Topic: foo_upnp (Read 1655145 times) previous topic - next topic
foo_upnp
Reply #850
Play Internet radio stream in WMA without conversion.
I am trying to stream a WMA radio station from Foobar to a Philips SLA5500. The SLA5500 has no option to play the audio stream directly from the Internet.
foo_upnp does a nice job, but it converts the WMA stream to either MP3, WAV, or LPCM, depending on the settings in the streaming profile.
I want it to pass the WMA directly on to the SLA5500.
When I play the stream locally in Foobar it just plays the WMA without conversion.
The stream I am trying to play is http://vista.streamguys.com/galwaybayfm?MSWMExt=.asf
Any suggestions?
foo_upnp
Reply #851
Any suggestions?
There's an option for that. In the streaming profile you are using enable "Can decode HTTP and MMS streams directly". This will just pass the radio streaming URL to your device for direct streaming.
foo_upnp
Reply #852
bubbleguuum,
BIG EDIT:  I ripped WAV files and can stream them directly to a Denon AVR-4806CI with Windows Media Player.  Using foo_upnp, within the streaming profiles "Decode to PCM" section I have to select Decode: Always for the receiver to play the files.  It doesn't matter whether I select WAV or LPCM, however.
Is your software doing anything to the file when Decode: Always is selected?  Meaning, is it decoding/reencoding my WAV files?  Or is it just streaming them to my receiver?
It is decoding the files (whatever their format is) to PCM (WAV or LPCM) for streaming, just like foobar2000 would do to send data to your audio card. So there's no loss of quality. So if it works you can stick with that.
Thanks, I found that the LPCM sounded better so perhaps it's taking the decoding load off of my receiver
foo_upnp
Reply #853
24bit/96khz or higher playback.
Hi
I have an external DAC connected (Firewire). I can play bit perfect and also music with higher sample rates (48,96 etc) and resolution (24 Bit).
As soon as  I play such a HiRes music file the sample rate is switched it self what I can see it on the control window of the firewire dac driver.
When I play the file with the upnp renderer, controlled by PlugPlayer on my Ipad, the sample rate is not switched, it stays at 44khz.
I tried to change the sample rate range on foo_upnp settings. But it didn't solved the problem.
Is ther a solution for this ?
Regards
Beat
My system
Apple Mini running windows7 Pro 32Bit.
foobar2000 v1.0.3 with WASAPI Driver, latest foo_upnp version
Weiss Minerva DAC
foo_upnp
Reply #854
You must change the min and max samplerate in the PlugPlayer streaming profile (in the Renderer Capabilities section), to match the
supported samplerate of your DAC.
but then you won't be able to play hires files on your iPad if you ever want to do that, because it won't resample to a compatible samplerate.
This is a known limitation/problem of profiles when the client (PlugPlayer) acts as a  pure Control Point.
foo_upnp
Reply #855
Thank
It does not work. It always stays at 44.1kHz or switches to 44.1kHz when Iset it manually to 96kHz.
And sometimes I get following error message:
Unable to open item for playback (File Not Found (404)):
"http://192.168.1.57:56923/content/24101c43da30d18be83f4af037eb527d.mp3?profile_id=2&convert=mp3"
Regards
Beat
foo_upnp
Reply #856
Thank
Regards
Beat
Your file (I assume a hires FLAC) is getting transcoded to mp3 by the PlugPlayer profile.
Copy every setting of the foobar2000 profile into the PlugPlayer profile'except the "Use profile when" line.
foo_upnp
Reply #857
I just wanted to randomly give thanks to anyone and everyone who has had a part in making the UPnP plugin what it is. I *love* having access to my music library on my PS3, on my fb2k install at work, and on the road. Thanks also to the PlugPlayer folks. Yay for convenience!
foo_upnp
Reply #858
Hi.
first, thanks for this great plugin!
there is a free application by spoon (dBpoweramp), that recognizes (password unprotected) apple airport devices in the network and implements an automated upnp-device: Air Upnp. If you run this service, you can easily control your airport express via foo_upnp. I was able to playback single files and playlists, but whenever is tried to playback the "screen capture", it crashes (not foobar, but the connection to the upnp device).
i have 2 logfiles (logfile 1, logfile 2), maybe this may help to find the solution.
a second issue comes with that: how do i enable straming profiles? i want to activate a certain profile whenever the device contains "dBpoweramp Renaissance". but as far as i understood the settings dialog (and the logfiles) this is not covered by "Use profile when User-Agent contain XYZ". "device" instead of "User-Agent" does not solve this, too. what am i doing wrong?
thank you.
foo_upnp
Reply #859
Hi.
Can you try playing some track in foobar200 first (using regular fb playback controls), then triggering PSC play in the UPnP Controller ?
If you do it the other way around, it is possible Air UPnP close the connection early because there's no data.
I also suggest you try configuring PSC to stream as LPCM in the Default profile.
If none of the above work, post a log with INFO level (see first post for instructions on how to enable)
Enable logging with INFO level. For each HTTP request, it will display the User-Agent of Air UPnP that you can use to create a profile
foo_upnp
Reply #860
Hires Playback by renderer.
The copy of the settings worked.
Thanks Beat.
foo_upnp
Reply #861
here is the log file: http://pastebin.com/tQGirun4 (crash after fb was playing and i triggered the stream playback)
i got the user agent string and created a new profile, but it was not selected properly (this is a small part of the above logfile)
107.465: upnp_server_conf::get_profile(699)/6420: INFO: using profile 'dBpoweramp Renaissance' (User-Agent:dBpoweramp)
opened 'Playback Stream Capture' for streaming, profile: Default, WAV / 44100 Hz / 16 bits / 2 channels, replaygain: off, DSP chain: off
if i add lpcm to default profile though my other profile should be used, i get the same error (log: http://pastebin.com/1n2mt0E3)
67.318: upnp_server_conf::get_profile(699)/5396: INFO: using profile 'dBpoweramp Renaissance' (User-Agent:dBpoweramp)
opened 'Playback Stream Capture' for streaming, profile: Default, LPCM / 44100 Hz / 16 bits / 2 channels, replaygain: off, DSP chain: off
thanks in advance...
foo_upnp
Reply #862
Indeed, the User-Agent is of no use to the Controller to identify a renderer. The renderer's  manufacturer or model name can be used instead.
The manufacturer should be Illustrate so modify the line to read :
Use profile when <leave empty> contains Illustrate
In the log you posted it seems you didn't have a file playing in foobar2000, prior to hitting the Play PBS button of the Controller.
Can you try that ?
foo_upnp
Reply #863
Can you try that ?
weird.
streaming is also aborted when playing normal files (not the current foobar stream). so its not a problem of screen capturing. sometimes it takes 2 seconds playing until stopping, sometimes 15.
i do the following: start normal playback, select device, add file to upnp controller queue (normal file or screen capture), hit play pbs putton. depending on chance*, playback starts and stops after a few* seconds
the  log is here: http://pastebin.com/A91rMJP4
(* sorry, for this unclear description. i know this doesn't help that much)
foo_upnp
Reply #864
First off, I love this plug-in. Thank you, so much, Bubbleguuum!!!
I do have a few questions though.
Here are the versions of the software for both of my PCs:
FB: 1.0.3
UpuP: 0.99.27
XP, SP3
1) I noticed on a screenshot (message #779) of another users controller UI, there were files listed under the control buttons and the currently playing line. Mine is just blank open space under those 2 items. I use DUI, and I have a large corner of my screen setup with multiple tabs (playlist, folders, console, controller, browser, etc.). Should there be a list or playlist under there or is this just that users config?
