded at 09750000h - 09771000h
foo_out_ks loaded at 097B0000h - 097DA000h
SETUPAPI loaded at 77920000h - 77A13000h
foo_playlist_manager loaded at 09800000h - 09844000h
foo_prettypop loaded at 09870000h - 098BD000h
mscoree loaded at 79000000h - 79045000h
MSVCR80 loaded at 78130000h - 781CB000h
msvcm80 loaded at 7C4C0000h - 7C53D000h
mscorwks loaded at 79E70000h - 7A3D6000h
mscorlib.ni loaded at 790C0000h - 79B90000h
mscorjit loaded at 79060000h - 790B3000h
rsaenh loaded at 0FC60000h - 0FC96000h
foo_rgscan loaded at 0BE20000h - 0BE7B000h
foo_run loaded at 0BE80000h - 0BEAB000h
foo_scrobblecharts loaded at 0BEB0000h - 0BEE3000h
foo_uie_albumart loaded at 0BF10000h - 0BF47000h
foo_uie_albumlist loaded at 0BF70000h - 0BFAD000h
foo_uie_elplaylist loaded at 0BFD0000h - 0C037000h
foo_uie_explorer loaded at 0C060000h - 0C09C000h
foo_uie_graphical_browser loaded at 0C0C0000h - 0C154000h
MSIMG32 loaded at 76380000h - 76385000h
foo_uie_lyrics loaded at 0C170000h - 0C1CF000h
foo_uie_panel_splitter loaded at 0C1F0000h - 0C23E000h
foo_uie_peakmeter loaded at 0C260000h - 0C286000h
foo_uie_playlists_dropdown loaded at 0C2B0000h - 0C2EA000h
foo_uie_queuemanager loaded at 0C310000h - 0C349000h
System.ni loaded at 7A440000h - 7AC06000h
System.Drawing.ni loaded at 7ADE0000h - 7AF6C000h
foo_uie_quicksearch loaded at 0C630000h - 0C676000h
foo_uie_single_column_playlist loaded at 0C680000h - 0C6CC000h
MSVCP80 loaded at 7C420000h - 7C4A7000h
foo_uie_tabs loaded at 0C6E0000h - 0C70A000h
foo_uie_trackinfo loaded at 0C730000h - 0C75E000h
foo_uie_trackinfo_mod loaded at 0C780000h - 0C7D6000h
foo_uie_vis_channel_spectrum loaded at 0C7F0000h - 0C818000h
foo_uie_vis_egoh loaded at 0C840000h - 0C85D000h
foo_uie_vis_peakmeter_spectrum loaded at 0C870000h - 0C8AF000h
foo_uie_wsh_panel loaded at 0C8D0000h - 0C904000h
foo_ui_columns loaded at 0C930000h - 0CA5C000h
foo_ui_egoh loaded at 0CA80000h - 0CABE000h
foo_ui_std loaded at 0CAD0000h - 0CBA5000h
foo_unpack loaded at 0CBD0000h - 0CBFD000h
foo_utils loaded at 0CC20000h - 0CC58000h
foo_vis_samurize2 loaded at 0CC80000h - 0CCB0000h
CLBCATQ loaded at 76FD0000h - 7704F000h
COMRes loaded at 77050000h - 77115000h
mswsock loaded at 71A50000h - 71A8F000h
hnetcfg loaded at 662B0000h - 66308000h
wshtcpip loaded at 71A90000h - 71A98000h
System.Windows.Forms.ni loaded at 7AFD0000h - 7BC54000h
pshimp loaded at 0D060000h - 0D0A6000h
WSOCK32 loaded at 71AD0000h - 71AD9000h
imagehlp loaded at 76C90000h - 76CB8000h
appHelp loaded at 77B40000h - 77B62000h
GrooveShellExtensions loaded at 0D530000h - 0D74D000h
GrooveUtil loaded at 68EF0000h - 68FE1000h
GrooveNew loaded at 68FF0000h - 68FF7000h
ATL80 loaded at 7C630000h - 7C64B000h
cscui loaded at 77A20000h - 77A74000h
CSCDLL loaded at 76600000h - 7661D000h
browseui loaded at 75F80000h - 7607D000h
ntshrui loaded at 76990000h - 769B5000h
ATL loaded at 76B20000h - 76B31000h
NETAPI32 loaded at 5B860000h - 5B8B5000h
USERENV loaded at 769C0000h - 76A74000h
shdocvw loaded at 7E290000h - 7E401000h
CRYPTUI loaded at 754D0000h - 75550000h
WINTRUST loaded at 76C30000h - 76C5E000h
WLDAP32 loaded at 76F60000h - 76F8C000h
GrooveSystemServices loaded at 65E30000h - 65E67000h
urlmon loaded at 7E1E0000h - 7E282000h
msxml3 loaded at 74980000h - 74A93000h
xpsp2res loaded at 0E210000h - 0E4D5000h
SXS loaded at 7E720000h - 7E7D0000h
jscript loaded at 75C50000h - 75CCD000h
mscms loaded at 73B30000h - 73B45000h
WINSPOOL loaded at 73000000h - 73026000h
icm32 loaded at 66E90000h - 66ED1000h
msscript loaded at 585A0000h - 585BB000h
vbscript loaded at 73300000h - 73369000h
iglicd32 loaded at 0FCA0000h - 0FED8000h
igldev32 loaded at 0FF70000h - 0FFF2000h
DBGHELP loaded at 59A60000h - 59B01000h
Stack dump analysis:
Address: 7C91003Dh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000130h)
Address: 0FF926FCh, location: "igldev32", loaded at 0FF70000h - 0FFF2000h
Address: 7C90DA0Ch, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "ZwReleaseMutant" (+0000000Ch)
Address: 7C8024C7h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "ReleaseMutex" (+00000010h)
Address: 0FE5310Eh, location: "iglicd32", loaded at 0FCA0000h - 0FED8000h
Symbol: "DrvDescribePixelFormat" (+0000009Eh)
Address: 7C9145E6h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlQueryEnvironmentVariable_U" (+0000006Dh)
Address: 7C910440h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReleasePebLock" (+0000000Fh)
Address: 7C97D600h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 7C914659h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlQueryEnvironmentVariable_U" (+000000E0h)
Address: 7C8855F8h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Address: 7C914579h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlQueryEnvironmentVariable_U" (+00000000h)
Address: 5EDA3838h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Address: 5ED00000h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Address: 5EDA3278h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Address: 5ED1C471h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglGetProcAddress" (+000000CFh)
Address: 5ED26208h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglGetPixelFormat" (+00000417h)
Address: 7C917D9Ah, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlCompareUnicodeString" (+00000412h)
Address: 0FE54E3Fh, location: "iglicd32", loaded at 0FCA0000h - 0FED8000h
Symbol: "DrvGetLayerPaletteEntries" (+0000166Fh)
Address: 0FE5248Eh, location: "iglicd32", loaded at 0FCA0000h - 0FED8000h
Symbol: "DrvCreateLayerContext" (+0000000Eh)
Address: 7C9175D6h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "LdrUnloadDll" (+0000026Bh)
Address: 7C97B178h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 7C9175B4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "LdrUnloadDll" (+00000249h)
Address: 7C80E46Ch, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "DuplicateHandle" (+000005DEh)
Address: 7C90D7ECh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "NtQueryInformationProcess" (+0000000Ch)
Address: 7C815242h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "IsWow64Process" (+00000019h)
Address: 5ED26637h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglDescribePixelFormat" (+000000B6h)
Address: 77F180F6h, location: "GDI32", loaded at 77F10000h - 77F59000h
Symbol: "ExtTextOutW" (+000000C0h)
Address: 77F1819Ah, location: "GDI32", loaded at 77F10000h - 77F59000h
Symbol: "GetObjectType" (+0000009Ch)
Address: 77F1816Dh, location: "GDI32", loaded at 77F10000h - 77F59000h
Symbol: "GetObjectType" (+0000006Fh)
Address: 7E42FA5Dh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "WindowFromDC" (+0000000Fh)
