Topic: Volumio UPnP (Read 1890 times) previous topic - next topic
Volumio UPnP
Hi, I want to use Foobar with Volumio via UPnP, I installed the required plugins (foo_out_upnp and Foo_upnp) but only a white noise is heard. In the interface of Volumio I see the data of what I am reproducing in Foobar.
What am I doing wrong?
Daniel
Re: Volumio UPnP
I seem to have trouble making Volumio work to test it. But have you tried 16-bit PCM output from foobar2000? I recall reading about compatibility problems with several devices when 24-bit output is used.