2) I stumbled upon an odd behavior, while testing for files being passed unmodified between my old laptop and main rig. I had earlier been testing the laptop as a renderer with the main rig being the server and controller. That worked fine and I stopped those tests. Next, I was testing the laptop as a client, pulling songs from the main rig. That also worked fine, but when I would stop the song playing on the laptop from the browser, the controller on the main rig would start pushing songs from the controller playback queue to the laptop. During my testing yesterday, I had always cleared the playback queue after tests, but this morning, I had left some songs in the queue. Is this automatically starting to play the playback queue normal, when a client’s playback is stopped?
Neither of these are showstoppers, just curious. Thank you, again, sir.
Watch out were the huskies go and don't you eat that yellow snow! - F. Zappa
foo_upnp
Reply #865
I too am very happy with this plugin and have several SMC renderers around the house.  I stream radio, Sirius and files to several units.
However I am having a problem recently with flac file streaming and it is intermittent.  The song will play and then stop completely for several seconds before jumping to the next song.  I am not transcoding lossless, but am decoding to WAV.
Software - Windows 7, foobar2000 1.1b ( but the problem happened in 1.03), foo_upnp 0.99.27
I have solid network performance.  I have also made some changes on this Windows 7 latpop to optimize USB drive performanc and reduce latency.  Average DPC Latency 400 to 500 usec.
I am getting these types of error messages in the console:
foo_upnp: 3603.930: PLT_HttpServerSocketTask::Write(331)/4288: WARNING: NPT_CHECK failed, result=-20400 (NPT_ERROR_CONNECTION_RESET) [(NPT_StreamToStreamCopy( *body_stream.AsPointer(), *output_stream.AsPointer(), 0, entity->GetContentLength(), 0, abort))]
Any help you can offer will be appreciated.
More Detail
foo_upnp: 2986.716: PLT_Service::ProcessRenewSubscription(636)/4928: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 2989.134: FbMediaServer::ProcessHttpRequest(285)/5320: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 2989.135: PLT_Service::ProcessRenewSubscription(636)/5320: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 2999.655: FbMediaServer::ProcessHttpRequest(285)/636: INFO: received LAN request: [url=http://192.168.1.166:56923/DeviceDescription.xml]http://192.168.1.166:56923/DeviceDescription.xml[/url] (User-Agent: Opera/9.80 (Windows NT 6.1; U; en) Presto/2.6.30 Version/10.60)
foo_upnp: 2999.655: FbMediaServer::ProcessGetDescription(354)/636: INFO: ProcessGetDescription: user-agent: Opera/9.80 (Windows NT 6.1; U; en) Presto/2.6.30 Version/10.60
foo_upnp: 3007.739: FbMediaServer::ProcessHttpRequest(285)/3556: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3007.740: PLT_Service::ProcessRenewSubscription(636)/3556: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3010.157: FbMediaServer::ProcessHttpRequest(285)/5516: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3010.158: PLT_Service::ProcessRenewSubscription(636)/5516: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3028.774: FbMediaServer::ProcessHttpRequest(285)/4380: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3028.775: PLT_Service::ProcessRenewSubscription(636)/4380: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3031.185: FbMediaServer::ProcessHttpRequest(285)/4972: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3031.186: PLT_Service::ProcessRenewSubscription(636)/4972: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3049.796: FbMediaServer::ProcessHttpRequest(285)/4212: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3049.797: PLT_Service::ProcessRenewSubscription(636)/4212: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3052.249: FbMediaServer::ProcessHttpRequest(285)/4000: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3052.250: PLT_Service::ProcessRenewSubscription(636)/4000: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3070.832: FbMediaServer::ProcessHttpRequest(285)/5452: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3070.833: PLT_Service::ProcessRenewSubscription(636)/5452: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3073.272: FbMediaServer::ProcessHttpRequest(285)/4964: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3073.273: PLT_Service::ProcessRenewSubscription(636)/4964: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3091.863: FbMediaServer::ProcessHttpRequest(285)/1624: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3091.864: PLT_Service::ProcessRenewSubscription(636)/1624: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3094.298: FbMediaServer::ProcessHttpRequest(285)/4880: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3094.300: PLT_Service::ProcessRenewSubscription(636)/4880: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3112.892: FbMediaServer::ProcessHttpRequest(285)/1872: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3112.892: PLT_Service::ProcessRenewSubscription(636)/1872: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3115.329: FbMediaServer::ProcessHttpRequest(285)/5268: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3115.330: PLT_Service::ProcessRenewSubscription(636)/5268: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3133.924: FbMediaServer::ProcessHttpRequest(285)/2140: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3133.925: PLT_Service::ProcessRenewSubscription(636)/2140: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3136.349: FbMediaServer::ProcessHttpRequest(285)/5860: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3136.349: PLT_Service::ProcessRenewSubscription(636)/5860: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3153.304: FbMediaServer::ProcessHttpRequest(285)/4840: INFO: received LAN request: [url=http://192.168.1.166:56923/ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/ContentDirector...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3153.305: PLT_Service::ProcessRenewSubscription(636)/4840: INFO: Renewed subscrption for ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:e10dd763-dbf9-4dcf-0d80-04f740312fd5)
foo_upnp: 3154.955: FbMediaServer::ProcessHttpRequest(285)/5496: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3154.956: PLT_Service::ProcessRenewSubscription(636)/5496: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3156.142: FbMediaServer::ProcessHttpRequest(285)/4948: INFO: received LAN request: [url=http://192.168.1.166:56923/ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/ContentDirector...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3156.143: PLT_Service::ProcessRenewSubscription(636)/4948: INFO: Renewed subscrption for ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:7314ad64-efbb-405e-8765-9967c4541bf9)
foo_upnp: 3157.368: FbMediaServer::ProcessHttpRequest(285)/3556: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3157.368: PLT_Service::ProcessRenewSubscription(636)/3556: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: submitted statistics for 'file://E:\FLAC\Alan Parsons Project\The Turn Of A Friendly Card\05 - The Gold Bug.flac'
foo_upnp: 3168.489: FbMediaServer::ProcessHttpRequest(285)/4288: INFO: received LAN request: [url=http://192.168.1.166:56923/content/2571c5f148ec5511b80ca7a15a24e72a.wav?profile_id=0&convert=wav]http://192.168.1.166:56923/content/2571c5f...amp;convert=wav[/url] (User-Agent: WinampMPEG/2.8)
foo_upnp: 3168.490: PLT_HttpHelper::ToLog(409)/4288: INFO:
GET /content/2571c5f148ec5511b80ca7a15a24e72a.wav?profile_id=0&convert=wav HTTP/1.1
Host: 192.168.1.166:56923
Icy-MetaData: 1
Connection: close
Accept: */*
foo_upnp: 3168.495: upnp_server_conf::get_profile(705)/4288: INFO: using default profile (User-Agent:WinampMPEG/2.8)
foo_upnp: opened 'file://E:\FLAC\Alan Parsons Project\The Turn Of A Friendly Card\06 - The Turn Of A Friendly Card.flac' for streaming, profile: Default, WAV / 44100 Hz / 16 bits / 2 channels, replaygain: off, DSP chain: off
foo_upnp: 3175.980: FbMediaServer::ProcessHttpRequest(285)/1172: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3175.981: PLT_Service::ProcessRenewSubscription(636)/1172: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3178.392: FbMediaServer::ProcessHttpRequest(285)/4380: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3178.393: PLT_Service::ProcessRenewSubscription(636)/4380: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3197.008: FbMediaServer::ProcessHttpRequest(285)/4312: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3197.009: PLT_Service::ProcessRenewSubscription(636)/4312: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3199.415: FbMediaServer::ProcessHttpRequest(285)/4100: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3199.415: PLT_Service::ProcessRenewSubscription(636)/4100: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3218.036: FbMediaServer::ProcessHttpRequest(285)/4164: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3218.036: PLT_Service::ProcessRenewSubscription(636)/4164: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3220.440: FbMediaServer::ProcessHttpRequest(285)/5048: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3220.441: PLT_Service::ProcessRenewSubscription(636)/5048: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3239.066: FbMediaServer::ProcessHttpRequest(285)/6040: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3239.067: PLT_Service::ProcessRenewSubscription(636)/6040: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3241.462: FbMediaServer::ProcessHttpRequest(285)/1872: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3241.463: PLT_Service::ProcessRenewSubscription(636)/1872: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3260.112: FbMediaServer::ProcessHttpRequest(285)/3552: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3260.113: PLT_Service::ProcessRenewSubscription(636)/3552: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3262.485: FbMediaServer::ProcessHttpRequest(285)/5892: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3262.485: PLT_Service::ProcessRenewSubscription(636)/5892: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3281.212: FbMediaServer::ProcessHttpRequest(285)/4948: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3281.213: PLT_Service::ProcessRenewSubscription(636)/4948: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3283.505: FbMediaServer::ProcessHttpRequest(285)/3556: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3283.506: PLT_Service::ProcessRenewSubscription(636)/3556: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3302.248: FbMediaServer::ProcessHttpRequest(285)/5668: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3302.249: PLT_Service::ProcessRenewSubscription(636)/5668: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3304.527: FbMediaServer::ProcessHttpRequest(285)/5232: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3304.527: PLT_Service::ProcessRenewSubscription(636)/5232: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3323.274: FbMediaServer::ProcessHttpRequest(285)/4212: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3323.275: PLT_Service::ProcessRenewSubscription(636)/4212: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3325.550: FbMediaServer::ProcessHttpRequest(285)/5988: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3325.551: PLT_Service::ProcessRenewSubscription(636)/5988: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3344.311: FbMediaServer::ProcessHttpRequest(285)/4232: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3344.312: PLT_Service::ProcessRenewSubscription(636)/4232: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3346.570: FbMediaServer::ProcessHttpRequest(285)/5780: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3346.571: PLT_Service::ProcessRenewSubscription(636)/5780: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3365.349: FbMediaServer::ProcessHttpRequest(285)/5140: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3365.350: PLT_Service::ProcessRenewSubscription(636)/5140: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3367.592: FbMediaServer::ProcessHttpRequest(285)/6024: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3367.593: PLT_Service::ProcessRenewSubscription(636)/6024: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3378.328: FbMediaServer::ProcessHttpRequest(285)/5072: INFO: received LAN request: [url=http://192.168.1.166:56923/ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/ContentDirector...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3378.329: PLT_Service::ProcessRenewSubscription(636)/5072: INFO: Renewed subscrption for ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:e10dd763-dbf9-4dcf-0d80-04f740312fd5)
foo_upnp: 3381.180: FbMediaServer::ProcessHttpRequest(285)/1820: INFO: received LAN request: [url=http://192.168.1.166:56923/ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/ContentDirector...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3381.181: PLT_Service::ProcessRenewSubscription(636)/1820: INFO: Renewed subscrption for ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:7314ad64-efbb-405e-8765-9967c4541bf9)
foo_upnp: 3386.379: FbMediaServer::ProcessHttpRequest(285)/4956: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3386.380: PLT_Service::ProcessRenewSubscription(636)/4956: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3388.613: FbMediaServer::ProcessHttpRequest(285)/5144: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3388.614: PLT_Service::ProcessRenewSubscription(636)/5144: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3407.414: FbMediaServer::ProcessHttpRequest(285)/5256: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3407.415: PLT_Service::ProcessRenewSubscription(636)/5256: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3409.636: FbMediaServer::ProcessHttpRequest(285)/5988: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3409.638: PLT_Service::ProcessRenewSubscription(636)/5988: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3428.463: FbMediaServer::ProcessHttpRequest(285)/2432: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3428.464: PLT_Service::ProcessRenewSubscription(636)/2432: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3430.657: FbMediaServer::ProcessHttpRequest(285)/5048: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3430.658: PLT_Service::ProcessRenewSubscription(636)/5048: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3449.493: FbMediaServer::ProcessHttpRequest(285)/5644: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3449.493: PLT_Service::ProcessRenewSubscription(636)/5644: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3451.677: FbMediaServer::ProcessHttpRequest(285)/3292: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3451.678: PLT_Service::ProcessRenewSubscription(636)/3292: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3470.516: FbMediaServer::ProcessHttpRequest(285)/4448: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3470.517: PLT_Service::ProcessRenewSubscription(636)/4448: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3472.699: FbMediaServer::ProcessHttpRequest(285)/5988: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3472.700: PLT_Service::ProcessRenewSubscription(636)/5988: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3491.548: FbMediaServer::ProcessHttpRequest(285)/5748: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3491.549: PLT_Service::ProcessRenewSubscription(636)/5748: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3493.724: FbMediaServer::ProcessHttpRequest(285)/5348: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3493.725: PLT_Service::ProcessRenewSubscription(636)/5348: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3499.202: FbMediaServer::ProcessHttpRequest(285)/4676: INFO: received LAN request: [url=http://192.168.1.166:56923/DeviceDescription.xml]http://192.168.1.166:56923/DeviceDescription.xml[/url] (User-Agent: Opera/9.80 (Windows NT 6.1; U; en) Presto/2.6.30 Version/10.60)
foo_upnp: 3499.202: FbMediaServer::ProcessGetDescription(354)/4676: INFO: ProcessGetDescription: user-agent: Opera/9.80 (Windows NT 6.1; U; en) Presto/2.6.30 Version/10.60
foo_upnp: 3512.578: FbMediaServer::ProcessHttpRequest(285)/5824: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3512.579: PLT_Service::ProcessRenewSubscription(636)/5824: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3514.746: FbMediaServer::ProcessHttpRequest(285)/5816: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3514.746: PLT_Service::ProcessRenewSubscription(636)/5816: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3533.607: FbMediaServer::ProcessHttpRequest(285)/4440: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3533.608: PLT_Service::ProcessRenewSubscription(636)/4440: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3535.767: FbMediaServer::ProcessHttpRequest(285)/5192: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3535.768: PLT_Service::ProcessRenewSubscription(636)/5192: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3554.634: FbMediaServer::ProcessHttpRequest(285)/5860: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3554.635: PLT_Service::ProcessRenewSubscription(636)/5860: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3556.789: FbMediaServer::ProcessHttpRequest(285)/1324: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3556.789: PLT_Service::ProcessRenewSubscription(636)/1324: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3575.656: FbMediaServer::ProcessHttpRequest(285)/4160: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3575.657: PLT_Service::ProcessRenewSubscription(636)/4160: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3577.808: FbMediaServer::ProcessHttpRequest(285)/676: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3577.809: PLT_Service::ProcessRenewSubscription(636)/676: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3596.684: FbMediaServer::ProcessHttpRequest(285)/6168: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3596.685: PLT_Service::ProcessRenewSubscription(636)/6168: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3598.827: FbMediaServer::ProcessHttpRequest(285)/6172: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3598.828: PLT_Service::ProcessRenewSubscription(636)/6172: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp: 3603.352: FbMediaServer::ProcessHttpRequest(285)/6200: INFO: received LAN request: [url=http://192.168.1.166:56923/ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/ContentDirector...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3603.353: PLT_Service::ProcessRenewSubscription(636)/6200: INFO: Renewed subscrption for ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:e10dd763-dbf9-4dcf-0d80-04f740312fd5)
foo_upnp: 3606.233: FbMediaServer::ProcessHttpRequest(285)/6212: INFO: received LAN request: [url=http://192.168.1.166:56923/ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/ContentDirector...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3606.234: PLT_Service::ProcessRenewSubscription(636)/6212: INFO: Renewed subscrption for ContentDirectory/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:7314ad64-efbb-405e-8765-9967c4541bf9)
foo_upnp: 3617.705: FbMediaServer::ProcessHttpRequest(285)/6244: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3617.706: PLT_Service::ProcessRenewSubscription(636)/6244: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:f1c933ab-9087-3087-bb48-195587292d6f)
foo_upnp: 3619.855: FbMediaServer::ProcessHttpRequest(285)/6248: INFO: received LAN request: [url=http://192.168.1.166:56923/X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml]http://192.168.1.166:56923/X_MS_MediaRecei...b6860/event.xml[/url] (User-Agent: Unknown)
foo_upnp: 3619.856: PLT_Service::ProcessRenewSubscription(636)/6248: INFO: Renewed subscrption for X_MS_MediaReceiverRegistrar/b77a1e11-438d-2e25-f173-0dd887cb6860/event.xml (sub=uuid:3bd47653-7e2c-0e5a-c50a-8b9a88d1a270)
foo_upnp
Reply #866
I cannot figure out how to edit my previous post.