Address: 5ED1B652h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglSwapMultipleBuffers" (+00000CF5h)
Address: 7C90E900h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "strchr" (+00000113h)
Address: 5ED19652h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglSwapLayerBuffers" (+000002FDh)
Address: 5EDAC6E0h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Address: 5ED1B8C9h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglSwapMultipleBuffers" (+00000F6Ch)
Address: 5ED1BA21h, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglCreateLayerContext" (+0000008Dh)
Address: 5ED1BADDh, location: "OPENGL32", loaded at 5ED00000h - 5EDCC000h
Symbol: "wglCreateContext" (+0000000Fh)
Address: 00E31C19h, location: "foo_chronflow", loaded at 00E30000h - 00E91000h
Address: 7C80A739h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "CreateEventW" (+00000000h)
Address: 00E663C7h, location: "foo_chronflow", loaded at 00E30000h - 00E91000h
Address: 00E31615h, location: "foo_chronflow", loaded at 00E30000h - 00E91000h
Address: 00E81720h, location: "foo_chronflow", loaded at 00E30000h - 00E91000h
Address: 7C80A0A7h, location: "kernel32", loaded at 7C800000h - 7C8F6000h
Symbol: "SetEvent" (+00000000h)
Address: 00E66BE3h, location: "foo_chronflow", loaded at 00E30000h - 00E91000h
Address: 00E40E88h, location: "foo_chronflow", loaded at 00E30000h - 00E91000h
Address: 00E67497h, location: "foo_chronflow", loaded at 00E30000h - 00E91000h
Address: 00E40BDCh, location: "foo_chronflow", loaded at 00E30000h - 00E91000h
Address: 0C21A142h, location: "foo_uie_panel_splitter", loaded at 0C1F0000h - 0C23E000h
Address: 0C22644Ah, location: "foo_uie_panel_splitter", loaded at 0C1F0000h - 0C23E000h
Address: 0C21C0F4h, location: "foo_uie_panel_splitter", loaded at 0C1F0000h - 0C23E000h
Address: 0C22CB44h, location: "foo_uie_panel_splitter", loaded at 0C1F0000h - 0C23E000h
Address: 100025D2h, location: "shared", loaded at 10000000h - 1002A000h
Symbol: "uCallStackTracker::uCallStackTracker" (+0000002Fh)
Address: 0C219E65h, location: "foo_uie_panel_splitter", loaded at 0C1F0000h - 0C23E000h
Address: 0C226404h, location: "foo_uie_panel_splitter", loaded at 0C1F0000h - 0C23E000h
Address: 0C97DB20h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA140E8h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA15764h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA1267Ch, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA022CEh, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0C97ED7Ah, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 7E418B26h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowThreadProcessId" (+000000A6h)
Address: 0C9CF190h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 7E4188D1h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+0000002Bh)
Address: 7E4188DAh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetWindowLongW" (+00000034h)
Address: 7E440497h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 0C9CF326h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 7E418734h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+0000006Dh)
Address: 7E41D991h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "TrackMouseEvent" (+0000017Dh)
Address: 7E418830h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "GetDC" (+00000169h)
Address: 7E41B4C0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000184h)
Address: 7E41B4D0h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000194h)
Address: 7E41F104h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "SetLayeredWindowAttributes" (+0000006Ah)
Address: 7C90E453h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "KiUserCallbackDispatcher" (+00000013h)
Address: 0C930000h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA15E00h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 7E41B473h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "DefWindowProcW" (+00000137h)
Address: 7E420A9Fh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "PostQuitMessage" (+000001BEh)
Address: 7E420A65h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "PostQuitMessage" (+00000184h)
Address: 7C910202h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000015Eh)
Address: 7C919CA7h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+00000127h)
Address: 7C919DCDh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+0000024Dh)
Address: 7C919D8Ah, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlReAllocateHeap" (+0000020Ah)
Address: 7C910208h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000164h)
Address: 7C9101BBh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Address: 7C9100A4h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000000h)
Address: 7C915219h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "bsearch" (+00000046h)
Address: 7C91540Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "bsearch" (+00000238h)
Address: 7C910098h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+0000018Bh)
Address: 7C910021h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000114h)
Address: 0CA15E4Eh, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 7C9157A1h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlHashUnicodeString" (+00000164h)
Address: 7C91532Ah, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "bsearch" (+00000157h)
Address: 7C915722h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlHashUnicodeString" (+000000E5h)
Address: 7C9155CDh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFindActivationContextSectionString" (+000000DCh)
Address: 7C910040h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlFreeHeap" (+00000133h)
Address: 7E419951h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsChild" (+00000243h)
Address: 7C910303h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000025Fh)
Address: 0C930108h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 7C910308h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+00000264h)
Address: 7E4199E4h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsChild" (+000002D6h)
Address: 7E419A12h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsChild" (+00000304h)
Address: 7E41A303h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "ClientThreadSetup" (+000002F9h)
Address: 7E419A18h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "IsChild" (+0000030Ah)
Address: 7E41A31Ah, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "ClientThreadSetup" (+00000310h)
Address: 7E41A33Bh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "ClientThreadSetup" (+00000331h)
Address: 004E004Ch, location: "foobar2000", loaded at 00400000h - 0052B000h
Address: 7E419D60h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "UnregisterClassW" (+000002BCh)
