Topic: Is FB2k modyfing mp3s? (Read 3136 times) previous topic - next topic
Hi
I noticed that after listening to mp3s (in foobar v0.9.5)  the SUM check of mp3 files is failing. This have no effect on playback, but may affect for example if I am sending a file to somebody and listening at the same time it may cause troubles etc.
Do you have any idea about it?
The default installation, and most components do not write to files without your explicit permission. However, there are components whose default settings are to write info to file tags... e.g. the unofficial playback counter, uie_lyrics_view etc. If you post your components list, we might be able to determine the culprit.
ok it'd be nice. Here we go:
Core (2007-12-31 19:57:54)
    foobar2000 core 0.9.5
foo_abx.dll (2006-11-25 15:20:22)
    ABX Comparator 1.3.1
foo_albumlist.dll (2007-12-29 16:47:54)
    Album List 4.1
foo_audioscrobbler.dll (2008-03-09 20:08:02)
    Audioscrobbler 1.3.16
foo_cdda.dll (2007-12-14 00:38:24)
    CD Audio Decoder 2.1.2
foo_converter.dll (2007-12-29 16:47:36)
    Converter 1.0.2
foo_convolve.dll (2006-08-04 22:57:26)
    Convolver 0.3
foo_cwb_hooks.dll (2008-01-02 16:51:10)
    cwbowron's title format hooks 1.2.6 [Jan  2 2008 - 15:50:05]
    Tagger Panel Window 1.0.6 [Jan  2 2008 - 15:50:49]
foo_dsp_delta.dll (2006-03-21 19:16:22)
    LPCM <--> delta-PCM converter 0.1.1
foo_dsp_soundtouch.dll (2008-02-16 08:05:52)
    SoundTouch DSP 0.1 (SSE)
foo_dsp_ssrc.dll (2006-08-15 17:00:00)
    Resampler DSP (SSRC) 0.57 SSE2
foo_dsp_std.dll (2007-11-22 23:20:02)
    Standard DSP Array 1.0
foo_input_monkey.dll (2007-04-13 19:39:54)
    Monkey's Audio decoder 2.1.2
foo_input_std.dll (2007-12-29 16:50:00)
    Standard Input Array 1.0
foo_lyricsdb.dll (2007-02-26 18:42:02)
    foo_lyricsdb 0.0.7 beta 5
foo_masstag.dll (2006-11-25 15:18:42)
    Masstagger 1.6
foo_out_asio.dll (2006-08-13 18:07:52)
    ASIO support 1.2.4
foo_playback_custom.dll (2007-11-12 09:23:50)
    Playback Statistics Custom 1.4.3
foo_pqview.dll (2008-03-11 19:02:54)
    Playback Queue Viewer 0.2
foo_removefromqueue.dll (2007-07-14 14:30:00)
    Remove from Queue 1
foo_rgscan.dll (2007-12-29 16:47:00)
    ReplayGain Scanner 2.0.2
foo_ui_columns.dll (2008-01-10 03:17:37)
    Columns UI 0.2.1 alpha 10 v3
foo_ui_panels.dll (2007-07-13 15:06:18)
    Panels UI 0.14.9 beta [Jul 13 2007 - 14:05:55]
foo_ui_std.dll (2007-12-29 19:06:28)
    Default User Interface 0.9.5
foo_uie_albumart.dll (2007-12-16 01:22:24)
    Album Art Panel 0.2.7.1
foo_uie_albumlist.dll (2007-06-11 15:13:53)
    Album list panel 0.2.3 beta
foo_uie_lyrics.dll (2008-01-15 14:44:18)
    Lyric Show Panels 0.3.2.1 Beta 2 [Jan 15 2008 - 20:42:40]
foo_uie_peakmeter.dll (2007-10-20 15:03:30)
    Peakmeter Panel 0.0.4.2 beta
foo_uie_powerpanels.dll (2007-08-05 14:32:38)
    Seek Panel 0.1
    Volume Panel 0.1
foo_uie_queuemanager.dll (2006-12-17 03:21:36)
    Queue manager panel 0.2.3
foo_uie_quicksearch.dll (2007-05-18 13:31:10)
    Quick Search Toolbar 2.8l
foo_uie_trackinfo.dll (2006-06-22 23:26:04)
    Track info panel 0.8
foo_uie_vis_channel_spectrum.dll (2008-01-12 17:52:12)
    Channel Spectrum panel 0.14
foo_uie_vis_egoh.dll (2007-01-13 06:20:06)
    Egoh Spectrum analyser (uie) 1.1.0
foo_uie_vis_peakmeter_spectrum.dll (2008-04-19 20:18:50)
    Peakmeter Spectrum Visualisation 0.2.0.0 beta
foo_uie_vis_projectm.dll (2006-05-25 01:21:08)
    projectM visualization (Panel) 0.4 (SSE2)
foo_unpack.dll (2006-11-25 15:20:32)
    RAR reader 1.1
    ZIP/GZIP reader 1.0
Check if it updates the tags.