I reinstalled foobar2000 1.0.3 and now the flac streaming problem is solved.  I have heard a couple gaps in about 90 minutes of listening, but the song always picks up where it left off.  And I am browsing constantly.
Just FYI - I had drop out problems with streaming internet radio stations to the renderers using foo_upnp.  I solved this by transcoding everything to mp3 ( except lossless, which I decode to WAV).  I guess the transcoding takes care of any buffering problems so the internet radio stations play continuously.
Thanks again for a splendid piece of software!
foo_upnp
Reply #867
Are you streaming using wifi ? wifi is very hit and miss for streaming especially the higher  the required bandwidth is.
When it works reliably you're lucky but generally going wired is way more reliable.
foo_upnp
Reply #868
It's just a custom user layout with the playlist manager below the Controller.
The Controller will instruct the renderer to play next song from the UPnP Playback Queue when it gets a stop event. Usually this happen automatically when the renderer finishes playing a track but you can also trigger it manually if you stop playback on the renderer.
foo_upnp
Reply #869
When using playback stream capture there's no need to add anything the the upnp controller queue as PBS stream what foobar2000 is currently playing as a continuous stream.
foo_upnp
Reply #870
both, screen capture and normal playback fails. maybe it's also a wifi problem...
foo_upnp
Reply #871
Still happening...
I am now getting this error on foobar2000 startup.
foo_upnp: 5.320: PLT_HttpTcpConnector::Connect(86)/3120: FATAL: NPT_CHECK failed, result=-1 (FAILURE) [(m_Socket->Connect(socket_address, connection_timeout))]
foo_upnp: 5.357: PLT_HttpTcpConnector::Connect(86)/2336: FATAL: NPT_CHECK failed, result=-1 (FAILURE) [(m_Socket->Connect(socket_address, connection_timeout))]
foo_upnp: 5.451: PLT_HttpTcpConnector::Connect(86)/2060: FATAL: NPT_CHECK failed, result=-1 (FAILURE) [(m_Socket->Connect(socket_address, connection_timeout))]
Here is all level log:
foo_upnp: 4.469: PLT_HttpHelper::ToLog(409)/4052: FINER:
GET / HTTP/1.1
User-Agent: Windows Media Player Network Sharing Service/1.0
Host: 5.139.8.151:53301
Connection: Keep-Alive
foo_upnp: 4.469: PLT_DeviceHost::ProcessHttpRequest(376)/4052: FINER: PLT_DeviceHost Received Request:
GET / HTTP/1.1
foo_upnp: 4.470: PLT_DeviceHost::ProcessGetDescription(422)/4052: FINEST: Returning description to 5.199.216.40: <?xml version="1.0" encoding="UTF-8"?>
<root xmlns="urn:schemas-upnp-org:device-1-0" xmlns:dlna="urn:schemas-dlna-org:device-1-0"><specVersion><major>1</major><minor>0</minor></specVersion><device><deviceType>urn:schemas-upnp-org:device:MediaRenderer:1</deviceType><friendlyName>foobar2000 Renderer (Will)</friendlyName><manufacturer>Michael Pujos</manufacturer><manufacturerURL>http://www.hydrogenaudio.org/forums/index.php?showtopic=69664</manufacturerURL><modelDescription>foobar2000 Media Renderer</modelDescription><modelName>foobar2000 Media Renderer</modelName><modelURL>http://www.hydrogenaudio.org/forums/index.php?showtopic=69664</modelURL><modelNumber>0.99.24</modelNumber><serialNumber></serialNumber><UDN>uuid:8d704038-586e-8143-d86f-ac1b68a877fd</UDN><dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMR-1.50</dlna:X_DLNADOC><iconList><icon><mimetype>image/jpeg</mimetype><width>48</width><height>48</height><depth>24</depth><url>/images/foobar2000-48x48.jpg</url></icon><icon><mimetype>image/png</mimetype><width>48</width><height>48</height><depth>24</depth><url>/images/foobar2000-48x48.png</url></icon></iconList><serviceList><service><serviceType>urn:schemas-upnp-org:service:AVTransport:1</serviceType><serviceId>urn:upnp-org:serviceId:AVTransport</serviceId><SCPDURL>/AVTransport/8d704038-586e-8143-d86f-ac1b68a877fd/scpd.xml</SCPDURL><controlURL>/AVTransport/8d704038-586e-8143-d86f-ac1b68a877fd/control.xml</controlURL><eventSubURL>/AVTransport/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml</eventSubURL></service><service><serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType><serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId><SCPDURL>/ConnectionManager/8d704038-586e-8143-d86f-ac1b68a877fd/scpd.xml</SCPDURL><controlURL>/ConnectionManager/8d704038-586e-8143-d86f-ac1b68a877fd/control.xml</controlURL><eventSubURL>/ConnectionManager/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml</eventSubURL></service><service><serviceType>urn:schemas-upnp-org:service:RenderingControl:1</serviceType><serviceId>urn:upnp-org:serviceId:RenderingControl</serviceId><SCPDURL>/RenderingControl/8d704038-586e-8143-d86f-ac1b68a877fd/scpd.xml</SCPDURL><controlURL>/RenderingControl/8d704038-586e-8143-d86f-ac1b68a877fd/control.xml</controlURL><eventSubURL>/RenderingControl/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml</eventSubURL></service></serviceList></device></root>
foo_upnp: 4.470: PLT_HttpServerSocketTask::Write(305)/4052: FINER: PLT_HttpServerTask Sending response:
foo_upnp: 4.470: PLT_HttpHelper::ToLog(495)/4052: FINER:
HTTP/1.1 200 OK
Server: Platinum/0.5.4.0
Content-Length: 2423
Content-Type: text/xml; charset="utf-8"
Connection: keep-alive
foo_upnp: 4.470: NPT_HttpHeader::Emit(118)/4052: FINEST: header Server: Platinum/0.5.4.0
foo_upnp: 4.470: NPT_HttpHeader::Emit(118)/4052: FINEST: header Content-Length: 2423
foo_upnp: 4.470: NPT_HttpHeader::Emit(118)/4052: FINEST: header Content-Type: text/xml; charset="utf-8"
foo_upnp: 4.470: NPT_HttpHeader::Emit(118)/4052: FINEST: header Connection: keep-alive
foo_upnp: 4.470: PLT_HttpServerSocketTask::Write(319)/4052: FINER: keep_alive = true, headers_only = false
foo_upnp: 4.470: PLT_HttpServerSocketTask::Write(324)/4052: FINER: NPT_StreamToStreamCopy begin
foo_upnp: 4.470: PLT_HttpServerSocketTask::Write(332)/4052: FINER: NPT_StreamToStreamCopy end
foo_upnp: 4.474: PLT_HttpServerSocketTask::Write(305)/2480: FINER: PLT_HttpServerTask Sending response:
foo_upnp: 4.474: PLT_HttpHelper::ToLog(495)/2480: FINER:
HTTP/1.1 200 OK
Connection: close
foo_upnp: 4.474: NPT_HttpHeader::Emit(118)/2480: FINEST: header Server: Platinum/0.5.4.0
foo_upnp: 4.474: NPT_HttpHeader::Emit(118)/2480: FINEST: header Connection: close