Address: 7E471270h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7E410000h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Address: 7C91017Bh, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+000000D7h)
Address: 7C910A16h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+000004B7h)
Address: 7C910961h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "wcsncpy" (+00000402h)
Address: 7E420B58h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "PostQuitMessage" (+00000277h)
Address: 0CA35BACh, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 7C9101C0h, location: "ntdll", loaded at 7C900000h - 7C9AF000h
Symbol: "RtlAllocateHeap" (+0000011Ch)
Address: 0C9D7FD4h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 7E41A3D3h, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "RegisterClassW" (+00000039h)
Address: 7E41F35Eh, location: "USER32", loaded at 7E410000h - 7E4A1000h
Symbol: "CreateWindowExW" (+00000033h)
Address: 0C9CF011h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0C974A34h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA371B0h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA37198h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0C991612h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA349C4h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA01FB0h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0C990800h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA16E38h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA15774h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA371C4h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0C98DBEAh, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA37B04h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA02098h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0C98DCF3h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0C98DCFCh, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA127C0h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA12664h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0C9CAD08h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA35634h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA12A80h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA19C08h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA16E2Ch, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0CA05132h, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 0C9C6F2Fh, location: "foo_ui_columns", loaded at 0C930000h - 0CA5C000h
Address: 00A81DD5h, location: "RocketDock", loaded at 00A80000h - 00A92000h
Version info:
foobar2000 v0.9.5.6
UNICODE
Windows 5.1
Additional info:
Pretty Popup 1.2.3 (foo_prettypop)
Kernel Streaming Output 1.2.2 (foo_out_ks)
Converter 1.1.2 (foo_converter)
ZIP/GZIP reader 1.0 (foo_unpack)
Dockable Panels 1.0.5 [Dec 4 2006 - 09:04:00] (foo_dockable_panels)
Quick Search Toolbar 2.8l (foo_uie_quicksearch)
WSH Panel (uie) 0.7.2 (foo_uie_wsh_panel)
Standard DSP Array 1.0 (foo_dsp_std)
Album Art Browser 0.0.5 [Jul 20 2007 - 15:23:26] (foo_cwbowron)
ReplayGain Scanner 2.0.8 (foo_rgscan)
Last.fm Chart Player 0.2.3 (foo_scrobblecharts)
Directory watcher 0.2 beta 3 (foo_dirwatch)
Default User Interface 0.9.5 (foo_ui_std)
foo_lyricsdb 0.0.7 beta 5 (foo_lyricsdb)
Control Server 1.0.1 (foo_controlserver)
Track info panel 0.8 (foo_uie_trackinfo)
Album List 4.3 (foo_albumlist)
Audioscrobbler 1.3.6 (foo_audioscrobbler)
ABX Comparator 1.3.3 (foo_abx)
Masstagger 1.6 (foo_masstag)
ELPlaylist 0.6.2.6(beta) (foo_uie_elplaylist)
freedb Tagger 0.6 (foo_freedb2)
Album Art Panel 0.2.5.1 (foo_uie_albumart)
Playlist Tools 0.5.9 (foo_utils)
Track info panel mod 0.8.0 beta [Jan 5 2007 - 13:36:12] (foo_uie_trackinfo_mod)
Channel Spectrum panel 0.06b2 (foo_uie_vis_channel_spectrum)
Samurize Visualization Server (AMPI) 1.64 (foo_vis_samurize2)
Run services 0.3.2 (foo_run)
Graphical Browser rev015 (foo_uie_graphical_browser)
Music Browser 1.2.3b [Mar 23 2007 - 16:52:56] (foo_browser)
File Operations 2.1 (foo_fileops)
Standard Input Array 1.0 (foo_input_std)
Special file info box 2.0.3 (foo_infobox)
Queue manager panel 0.2.3 (foo_uie_queuemanager)
Lyric Show Panels 0.3.1.1 (foo_uie_lyrics)
Egoh User Interface 1.1.2 (foo_ui_egoh)
Channel Mixer 0.9.6.2 (foo_channel_mixer)
RAR reader 1.1 (foo_unpack)
Tabbed panel modified 0.2.5 (foo_uie_tabs)
Startup Actions 0.0.1 [Jul 20 2007 - 15:23:26] (foo_cwbowron)
Egoh Spectrum analyser (uie) 1.1.2 (foo_uie_vis_egoh)
Samurize Info Server (AMPI) 1.64 (foo_info_samurize)
Navigator 0.2 (foo_navigator)
Explorer Tree 1.04.6b (foo_uie_explorer)
Album list panel 0.2.1 (foo_uie_albumlist)
Playlist Manager 1.0.2 (foo_playlist_manager)
Peakmeter Panel 0.0.2 (foo_uie_peakmeter)
foobar2000 core 0.9.5.6 (Core)
Single Column Playlist Display 0.5.4 beta [Jan 9 2007 - 15:42:59] (foo_uie_single_column_playlist)
Columns UI 0.3.4.1 (foo_ui_columns)
Playlists Dropdown 0.5.7.5 (foo_uie_playlists_dropdown)
CD Audio Decoder 2.1.3 (foo_cdda)
Autoplaylist Manager 1.0 (foo_autoplaylist)
Chronial's Coverflow 0.3.0 (foo_chronflow)
Peakmeter Spectrum Visualisation 0.2.0.0 beta (foo_uie_vis_peakmeter_spectrum)
Audio CD Writer 2.0.1 (foo_burninate)
Panel Stack Splitter 0.3.5.1(alpha) (foo_uie_panel_splitter)
troubleshooting?
thanks
Illegal operation:
Call path:
Stack (0012E780h):
Registers:
Loaded modules:
Version info:
foobar2000 v0.9.5.6
UNICODE
Windows 5.1
Additional info:
please, update your previous post by replacing code /code anchors by codebox /codebox, that polluate the forum this king of post !
so, i know you'll do it so i give you a reply :
Panel Stack Splitter 0.3.5.1(alpha) (foo_uie_panel_splitter) ==> bugged version of Panel Stack Splitter, go back to the last stable version 0.3.4 it is maybe the cause of your DUMP !
Regards
yes i know, but make your personnal config to be 100% happy ... that's the only way ... choice in my configs have to be done and can't never satisfy all people at the same
problem solved - thank you
and sorry bout the code thing, its fixed now
any chance of updating the config to compensate for foo_uie_trackinfo.dll no longer being supported in 0.9.6? I'm trying beta 1 and that plugin is no longer working it says.
yes he plans on working this out. will be done you can count on that
not yet, stay cool, v0.9.6 is only beta for now, let me time to adapt my configs, stay in 0.9.5.6 is possible for a while no ??
Can not be used in the foobar2000 v0.9.6
Because foobar2000 v0.9.6 does not support foo_uie_trackinfo.dll
yeyo, right above your post, has already been known, and br3tt needs time to adapt his configs
use IBIZA for waiting ...
