Topic: Missing ReplayGain Scan function (Read 265 times) previous topic - next topic
i don't have any menu links to the original ReplayGain Scan function, and i don't see it in the component menu... it should be under Preferences -> Tools?
it's an old foobar install, updated to v1.6.6, can this functionality be downloaded somewhere?
i do have ReplayGain in the Playback menu.
thx
Re: Missing ReplayGain Scan function
Select the tracks in the main window and right-click on 1 of then. Then you'll see the RG in the drop-down menu.
That was weird.......
Give it try with a portable 'install' of fb2k and and see if it works there. If it does so do i recommend ya to uninstall your installed version of foobar and start all over with a fresh install of it.
Attached a screenshot of my fb2k showing RG in the drop-down menu.
that fixed it, the default install had replaygain unchecked(!), so i ticked the box and installed... the missing component is named foo_rgscan
thx for your help, i should have tried a complete install before posting out here :-/
Gr8 that it got solved :)