foo_upnp: 4.474: PLT_HttpServerSocketTask::Write(319)/2480: FINER: keep_alive = false, headers_only = false
foo_upnp: 4.483: NPT_Win32Thread::Start(483)/2748: FINER: creating thread
foo_upnp: 4.483: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/2748: FINE: current http task count = 8
foo_upnp: 4.484: NPT_Win32Thread::EntryPoint(450)/3272: FINER: thread in =======================
foo_upnp: 4.484: NPT_HttpRequest::Parse(592)/3272: FINEST: http request: UNSUBSCRIBE /RenderingControl/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml HTTP/1.1
foo_upnp: 4.484: NPT_HttpHeaders::Parse(185)/3272: FINEST: header - Cache-Control: no-cache
foo_upnp: 4.484: NPT_HttpHeaders::Parse(185)/3272: FINEST: header - Connection: Close
foo_upnp: 4.484: NPT_HttpHeaders::Parse(185)/3272: FINEST: header - Pragma: no-cache
foo_upnp: 4.484: NPT_HttpHeaders::Parse(185)/3272: FINEST: header - User-Agent: Microsoft-Windows/6.1 UPnP/1.0
foo_upnp: 4.484: NPT_HttpHeaders::Parse(185)/3272: FINEST: header - SID: uuid:88d1a270-8518-27ab-bc87-3801544e13c8
foo_upnp: 4.484: NPT_HttpHeaders::Parse(215)/3272: FINEST: header Host: 5.139.8.151:53301
foo_upnp: 4.484: PLT_HttpServer::ProcessHttpRequest(142)/3272: FINE: Received UNSUBSCRIBE Request from 5.243.250.36 for /RenderingControl/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml
foo_upnp: 4.484: PLT_HttpHelper::ToLog(409)/3272: FINER:
Connection: Close
Pragma: no-cache
foo_upnp: 4.484: PLT_DeviceHost::ProcessHttpRequest(376)/3272: FINER: PLT_DeviceHost Received Request:
Connection: Close
Pragma: no-cache
foo_upnp: 4.484: PLT_Service::ProcessCancelSubscription(664)/3272: INFO: Cancelling subscription for RenderingControl/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml (sub=uuid:88d1a270-8518-27ab-bc87-3801544e13c8)
foo_upnp: 4.484: PLT_EventSubscriber::~PLT_EventSubscriber(69)/3272: FINE: Deleting subscriber (uuid:88d1a270-8518-27ab-bc87-3801544e13c8)
foo_upnp: 4.491: PLT_HttpServerSocketTask::Write(305)/2356: FINER: PLT_HttpServerTask Sending response:
foo_upnp: 4.491: PLT_HttpHelper::ToLog(495)/2356: FINER:
HTTP/1.1 200 OK
Connection: close
foo_upnp: 4.491: NPT_HttpHeader::Emit(118)/2356: FINEST: header Server: Platinum/0.5.4.0
foo_upnp: 4.491: NPT_HttpHeader::Emit(118)/2356: FINEST: header Connection: close
foo_upnp: 4.491: PLT_HttpServerSocketTask::Write(319)/2356: FINER: keep_alive = false, headers_only = false
foo_upnp: 4.502: NPT_HttpClient::SendRequestOnce(1007)/736: FINE: requesting URL [url=http://192.168.1.194:2869/upnp/eventing/faupfcujvv]http://192.168.1.194:2869/upnp/eventing/faupfcujvv[/url]
foo_upnp: 4.502: NPT_HttpClient::SendRequestOnce(1038)/736: FINER: connecting to 192.168.1.194:2869
foo_upnp: 4.502: PLT_HttpTcpConnector::Connect(81)/736: FINER: NPT_HttpTcpConnector::Connect - will connect to 192.168.1.194:2869
foo_upnp: 4.531: PLT_HttpServerSocketTask::Write(305)/3272: FINER: PLT_HttpServerTask Sending response:
foo_upnp: 4.531: PLT_HttpHelper::ToLog(495)/3272: FINER:
HTTP/1.1 200 OK
Connection: close
foo_upnp: 4.531: NPT_HttpHeader::Emit(118)/3272: FINEST: header Server: Platinum/0.5.4.0
foo_upnp: 4.531: NPT_HttpHeader::Emit(118)/3272: FINEST: header Connection: close
foo_upnp: 4.531: PLT_HttpServerSocketTask::Write(319)/3272: FINER: keep_alive = false, headers_only = false
foo_upnp: 4.585: NPT_HttpClient::SendRequestOnce(1007)/2176: FINE: requesting URL [url=http://192.168.1.194:2869/upnp/eventing/gbvxzqjcbf]http://192.168.1.194:2869/upnp/eventing/gbvxzqjcbf[/url]
foo_upnp: 4.585: NPT_HttpClient::SendRequestOnce(1038)/2176: FINER: connecting to 192.168.1.194:2869
foo_upnp: 4.585: PLT_HttpTcpConnector::Connect(81)/2176: FINER: NPT_HttpTcpConnector::Connect - will connect to 192.168.1.194:2869
foo_upnp: 4.798: NPT_Win32Thread::Start(483)/2748: FINER: creating thread
foo_upnp: 4.798: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/2748: FINE: current http task count = 7
foo_upnp: 4.799: NPT_Win32Thread::EntryPoint(450)/1860: FINER: thread in =======================
foo_upnp: 4.799: NPT_HttpRequest::Parse(592)/1860: FINEST: http request: UNSUBSCRIBE /AVTransport/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml HTTP/1.1
foo_upnp: 4.799: NPT_HttpHeaders::Parse(185)/1860: FINEST: header - Cache-Control: no-cache
foo_upnp: 4.799: NPT_HttpHeaders::Parse(185)/1860: FINEST: header - Connection: Close
foo_upnp: 4.799: NPT_HttpHeaders::Parse(185)/1860: FINEST: header - Pragma: no-cache
foo_upnp: 4.799: NPT_HttpHeaders::Parse(185)/1860: FINEST: header - User-Agent: Microsoft-Windows/6.1 UPnP/1.0
foo_upnp: 4.799: NPT_HttpHeaders::Parse(185)/1860: FINEST: header - SID: uuid:5232a69c-b9e3-9616-8287-2c0fc6229a75
foo_upnp: 4.799: NPT_HttpHeaders::Parse(215)/1860: FINEST: header Host: 192.168.1.125:53301
foo_upnp: 4.799: PLT_HttpServer::ProcessHttpRequest(142)/1860: FINE: Received UNSUBSCRIBE Request from 192.168.1.194 for /AVTransport/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml
foo_upnp: 4.799: PLT_HttpHelper::ToLog(409)/1860: FINER:
Connection: Close
Pragma: no-cache
foo_upnp: 4.799: PLT_DeviceHost::ProcessHttpRequest(376)/1860: FINER: PLT_DeviceHost Received Request:
Connection: Close
Pragma: no-cache
foo_upnp: 4.799: PLT_Service::ProcessCancelSubscription(664)/1860: INFO: Cancelling subscription for AVTransport/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml (sub=uuid:5232a69c-b9e3-9616-8287-2c0fc6229a75)
foo_upnp: 4.799: PLT_EventSubscriber::~PLT_EventSubscriber(69)/1860: FINE: Deleting subscriber (uuid:5232a69c-b9e3-9616-8287-2c0fc6229a75)
foo_upnp: 4.800: PLT_HttpTcpConnector::Connect(86)/2308: FATAL: NPT_CHECK failed, result=-1 (FAILURE) [(m_Socket->Connect(socket_address, connection_timeout))]
foo_upnp: 4.800: NPT_HttpClient::SendRequestOnce(1045)/2308: WARNING: NPT_CHECK failed, result=-1 (FAILURE) [(m_Connector->Connect(server_hostname, server_port, m_Config.m_ConnectionTimeout, m_Config.m_IoTimeout, m_Config.m_NameResolverTimeout, input_stream, output_stream))]
foo_upnp: 4.800: PLT_HttpClientSocketTask::DoRun(233)/2308: FINER: PLT_HttpClientSocketTask receiving: res = -1
foo_upnp: 4.800: PLT_HttpHelper::ToLog(483)/2308: FINER: NULL HTTP Response!