Hello,I am new, I am French, and my English is not very good, sorry
To start, thank you in Br3tt for this skin
Here my problem, I would like that:
(http://img241.imageshack.us/img241/9880/capture10222008224838dsxb7.png) (http://imageshack.us)
(http://img241.imageshack.us/img241/capture10222008224838dsxb7.png/1/w800.png) (http://g.imageshack.us/img241/capture10222008224838dsxb7.png/1/)
and, i have that:
(http://img241.imageshack.us/img241/9419/sanstitreuu3.png) (http://imageshack.us)
(http://img241.imageshack.us/img241/sanstitreuu3.png/1/w800.png) (http://g.imageshack.us/img241/sanstitreuu3.png/1/)
My albums all are with the format .wav
The structure of my repertories and files:
(http://img355.imageshack.us/img355/9564/testsf2.png) (http://imageshack.us)
(http://img355.imageshack.us/img355/testsf2.png/1/w565.png) (http://g.imageshack.us/img355/testsf2.png/1/)
I modified in foobar > preferences> display chronflow> album source, but not of results
Help , thanks
well I got tired of the prompt saying foo_uie_trackinfo.dll was no longer supported so I just renamed foo_uie_trackinfo_mod.dll to foo_uie_trackinfo.dll and then put it over the one there now and it shut up. I don't know the consequences of this action but I haven't noticed anything really. I'm sure something is messed up by doing this but I figured the mod had the same as the original with just some added stuff. Maybe I am wrong but hey...no more nag LOL.
I've recompiled foo_uie_trackinfo here: <LINK> (http://theo.foobar2000.com.cn/projects/fb2k%2D0%5F9%5F6%2Dports/foo_uie_trackinfo.zip)
Thank you
many thanks T.P Wang as well
Can I just say that this skin is great! I really like it.
But is there a way to browse through the artist and album
list by pressing a letter-key on the keyboard instead of
having to push the up or down keys to navigate?
on whcih parts (panel) ??
- Playlist
- chronflow
- Graphical Browser
last version of Panel Stack Splitter do not handle keypressed (bug to fix), so if u use it, go back to the previous stable version which is 0.3.4, that could fix your pb ...
It was indeed the panel stack splitter!
I went back to version 0.3.4 and navigating works like a charm now.
Thanks very much for the fast feedback.
Now this config is my personal all-time favourite, that was the only missing thing.
Tx to you, good job !
Hi Br3tt have you any idea why the play/previous/volume ... buttons are missing on my skinned foobar:
(http://uppix.net/6/7/a/120600bdbdadd02ef71a1370171cbtt.jpg) (http://uppix.net/6/7/a/120600bdbdadd02ef71a1370171cb.html)
Thanks in advance
ps: you can answer me in french, if you can, i'd rather
Thanks in advance
Does this happen when you play a song/or add it to foobar from a folder or desktop? If so that is why you have problems. Make sure you have the correct version of the plugins you need as well.
This happen when i open foobar without playing/adding songs but it happen too when i play music.
My plugins are:
(http://uppix.net/b/b/8/11eaf087273699d36d62d088e6484tt.jpg) (http://uppix.net/b/b/8/11eaf087273699d36d62d088e6484.html)
First off I would like to say thanks for this great config.
I'm having a few issues. I am missing the volume button picture and the track time on either side of the orange progress bar at the bottom. I have all up to date plugins as far as i know.
(http://img253.imageshack.us/img253/6870/34305333xp7.th.jpg) (http://img253.imageshack.us/my.php?image=34305333xp7.jpg)(http://img253.imageshack.us/images/thpix.gif) (http://g.imageshack.us/thpix.php)
Are the menus 'file', 'view', 'playlist' and 'library' "sticky" for everyone else? I have to click elsewhere to get the menus to disappear.
I also lose my config if i close foobar. What I mean is if i set it so my playlist and coverflow shows at the same time and then close and open foobar, it goes back to the single column playlist.
any help would be appreciated and thanks again.
edit:
I know this might not be directly related to the .fcs, but...
what is the code so artwork will show up no matter what the name is? I have most of my covers named "cover.jpg", how do i configure it so it will display them regardless of the name?
And another Thanks T.P. I'm glad I found this because I've been longing to use bretts nice configs and move away from PanelsUI.
Does anybody know how to add information from playcount to track info panel, like first and last time played of song. (take a look screenshot)
and, if we have possibility to rate songs in this config, would be just great if we have possibility to sort all music library by rating ... is it possible at all ?
(http://img204.imageshack.us/img204/6656/foonm8.jpg)
Thanks in advance
I ALSO HAVE THIS PROBLEM!! IS THAT THERE IS A RESOLUTION
Thanks in advance
how foobar is launched ?
you have to know that relative paths used in ColumnsUI+PSS config work from where the foobar is launched (normally the default installation folder of your foobar). So it do no work if you launch foobar by clicking on a music file (file association) or by using a tierce program that will laucnch foobar if this pgm is not store in the foobar folder ...
First off, thank you soo much!!! Beautiful beautiful skin, I love it and i really appreciate the work, this is the new look/function for me!
EDIT: Alright, I researched my original question in this post, so the new playlist doesnt support wildcards for album art, is that correct?
I am trying this and variants of it:
This string makes it so it displays a blank area and not the music note no art found image...
EDIT 2: Solved:
$if3($findfile($replace(%path%,%filename_ext%,folder.jpg)),$findfile($replace(%path%,%filename_ext%,*.png))etc.etc
Finally found, sorry, i shut up now. Thank you for the wicked theme. I am truly blown away by the functions you have employed. Amazing!
[/quote]
[/quote]
Foobar is loaded by it shortened who is in the menu to start
Thx Falstaff
the problem is regulated
I would like Foobar to open always in this shape:
[a href="http://imageshack.us" target="_blank"](http://img208.imageshack.us/img208/1922/foobar2bh9.png) (http://imageshack.us)
(http://img208.imageshack.us/img208/foobar2bh9.png/1/w540.png) (http://g.imageshack.us/img208/foobar2bh9.png/1/)
After installing the fonts and the dlls into the Components directory then the Images folder and the two layouts. I then follow step (3) to load one and apply the imported layout and all Foobar does is crash.
I have tried this on 0.9.5.6 and 0.9.5.2 neither will work, both versions crash when loading the .fcl
Crash Report:Illegal operation:
Code: C000001Dh, flags: 00000000h, address: 01B9738Eh
Call path:
Code bytes (01B9738Eh):
01B9734Eh: CC CC 32 C0 C3 CC CC CC CC CC CC CC CC CC CC CC
01B9735Eh: CC CC C2 04 00 CC CC CC CC CC CC CC CC CC CC CC
01B9736Eh: CC CC 32 C0 C2 04 00 CC CC CC CC CC CC CC CC CC
01B9737Eh: CC CC 83 EC 28 8B 11 66 0F EF C0 B8 FF FF FF 7F
01B9738Eh: 66 0F D6 44 24 20 89 44 24 20 89 44 24 24 8D 04
01B9739Eh: 24 50 8B 42 54 6A 00 6A 24 66 0F D6 44 24 0C 66
01B973AEh: 0F D6 44 24 14 66 0F D6 44 24 1C 66 0F D6 44 24
01B973BEh: 24 FF D0 50 FF 15 DC F1 BA 01 8B 44 24 2C 8B 4C
Stack (0012EB08h):
0012EAE8h: 00000000 B193C908 B193C214 00000001
0012EAF8h: B193C50C 0000003B 00000083 00787C58
0012EB08h: 0049B718 F48B82C9 02053688 02054AF8
0012EB18h: 00000000 02054AF8 0012EB0C 02054AF8
0012EB28h: 0012EB5C 0049DC00 01941067 0012EB48
0012EB38h: 00000035 00000035 000000DB 000000AA
0012EB48h: 00000000 7FFFFFFF 00000000 7FFFFFFF
0012EB58h: 01942610 01984F1C 00000035 000000DB
0012EB68h: 00000000 00000001 F495E648 028D7BD8
0012EB78h: 028C2328 0012EC28 0000001F 0012EBAC
0012EB88h: 00000007 004EEEF8 028C23F0 00000000
0012EB98h: 00000000 00000000 406C2000 00000000
0012EBA8h: 00000000 00000000 00000000 00000000
0012EBB8h: 00000000 00000000 00000000 00000001
0012EBC8h: 00000000 0012EBE8 000000E4 01953F64
0012EBD8h: 028AFB00 00000013 00000013 00000001
0012EBE8h: 0012EBF8 0012EC44 0194EEE3 00000001
0012EBF8h: 01943011 028C2328 0012EC18 00000000
0012EC08h: 01E58FC8 028C3938 02818C90 00000014
0012EC18h: 00000000 00000000 000000E1 000000E8
Registers:
EAX: 7FFFFFFF, EBX: 00000009, ECX: 01BD4720, EDX: 01BB01C8
ESI: 00000001, EDI: 00000075, EBP: 01984F1C, ESP: 0012EB08
Crash location: "foo_uie_wsh_panel", loaded at 01B90000h - 01BC4000h
Loaded modules:
foobar2000 loaded at 00400000h - 00522000h
ntdll loaded at 7C900000h - 7C9B0000h
kernel32 loaded at 7C800000h - 7C8F4000h
COMCTL32 loaded at 773D0000h - 774D2000h
RPCRT4 loaded at 77E70000h - 77F01000h
GDI32 loaded at 77F10000h - 77F56000h
USER32 loaded at 77D40000h - 77DD0000h
SHELL32 loaded at 7C9C0000h - 7D1D4000h
ole32 loaded at 774E0000h - 7761C000h
GameHook loaded at 10D00000h - 10D0F000h
lgscroll loaded at 10100000h - 1010F000h
NTMARTA loaded at 77690000h - 776B1000h
SAMLIB loaded at 71BF0000h - 71C03000h
foo_albumlist loaded at 00A80000h - 00AE5000h
foo_cdda loaded at 00B10000h - 00B48000h
foo_chronflow loaded at 00B70000h - 00BD1000h
gdiplus loaded at 4EC50000h - 4EDF3000h
DDRAW loaded at 73760000h - 737A9000h
OLEAUT32 loaded at 77120000h - 771AC000h
foo_dsp_std loaded at 014C0000h - 01506000h
foo_input_std loaded at 01530000h - 01658000h
foo_rgscan loaded at 01680000h - 016DA000h
foo_uie_albumlist loaded at 01700000h - 0173D000h
foo_uie_elplaylist loaded at 01760000h - 017C7000h
foo_uie_graphical_browser loaded at 017F0000h - 01884000h
foo_uie_lyrics loaded at 018A0000h - 018FF000h
WININET loaded at 771B0000h - 77256000h
CRYPT32 loaded at 77A80000h - 77B14000h
foo_uie_panel_splitter loaded at 01920000h - 01968000h
foo_uie_quicksearch loaded at 019D0000h - 01A16000h
foo_uie_trackinfo loaded at 01A20000h - 01A4E000h
foo_uie_trackinfo_mod loaded at 01A60000h - 01AB6000h
foo_uie_vis_channel_spectrum loaded at 01AD0000h - 01B0D000h
foo_uie_vis_peakmeter_spectrum loaded at 01B30000h - 01B6F000h
foo_uie_wsh_panel loaded at 01B90000h - 01BC4000h
foo_ui_columns loaded at 01D00000h - 01E33000h
foo_ui_std loaded at 01E60000h - 01F33000h
browseui loaded at 75F80000h - 7607C000h
USERENV loaded at 769C0000h - 76A73000h
NETAPI32 loaded at 5B860000h - 5B8B4000h
shdocvw loaded at 77760000h - 778CC000h
IMAGEHLP loaded at 76C90000h - 76CB8000h
SXS loaded at 75E90000h - 75F40000h
jscript loaded at 75C50000h - 75CBE000h
xpsp2res loaded at 20000000h - 202C5000h
mscms loaded at 73B30000h - 73B44000h
nvoglnt loaded at 69500000h - 69A76000h
Address: 0049B718h, location: "foobar2000", loaded at 00400000h - 00522000h
Address: 0049DC00h, location: "foobar2000", loaded at 00400000h - 00522000h
Address: 01941067h, location: "foo_uie_panel_splitter", loaded at 01920000h - 01968000h
Address: 01942610h, location: "foo_uie_panel_splitter", loaded at 01920000h - 01968000h
Address: 004EEEF8h, location: "foobar2000", loaded at 00400000h - 00522000h
Address: 01953F64h, location: "foo_uie_panel_splitter", loaded at 01920000h - 01968000h
Address: 0194EEE3h, location: "foo_uie_panel_splitter", loaded at 01920000h - 01968000h
Address: 01943011h, location: "foo_uie_panel_splitter", loaded at 01920000h - 01968000h
Address: 01940CD5h, location: "foo_uie_panel_splitter", loaded at 01920000h - 01968000h
Address: 0194ED71h, location: "foo_uie_panel_splitter", loaded at 01920000h - 01968000h
Address: 01D52EE0h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DEA21Ch, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DEC2D0h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DF14B0h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DD7AAEh, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D5412Ah, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 00AD01F8h, location: "foo_albumlist", loaded at 00A80000h - 00AE5000h
Address: 77D48AFEh, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 01DA4400h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 77D488A9h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D488B2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D70494h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetClipboardFormatNameA" (+0000014Fh)
Address: 01DA4596h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 1010854Bh, location: "lgscroll", loaded at 10100000h - 1010F000h
Address: 77D4ED1Ah, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsCharAlphaW" (+0000015Ah)
Address: 77D48709h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000072h)
Address: 77D4D297h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetTopWindow" (+00000128h)
Address: 77D48808h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000171h)
Address: 77D4B368h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000183h)
Address: 77D4B378h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000193h)
Address: 77D4E840h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetSystemMenu" (+00000088h)
Address: 77D862F7h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetRawInputDeviceInfoW" (+000000C6h)
Address: 7C90EAE3h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 01D00000h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DEC340h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 77D4B31Bh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+00000136h)
Address: 77D517EBh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UserClientDllInitialize" (+00000932h)
Address: 77D517B1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UserClientDllInitialize" (+000008F8h)
Address: 77D4B7DBh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "IsWindow" (+00000000h)
Address: 77D4B2A1h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000000BCh)
Address: 5AD71AF6h, location: "uxtheme", loaded at 5AD70000h - 5ADA8000h
Address: 7C910732h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C90EE18h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Symbol: "strchr" (+00000117h)