foo_upnp: 4.800: PLT_HttpClientSocketTask::ProcessResponse(289)/2308: FINE: PLT_HttpClientSocketTask::ProcessResponse (result=-1)
foo_upnp: 4.800: PLT_HttpClientSocketTask::ProcessResponse(290)/2308: WARNING: NPT_CHECK failed, result=-1 (FAILURE) [(res)]
foo_upnp: 4.800: PLT_HttpClientSocketTask::DoRun(249)/2308: WARNING: NPT_CHECK failed, result=-20401 (NPT_ERROR_CONNECTION_ABORTED) [(SetConnector(0))]
foo_upnp: 4.800: PLT_HttpServerSocketTask::Write(305)/1860: FINER: PLT_HttpServerTask Sending response:
foo_upnp: 4.800: PLT_HttpHelper::ToLog(495)/1860: FINER:
HTTP/1.1 200 OK
Connection: close
foo_upnp: 4.800: NPT_HttpHeader::Emit(118)/1860: FINEST: header Server: Platinum/0.5.4.0
foo_upnp: 4.800: NPT_HttpHeader::Emit(118)/1860: FINEST: header Connection: close
foo_upnp: 4.800: PLT_HttpServerSocketTask::Write(319)/1860: FINER: keep_alive = false, headers_only = false
foo_upnp: 4.836: NPT_Win32Thread::Start(483)/3844: FINER: creating thread
foo_upnp: 4.836: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/3844: FINE: current http task count = 3
foo_upnp: 4.837: NPT_Win32Thread::EntryPoint(450)/1532: FINER: thread in =======================
foo_upnp: 4.837: NPT_HttpRequest::Parse(592)/1532: FINEST: http request: GET /DeviceDescription.xml HTTP/1.1
foo_upnp: 4.837: NPT_HttpHeaders::Parse(185)/1532: FINEST: header - Cache-Control: no-cache
foo_upnp: 4.837: NPT_HttpHeaders::Parse(185)/1532: FINEST: header - Connection: Close
foo_upnp: 4.837: NPT_HttpHeaders::Parse(185)/1532: FINEST: header - Pragma: no-cache
foo_upnp: 4.837: NPT_HttpHeaders::Parse(185)/1532: FINEST: header - Accept: text/xml, application/xml
foo_upnp: 4.837: NPT_HttpHeaders::Parse(185)/1532: FINEST: header - Host: 5.139.8.151:56923
foo_upnp: 4.837: NPT_HttpHeaders::Parse(215)/1532: FINEST: header User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50
foo_upnp: 4.837: PLT_HttpServer::ProcessHttpRequest(142)/1532: FINE: Received GET Request from 5.243.250.36 for /DeviceDescription.xml
foo_upnp: 4.837: PLT_HttpHelper::ToLog(409)/1532: FINER:
Connection: Close
Pragma: no-cache
foo_upnp: 4.838: FbMediaServer::ProcessHttpRequest(265)/1532: INFO: received LAN request: [url=http://5.139.8.151:56923/DeviceDescription.xml]http://5.139.8.151:56923/DeviceDescription.xml[/url] (User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50)
foo_upnp: 4.838: PLT_DeviceHost::ProcessHttpRequest(376)/1532: FINER: PLT_DeviceHost Received Request:
foo_upnp: 4.838: PLT_HttpHelper::ToLog(409)/1532: FINER:
Connection: Close
Pragma: no-cache
foo_upnp: 4.838: FbMediaServer::ProcessGetDescription(333)/1532: INFO: ProcessGetDescription: user-agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7600.16385 DLNADOC/1.50
foo_upnp: 4.838: PLT_DeviceHost::ProcessGetDescription(422)/1532: FINEST: Returning description to 5.243.250.36: <?xml version="1.0" encoding="UTF-8"?>
<root xmlns="urn:schemas-upnp-org:device-1-0" xmlns:dlna="urn:schemas-dlna-org:device-1-0"><specVersion><major>1</major><minor>0</minor></specVersion><device><deviceType>urn:schemas-upnp-org:device:MediaServer:1</deviceType><friendlyName>Will</friendlyName><manufacturer>Michael Pujos</manufacturer><manufacturerURL>http://www.hydrogenaudio.org/forums/index.php?showtopic=69664</manufacturerURL><modelDescription>foobar2000 Media Server</modelDescription><modelName>foobar2000 Media Server</modelName><modelURL>http://www.hydrogenaudio.org/forums/index.php?showtopic=69664</modelURL><modelNumber>0.99.24</modelNumber><serialNumber></serialNumber><UDN>uuid:92b8f19e-35f9-2ee8-7c6b-9c28f6401a09</UDN><dlna:X_DLNADOC xmlns:dlna="urn:schemas-dlna-org:device-1-0">DMS-1.50</dlna:X_DLNADOC><iconList><icon><mimetype>image/jpeg</mimetype><width>48</width><height>48</height><depth>24</depth><url>/images/foobar2000-48x48.jpg</url></icon><icon><mimetype>image/png</mimetype><width>48</width><height>48</height><depth>32</depth><url>/images/foobar2000-48x48.png</url></icon></iconList><serviceList><service><serviceType>urn:schemas-upnp-org:service:ContentDirectory:1</serviceType><serviceId>urn:upnp-org:serviceId:ContentDirectory</serviceId><SCPDURL>/ContentDirectory/92b8f19e-35f9-2ee8-7c6b-9c28f6401a09/scpd.xml</SCPDURL><controlURL>/ContentDirectory/92b8f19e-35f9-2ee8-7c6b-9c28f6401a09/control.xml</controlURL><eventSubURL>/ContentDirectory/92b8f19e-35f9-2ee8-7c6b-9c28f6401a09/event.xml</eventSubURL></service><service><serviceType>urn:schemas-upnp-org:service:ConnectionManager:1</serviceType><serviceId>urn:upnp-org:serviceId:ConnectionManager</serviceId><SCPDURL>/ConnectionManager/92b8f19e-35f9-2ee8-7c6b-9c28f6401a09/scpd.xml</SCPDURL><controlURL>/ConnectionManager/92b8f19e-35f9-2ee8-7c6b-9c28f6401a09/control.xml</controlURL><eventSubURL>/ConnectionManager/92b8f19e-35f9-2ee8-7c6b-9c28f6401a09/event.xml</eventSubURL></service><service><serviceType>urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1</serviceType><serviceId>urn:microsoft.com:serviceId:X_MS_MediaReceiverRegistrar</serviceId><SCPDURL>/X_MS_MediaReceiverRegistrar/92b8f19e-35f9-2ee8-7c6b-9c28f6401a09/scpd.xml</SCPDURL><controlURL>/X_MS_MediaReceiverRegistrar/92b8f19e-35f9-2ee8-7c6b-9c28f6401a09/control.xml</controlURL><eventSubURL>/X_MS_MediaReceiverRegistrar/92b8f19e-35f9-2ee8-7c6b-9c28f6401a09/event.xml</eventSubURL></service></serviceList></device></root>