Address: 7C915041h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C915233h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9105C8h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C910551h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C91056Dh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 01DEC38Eh, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 7C9155C9h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C915152h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C91554Ah, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9153F5h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C910570h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 77D49751h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetLastInputInfo" (+00000238h)
Address: 7C910833h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 01D00100h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 7C910838h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 77D497E4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetLastInputInfo" (+000002CBh)
Address: 77D49812h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetLastInputInfo" (+000002F9h)
Address: 77D4A555h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "wsprintfA" (+00000277h)
Address: 77D49818h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetLastInputInfo" (+000002FFh)
Address: 77D4A56Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "wsprintfA" (+0000028Eh)
Address: 77D4A58Dh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "wsprintfA" (+000002AFh)
Address: 77D49B60h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77DA0248h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D40000h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 7C910738h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9106ABh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9106EBh, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 7C9105D4h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 77D518A4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "UserClientDllInitialize" (+000009EBh)
Address: 01E0CD14h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 7C9106F0h, location: "ntdll", loaded at 7C900000h - 7C9B0000h
Address: 01DAD2F4h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 77D4A625h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 77D51B08h, location: "USER32", loaded at 77D40000h - 77DD0000h
Address: 01DA4281h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D0C6F4h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01E0E378h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01E0E360h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D66632h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01E0BADCh, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DD7780h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D65820h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DED3C0h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DEC2E0h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01E0E38Ch, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D62C8Ah, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01E0ECCCh, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DD7868h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D62D93h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D62D9Ch, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DE87ACh, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DE8694h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D9FDB8h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01E0C74Ch, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DE8A68h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DF01B0h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DED3B4h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01E0C81Ch, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DDABB2h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D9C033h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 77F17C5Dh, location: "GDI32", loaded at 77F10000h - 77F56000h
Symbol: "GetTextMetricsW" (+00000068h)
Address: 77F17C6Dh, location: "GDI32", loaded at 77F10000h - 77F56000h
Symbol: "GetTextMetricsW" (+00000078h)
Address: 77F17C84h, location: "GDI32", loaded at 77F10000h - 77F56000h
Symbol: "GetTextMetricsW" (+0000008Fh)
Address: 77F52020h, location: "GDI32", loaded at 77F10000h - 77F56000h
Address: 01DF0E6Ch, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DEAE60h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DF0EBCh, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DF0E94h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DE9620h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01B36AA3h, location: "foo_uie_vis_peakmeter_spectrum", loaded at 01B30000h - 01B6F000h
Address: 01DD923Fh, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D9C40Ch, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D86B30h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DD8A68h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01D86BD1h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 01DDB728h, location: "foo_ui_columns", loaded at 01D00000h - 01E33000h
Address: 77D54CA6h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateIconFromResourceEx" (+000002C2h)
Address: 77D54CC8h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateIconFromResourceEx" (+000002E4h)
Address: 77D54AF2h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "CreateIconFromResourceEx" (+0000010Eh)
Address: 77D54CFAh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000000h)
Address: 77D54D1Ch, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefDlgProcW" (+00000022h)
Address: 77D487EBh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetDC" (+00000154h)
Address: 77D86299h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetRawInputDeviceInfoW" (+00000068h)
Address: 77D4B3B4h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "DefWindowProcW" (+000001CFh)
Address: 77D494E3h, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "GetWindowLongA" (+00000067h)
Address: 77D4DE6Eh, location: "USER32", loaded at 77D40000h - 77DD0000h
Symbol: "SetPropW" (+000000BBh)
Version info:
foobar2000 v0.9.5.2
UNICODE
Windows 5.1
Additional info:
CD Audio Decoder 2.1.2 (foo_cdda)
Channel Spectrum panel 0.17.2 (foo_uie_vis_channel_spectrum)
Panel Stack Splitter 0.3.4(alpha) (foo_uie_panel_splitter)
Album List 4.2 (foo_albumlist)
Columns UI 0.3.5.5 (foo_ui_columns)
ReplayGain Scanner 2.0.5 (foo_rgscan)
foobar2000 core 0.9.5.2 (Core)
ELPlaylist 0.6.3.0(beta) (foo_uie_elplaylist)
Album list panel 0.2.2 (foo_uie_albumlist)
Crash Report:
Registers:
go to this link and get T.P. Wangs WSH plugin without the SSE2
http://www.hydrogenaudio.org/forums/index....st&p=589236 (http://www.hydrogenaudio.org/forums/index.php?s=&showtopic=65618&view=findpost&p=589236)
Crash Report:
Registers:
By the way what version will this work with, is v0.9.5.6 ?
THANKS
THANKS
Yes it will I've tried it on 0.9.5.6 and 0.9.6 but if you move over to foobar 0.9.6 make sure you get the trackinfo mod panel that T.P Wang also made for 0.9.6 to allow these configs to work on it. Just go a page or 2 more and look for his posts in this thread.
THANKS
Here it is:
T.P Wang trackinfo (http://theo.foobar2000.com.cn/projects/fb2k%2D0%5F9%5F6%2Dports/foo_uie_trackinfo.zip)
THANKS...
P.S. I dumped Kung Foo, I like IBIZA better...
you are wrong, do not talk about trackinfo_mod when you give trackinfo by TP Wang link, these components are different.
only trackinfo is no more compatible and need the version built by TP Wang.
Hello Falstaff
Thx
Nice start! A few questions:
Where is the lyrics panel?
There are a lot of dark fonts on dark background, this really hurts the eye. Could you use colours instead of dark grey, please, like neon green, red or yellow? Anything that makes the stuff more readable, it's a typical flaw of dark themes.
Take a look at his Curacao-skin. Imho the best skin so far, just cool!
Yes I made a typo, but it would of been nice if you could of helped answer my questions...
Oh well, no problem I like IBIZA better...
For those of you with seemingly missing buttons and such:
I've found that using the closest possible version of components to the one listed in the initial post fixes this (at least for me). Specifically, make sure you are using the exact version of panel splitter Br3tt has listed - not the newest version.
Hey,
that's my first post on this forum...
1.
I' from germany and i think my english isn't so good, but i hope you can understand me.
2.
Thank you Br3tt for your great work! I love this very much. It's absolutly my favourite skin...
And now -enough compliments...i have a question.
I would integrate a automatic rating on kung foo. I have the code for this, but i don't know how to integrate the code btw where i integrate the code.
I found the code on www.foobar-users.de (http://foobar-users.de/index.php?topic=332.0) ->
$puts(rating,
$if2(%rating%,
$ifgreater(%play_counter%,70,5,
$ifgreater(%play_counter%,30,4,
$ifgreater(%play_counter%,15,3,
$ifgreater(%play_counter%,10,2,
$ifgreater(%play_counter%,5,1,0)))))))
I will not delete the manual rating, but "enhance" with a automatic rating.
Please help me and i thanks for every answer.
I think you have to put this in the ELPlaylist settings Tracklist and Per Second ($if(%el_isplaying%,.....)
But how to display this in the Playlist is too difficult for me.
Ok, thx for the answer, but it was a little bit more difficult.
Under "Track List":
- you must delete the "// drawing RATING info"-section and then replace it with the new code ->
// automatic rating
$puts(rating,
$if2(%rating%,
$ifgreater(%play_count%,70,5,
$ifgreater(%play_count%,30,4,
$ifgreater(%play_count%,15,3,
$ifgreater(%play_count%,10,2,
$ifgreater(%play_count%,5,1,0)))))))
$imageabs($sub(%el_width%,100),5,52,9,'./images/kung-foo/rating/set1/r0.png',nokeepaspect,,100)
$imageabs($sub(%el_width%,100),4,52,10,'./images/kung-foo/rating/set2/r'$get(rating)'.png',nokeepaspect,,180)
(without "$if(%el_isplaying%,)")[/code]
Under "Per Second":
- you must delete the "// drawing RATING info"-section ...thats all
Now, you have the automatic rating!
Then i have delete the manual rating buttons.
(I have the manual rating completly removed )
The next problem is the play_count-variable. This variable will not set in the meta-dates.
You need foo_playcount (official) and thats all.
And now...it works fine!
I can upload the changed *.elp-file...who wants.
P.S. O dear, that was a fight, but i have won it.
Hi
Just like to say that this setup is excellent.
I have a small problem with album artwork as shown below
http://img223.imageshack.us/my.php?image=albumartprobln7.jpg (http://img223.imageshack.us/my.php?image=albumartprobln7.jpg)
When i load foobar it doesnt show the cover even though it exists (and shows in other parts of the setup). If i go into the config and alter it, then put it back to what it was the art then shows.
Also, how do you change the font for "Playlist" and "Coverflow" that shows near the top right.
Allow me to begin by thanking you for this truly excellent work. I find the seamless integration of album art remarkable, and the easy tabbed filtering and accessible quick searching especially beneficial. The color scheme also matches well with the default vista theme for the start menu and taskbar.
I do have a couple questions, however, about proper configuration.
(http://img515.imageshack.us/img515/1623/foolj8.th.jpg) (http://img515.imageshack.us/my.php?image=foolj8.jpg)
I am missing the track time (in cyan, bottom left and right corners).
The filters have an opaque gray background, rather than a semi-transparent one.
The title bar ... [EDIT]: I found the solution to this in the Ibiza thread.
If you or other knowledgeable users have an explanation for any of the above, please don't hesitate to post. Thanks!
[EDIT]: The replacement menu bar was intentional; I found the default one somewhat sticky.
Hi,first of all i want to thank you for all of your hard work.I'm new fb2k user and your layout made this player very comfortable to use.
Secondly,i have small but irritable problem.
As the saying goes,"one pic is worth thousand words" so:
(http://img177.imageshack.us/img177/5316/65279604qe9.th.jpg) (http://img177.imageshack.us/my.php?image=65279604qe9.jpg) (http://img405.imageshack.us/img405/4664/92646753yr2.th.jpg) (http://img405.imageshack.us/my.php?image=92646753yr2.jpg) (http://img441.imageshack.us/img441/1108/84129236su6.th.jpg) (http://img441.imageshack.us/my.php?image=84129236su6.jpg)
See how in those marked area end of playlist panel kinda go under the album list panel?
I looked at screenshots of other users but haven't seen anything like that,so i guess problem is at my hand.
Anyway i would like,if possible,to explain me how to make playlist panel look "normal".
Thanks in advance.
[a href="http://img177.imageshack.us/my.php?image=65279604qe9.jpg" target="_blank"]
2. Maybe due to the Windows VS used (theme), check this :
[a href="http://xs135.xs.to/xs135/09040/kung-foo-scrollbar951.png" target="_blank"]
Yup,that did the trick .
Thank you for your swift reply,you helped me a lot.
Looking forward for your future works .
@Jorgo:
Look at this.
[a href="http://s2b.directupload.net/file/d/1691/dygdwqk8_png.htm" target="_blank"]
Edit:
Ok, i fixed the problem -> Right Click an then "View"
I'm a stupid white man...
Great work, thanks
But I also have the problem that the volume button is missing. Do you have an idea why?
Foobar is started directly from it's install folder
(http://www2.picfront.org/picture/2MfpiBHn/thb/kungfoovolumemis.PNG) (http://picfront.org/d/2MfpiBHn/kungfoovolumemis.PNG)
@MasterXXL:
...look at my foobar and then look at your foobar. What is with my Albumlist? Why it looks so...bad? Where are the arrows and so on?
(http://s10b.directupload.net/images/090208/temp/ekika4ms.png) (http://s10b.directupload.net/file/d/1699/ekika4ms_png.htm)
Please help!
You have no arrows,... as symbols in the albumlist because of your windows skin
If you want to have the background of the albumlist in grey (like mine) instead of white:
Rightklick in Albumlist -> Settings -> Advanced -> Appereance -> Use cusom colours -> Background
Click on change
[a href="http://picfront.org/d/0NODnrDH/getcolourchangealbum.PNG" target="_blank"]
[a href="http://picfront.org/d/pj7DTGse/greycolour.PNG" target="_blank"]
I just wondered if anyone is still using this config?