foo_upnp: 4.838: PLT_HttpServerSocketTask::Write(305)/1532: FINER: PLT_HttpServerTask Sending response:
foo_upnp: 4.838: PLT_HttpHelper::ToLog(495)/1532: FINER:
HTTP/1.1 200 OK
Content-Length: 2477
Connection: close
foo_upnp: 4.838: NPT_HttpHeader::Emit(118)/1532: FINEST: header Server: Platinum/0.5.4.0
foo_upnp: 4.838: NPT_HttpHeader::Emit(118)/1532: FINEST: header Content-Length: 2477
foo_upnp: 4.838: NPT_HttpHeader::Emit(118)/1532: FINEST: header Content-Type: text/xml; charset="utf-8"
foo_upnp: 4.838: NPT_HttpHeader::Emit(118)/1532: FINEST: header Connection: close
foo_upnp: 4.838: PLT_HttpServerSocketTask::Write(319)/1532: FINER: keep_alive = false, headers_only = false
foo_upnp: 4.839: PLT_HttpServerSocketTask::Write(324)/1532: FINER: NPT_StreamToStreamCopy begin
foo_upnp: 4.839: PLT_HttpServerSocketTask::Write(332)/1532: FINER: NPT_StreamToStreamCopy end
foo_upnp: 4.872: NPT_Win32Thread::Start(483)/3844: FINER: creating thread
foo_upnp: 4.873: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/3844: FINE: current http task count = 3
foo_upnp: 4.873: NPT_Win32Thread::EntryPoint(450)/3008: FINER: thread in =======================
foo_upnp: 4.874: NPT_HttpRequest::Parse(592)/3008: FINEST: http request: GET /images/foobar2000-48x48.png HTTP/1.1
foo_upnp: 4.874: NPT_HttpHeaders::Parse(185)/3008: FINEST: header - Connection: Keep-Alive
foo_upnp: 4.874: NPT_HttpHeaders::Parse(185)/3008: FINEST: header - User-Agent: Windows-Media-Player-DMS/12.0.7600.16385
foo_upnp: 4.874: NPT_HttpHeaders::Parse(215)/3008: FINEST: header Host: 5.139.8.151:56923
foo_upnp: 4.874: PLT_HttpServer::ProcessHttpRequest(142)/3008: FINE: Received GET Request from 5.243.250.36 for /images/foobar2000-48x48.png
foo_upnp: 4.874: PLT_HttpHelper::ToLog(409)/3008: FINER:
foo_upnp: 4.874: PLT_HttpServerSocketTask::Write(305)/3008: FINER: PLT_HttpServerTask Sending response:
foo_upnp: 4.874: PLT_HttpHelper::ToLog(495)/3008: FINER:
HTTP/1.1 200 OK
Content-Length: 1741
Content-Type: image/png
foo_upnp: 4.874: NPT_HttpHeader::Emit(118)/3008: FINEST: header Server: Platinum/0.5.4.0
foo_upnp: 4.874: NPT_HttpHeader::Emit(118)/3008: FINEST: header Connection: keep-alive
foo_upnp: 4.874: NPT_HttpHeader::Emit(118)/3008: FINEST: header Content-Length: 1741
foo_upnp: 4.874: NPT_HttpHeader::Emit(118)/3008: FINEST: header Content-Type: image/png
foo_upnp: 4.874: PLT_HttpServerSocketTask::Write(319)/3008: FINER: keep_alive = true, headers_only = false
foo_upnp: 4.874: PLT_HttpServerSocketTask::Write(324)/3008: FINER: NPT_StreamToStreamCopy begin
foo_upnp: 4.874: PLT_HttpServerSocketTask::Write(332)/3008: FINER: NPT_StreamToStreamCopy end
foo_upnp: 4.877: NPT_Win32Thread::Start(483)/2748: FINER: creating thread
foo_upnp: 4.877: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/2748: FINE: current http task count = 7
foo_upnp: 4.877: NPT_Win32Thread::EntryPoint(450)/332: FINER: thread in =======================
foo_upnp: 4.878: NPT_HttpRequest::Parse(592)/332: FINEST: http request: UNSUBSCRIBE /ConnectionManager/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml HTTP/1.1
foo_upnp: 4.878: NPT_HttpHeaders::Parse(185)/332: FINEST: header - Cache-Control: no-cache
foo_upnp: 4.878: NPT_HttpHeaders::Parse(185)/332: FINEST: header - Connection: Close
foo_upnp: 4.878: NPT_HttpHeaders::Parse(185)/332: FINEST: header - Pragma: no-cache
foo_upnp: 4.878: NPT_HttpHeaders::Parse(185)/332: FINEST: header - User-Agent: Microsoft-Windows/6.1 UPnP/1.0
foo_upnp: 4.878: NPT_HttpHeaders::Parse(185)/332: FINEST: header - SID: uuid:a6773bda-8af2-70d0-5714-727c6ce7ccff
foo_upnp: 4.878: NPT_HttpHeaders::Parse(215)/332: FINEST: header Host: 192.168.1.125:53301
foo_upnp: 4.878: PLT_HttpServer::ProcessHttpRequest(142)/332: FINE: Received UNSUBSCRIBE Request from 192.168.1.194 for /ConnectionManager/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml
foo_upnp: 4.878: PLT_HttpHelper::ToLog(409)/332: FINER:
Connection: Close
Pragma: no-cache
foo_upnp: 4.878: PLT_DeviceHost::ProcessHttpRequest(376)/332: FINER: PLT_DeviceHost Received Request:
Connection: Close
Pragma: no-cache
foo_upnp: 4.878: PLT_Service::ProcessCancelSubscription(664)/332: INFO: Cancelling subscription for ConnectionManager/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml (sub=uuid:a6773bda-8af2-70d0-5714-727c6ce7ccff)
foo_upnp: 4.878: PLT_EventSubscriber::~PLT_EventSubscriber(69)/332: FINE: Deleting subscriber (uuid:a6773bda-8af2-70d0-5714-727c6ce7ccff)
foo_upnp: 4.878: PLT_HttpTcpConnector::Connect(86)/736: FATAL: NPT_CHECK failed, result=-1 (FAILURE) [(m_Socket->Connect(socket_address, connection_timeout))]
foo_upnp: 4.878: NPT_HttpClient::SendRequestOnce(1045)/736: WARNING: NPT_CHECK failed, result=-1 (FAILURE) [(m_Connector->Connect(server_hostname, server_port, m_Config.m_ConnectionTimeout, m_Config.m_IoTimeout, m_Config.m_NameResolverTimeout, input_stream, output_stream))]
foo_upnp: 4.878: PLT_HttpClientSocketTask::DoRun(233)/736: FINER: PLT_HttpClientSocketTask receiving: res = -1
foo_upnp: 4.878: PLT_HttpHelper::ToLog(483)/736: FINER: NULL HTTP Response!
foo_upnp: 4.879: PLT_HttpClientSocketTask::ProcessResponse(289)/736: FINE: PLT_HttpClientSocketTask::ProcessResponse (result=-1)
foo_upnp: 4.879: PLT_HttpClientSocketTask::ProcessResponse(290)/736: WARNING: NPT_CHECK failed, result=-1 (FAILURE) [(res)]
foo_upnp: 4.879: PLT_HttpClientSocketTask::DoRun(249)/736: WARNING: NPT_CHECK failed, result=-20401 (NPT_ERROR_CONNECTION_ABORTED) [(SetConnector(0))]
foo_upnp: 4.879: PLT_HttpServerSocketTask::Write(305)/332: FINER: PLT_HttpServerTask Sending response:
foo_upnp: 4.879: PLT_HttpHelper::ToLog(495)/332: FINER:
HTTP/1.1 200 OK
Connection: close
foo_upnp: 4.879: NPT_HttpHeader::Emit(118)/332: FINEST: header Server: Platinum/0.5.4.0
foo_upnp: 4.879: NPT_HttpHeader::Emit(118)/332: FINEST: header Connection: close
foo_upnp: 4.879: PLT_HttpServerSocketTask::Write(319)/332: FINER: keep_alive = false, headers_only = false
foo_upnp: 4.959: NPT_Win32Thread::Start(483)/2748: FINER: creating thread
foo_upnp: 4.959: PLT_HttpListenTask<class PLT_HttpServerListener>::DoRun(156)/2748: FINE: current http task count = 7
foo_upnp: 4.960: NPT_Win32Thread::EntryPoint(450)/1472: FINER: thread in =======================
foo_upnp: 4.960: NPT_HttpRequest::Parse(592)/1472: FINEST: http request: UNSUBSCRIBE /RenderingControl/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml HTTP/1.1
foo_upnp: 4.960: NPT_HttpHeaders::Parse(185)/1472: FINEST: header - Cache-Control: no-cache
foo_upnp: 4.960: NPT_HttpHeaders::Parse(185)/1472: FINEST: header - Connection: Close
foo_upnp: 4.960: NPT_HttpHeaders::Parse(185)/1472: FINEST: header - Pragma: no-cache
foo_upnp: 4.960: NPT_HttpHeaders::Parse(185)/1472: FINEST: header - User-Agent: Microsoft-Windows/6.1 UPnP/1.0
foo_upnp: 4.960: NPT_HttpHeaders::Parse(185)/1472: FINEST: header - SID: uuid:de3be460-f9ad-0040-26ed-c69ef948c2e0
foo_upnp: 4.960: NPT_HttpHeaders::Parse(215)/1472: FINEST: header Host: 192.168.1.125:53301
foo_upnp: 4.960: PLT_HttpServer::ProcessHttpRequest(142)/1472: FINE: Received UNSUBSCRIBE Request from 192.168.1.194 for /RenderingControl/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml
foo_upnp: 4.960: PLT_HttpHelper::ToLog(409)/1472: FINER:
Connection: Close
Pragma: no-cache
foo_upnp: 4.960: PLT_DeviceHost::ProcessHttpRequest(376)/1472: FINER: PLT_DeviceHost Received Request:
Connection: Close
Pragma: no-cache
foo_upnp: 4.960: PLT_Service::ProcessCancelSubscription(664)/1472: INFO: Cancelling subscription for RenderingControl/8d704038-586e-8143-d86f-ac1b68a877fd/event.xml (sub=uuid:de3be460-f9ad-0040-26ed-c69ef948c2e0)
foo_upnp: 4.961: PLT_EventSubscriber::~PLT_EventSubscriber(69)/1472: FINE: Deleting subscriber (uuid:de3be460-f9ad-0040-26ed-c69ef948c2e0)
foo_upnp: 4.961: PLT_HttpTcpConnector::Connect(86)/2176: FATAL: NPT_CHECK failed, result=-1 (FAILURE) [(m_Socket->Connect(socket_address, connection_timeout))]
foo_upnp: 4.961: NPT_HttpClient::SendRequestOnce(1045)/2176: WARNING: NPT_CHECK failed, result=-1 (FAILURE) [(m_Connector->Connect(server_hostname, server_port, m_Config.m_ConnectionTimeout, m_Config.m_IoTimeout, m_Config.m_NameResolverTimeout, input_stream, output_stream))]
foo_upnp: 4.961: PLT_HttpClientSocketTask::DoRun(233)/2176: FINER: PLT_HttpClientSocketTask receiving: res = -1
foo_upnp: 4.961: PLT_HttpHelper::ToLog(483)/2176: FINER: NULL HTTP Response!
foo_upnp: 4.961: PLT_HttpClientSocketTask::ProcessResponse(289)/2176: FINE: PLT_HttpClientSocketTask::ProcessResponse (result=-1)
foo_upnp: 4.961: PLT_HttpClientSocketTask::ProcessResponse(290)/2176: WARNING: NPT_CHECK failed, result=-1 (FAILURE) [(res)]
foo_upnp: 4.961: PLT_HttpClientSocketTask::DoRun(249)/2176: WARNING: NPT_CHECK failed, result=-20401 (NPT_ERROR_CONNECTION_ABORTED) [(SetConnector(0))]
foo_upnp: 4.961: PLT_HttpServerSocketTask::Write(305)/1472: FINER: PLT_HttpServerTask Sending response:
foo_upnp: 4.962: PLT_HttpHelper::ToLog(495)/1472: FINER:
HTTP/1.1 200 OK
Connection: close
foo_upnp: 4.962: NPT_HttpHeader::Emit(118)/1472: FINEST: header Server: Platinum/0.5.4.0
foo_upnp: 4.962: NPT_HttpHeader::Emit(118)/1472: FINEST: header Connection: close
foo_upnp: 4.962: PLT_HttpServerSocketTask::Write(319)/1472: FINER: keep_alive = false, headers_only = false
God Bless U.S.A
foo_upnp
Reply #872
1) I noticed on a screenshot (message #779) of another users controller UI, there were files listed under the control buttons and the currently playing line. Mine is just blank open space under those 2 items. I use DUI, and I have a large corner of my screen setup with multiple tabs (playlist, folders, console, controller, browser, etc.). Should there be a list or playlist under there or is this just that users config?
2) I stumbled upon an odd behavior, while testing for files being passed unmodified between my old laptop and main rig. I had earlier been testing the laptop as a renderer with the main rig being the server and controller. That worked fine and I stopped those tests. Next, I was testing the laptop as a client, pulling songs from the main rig. That also worked fine, but when I would stop the song playing on the laptop from the browser, the controller on the main rig would start pushing songs from the controller playback queue to the laptop. During my testing yesterday, I had always cleared the playback queue after tests, but this morning, I had left some songs in the queue. Is this automatically starting to play the playback queue normal, when a client’s playback is stopped?
So I'm good to go. Looking forward to testing the internet remote access and also testing a hand-held device or an iPad as a controller. I saw some demo videos of an iPad running PlugPlayer as the app, was incredible. Awesome plug-in, thank you, again, sir!
Watch out were the huskies go and don't you eat that yellow snow! - F. Zappa
foo_upnp
Reply #873
Hi
this is a very nice component and it is doing great work. Thank you for that.
I want to use it with a media player device (MD 86162). It s working so far.  But currently i am forced to use "Playback Stream Capture" to achieve that files are played in an order i want them to play. The problem however is not the component, it s the stupid media player device, which keeps sorting the playlist entries alphabeticly and thus the order is gone.
My last hope was to set "Format track titles using:" to "[%list_index% - ]%artist% - %title%" but unfortunately %list_index% is not resolved to a value (just an "?").
Is there anyway to refer to the column value "Item Index" of a playlist. This would solve my problem with this stupid device.
If this is not yet possibel, it would be nice if this feature would be included in one of the next releases.
Regards
Joe
foo_upnp
Reply #874
perhaps, anyone can help.....
is it possible to remote foobar2000 with one pc in my network (like in the picuture). i dont want
stream music
i will remote PC2 with PC1.....
[/quote]