Have you seen Kameleon?
Try to put this as code in a WSH Panel.
Then start draw with the mouse in the panel.
Press:
B to clear the canvas
K to change background
Mousewheel changes size of brush
Arrow keys shift the canvas (up, down, left, right)
var weight_normal =400;
var weight_bold =800;
var italic_no =0;
var italic =1;
var uline_no =0;
var uline =1;
var align_top =0;
var align_middle=1;
var align_bottom=2;
var align_left =0;
var align_center=1;
var align_right =2;
var trim_no =0;
var trim_chara =1;
var trim_word =2;
var trim_elips_chara =3;
var trim_elips_word =4;
var trim_elips_path =5;
var flag_rtl =0x0001;
var flag_vert =0x0002;
var flag_nofit =0x0004;
var flag_dispctrl =0x0020;
var flag_nofallback =0x0400;
var flag_trailspace =0x0800;
var flag_nowrap =0x1000;
var flag_linelimit =0x2000;
var flag_noclip =0x4000;
function StrFmt(alignH,alignV,trim,flag){ return ((alignH<<28)|(alignV<<24)|(trim<<20)|flag); }
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
function RGBA(r,g,b,a){ return ((a<<24)|(r<<16)|(g<<8)|(b)); }
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
var g_font = gdi.Font(-14, weight_bold, italic_no, uline_no, "Segoe UI");
//var g_titlefmt = fb.TitleFormat("%bitrate%");
var g_drag = 0;
var g_pos = new Array();
var g_shift = {x:0, y:0};
var g_size = 5;
var g_key = null;
var g_increment = 10;
var g_bkgnd = 0;
function on_paint(gr){
var start = (new Date).getTime();
var ww = window.Width-1;
var wh = window.Height-1;
var ox = g_shift.x;
var oy = g_shift.y;
switch (g_bkgnd) {
case 0:
gr.FillSolidRect(0, 0, ww, wh, RGB(0,0,0));
break;
case 1:
gr.FillGradRect(0, 0, ww, wh, 45, RGB(0,0,0), RGB(255,255,255));
break;
case 2:
gr.FillGradRect(0, 0, ww, wh, 60, RGB(30,90,10), RGB(200,180,90));
break;
for (var i = 1; i < g_pos.length; i++) {
if (g_pos[i-1].size==0) {continue;}
gr.DrawLine(ox+g_pos[i-1].x, oy+g_pos[i-1].y, ox+g_pos[i].x, oy+g_pos[i].y, g_pos[i].size, RGB(255,10,0));
var diff = (new Date).getTime() - start;
txt = "Number of points: " + g_pos.length + "; Size: " + g_size + "; Key=" + g_key + "; Diff=" + diff;
gr.DrawString(txt, g_font, RGB(255,100,0), 0, 0, ww, 0,
StrFmt(align_left, align_top, trim_no, flag_nowrap|flag_noclip ));
gr.DrawRect(0,0, ww, wh, 1.0, RGB(150,150,150));
function on_size(){
function on_focus(focused){
function on_key_down(key){
g_key = key;
switch (key) {
case 66: g_pos = []; g_shift = {x:0, y:0}; break;
case 37: g_shift.x-=g_increment; break;
case 39: g_shift.x+=g_increment; break;
case 38: g_shift.y-=g_increment; break;
case 40: g_shift.y+=g_increment; break;
case 75: if (g_bkgnd++ > 1) g_bkgnd = 0; break;
window.Repaint();
function on_mouse_lbtn_down(x,y){
g_drag = 1;
//on_mouse_move(x,y);
g_pos.push({x: x-g_shift.x, y: y-g_shift.y, size: 0});
if(g_drag) g_drag = 0;
function on_mouse_move(xpos,ypos){
if(g_drag){
g_pos.push({x: xpos-g_shift.x, y: ypos-g_shift.y, size: g_size});
window.Repaint();
function on_mouse_wheel(delta){
g_size += delta;
if (g_size <=1) g_size = 1;
window.Repaint();
function on_playback_starting(cmd, paused){
function on_playback_new_track(info){
window.Repaint();
function on_playback_stop(){
window.Repaint();
function on_playback_seek(time){
window.Repaint();
function on_playback_pause(state){
function on_playback_edited(){
function on_playback_dynamic_info(){
function on_playback_dynamic_info_track(){
function on_playback_time(time){
window.Repaint();
function on_volume_change(val){
thanx for this tool i'll surely learn something about it
@saivert
Wow, what a funny script
Hello, your style is first-class still if I had there a question. How can I do this while starting always this view is chosen?
(http://img3.imagebanana.com/img/rfuxi0uh/thumb/foobar2000.PNG) (http://img3.imagebanana.com/view/rfuxi0uh/foobar2000.PNG)
And can one change this so available id3 tags cover are indicated and one must not store this separately in a folder?
Hi, Im new to hydro and foobar. I have tried a few other skins, and I must say that this has been my fave so far. I have been tweaking on it a bit (slow going as I know nothing about foobar) and have come to a few speed bumps. Heres my layout atm (after some fumbling around with splitter settings I even got it to open how I wanted..was a glorious revaluation at 3 in the morning ..heh)
layout (http://img.photobucket.com/albums/v159/Wimpy/kungfoo-mytweaks.jpg)
Id like to alter the fonts in these areas (highlighted in white) as they are way to dark for the settings I have on my monitors, but am unsure how to approach it. I don't want explicit instructions as I enjoy the project. Just a guide line to get me started. Do I need a special plug in, alter scripts. Also would like to change the color of the label of the skin (KungFoo).
link2 (http://img.photobucket.com/albums/v159/Wimpy/kungfoo-mytweaks2.jpg)
also is there a way to back up all my settings as it took my a day or so of fumbling around to get this far, and don't want to lose what I have so far (I would like explicit instructions on this )
Thanks a bunch for this great skin and any help anyone has to offer, and if the dev of this skin has any probs with it being altered please let me know and Ill set it back.
Can't answer your font question but to change the color of the label you need to edit that image file. To save your config you can go to preferences - display - Columns UI - main tab and select export fcl.
thanks for the response. thanks for the tip on saving .fcl files. got a back up made. thanks. also figured out the font color change on the kung-foo. was an edit in the script. still having a rough time getting my filter font color brighter.
(http://img13.imageshack.us/img13/5526/heyypq.jpg)
Why are practically none of my buttons shown? Sorry I'm new to plugins in foobar but I'm dumbstruck.
i you're noob to foobar configs, i recommand you try another more simple config before Kung-Foo, coz this one need a lot of settings, more than my other realisations, and it starts to become a little bit outdated now, i do not maintain it anymore.
Thanks for the advice. I'll mess around with the individual dlls first and try to become more familiar with each one.
