Stop after albumfoo_stopafteralbum.dll
Works with CUI/DUI
actual version:
3.6Usage:
Menu | Playback | Control | Stop after album (ON/OFF)
Menu | Playback | Control | Stop after last track (ON/OFF)
Menu | Playback | Control | Stop after album & last track (ON/OFF)
Menu | Playback | Control | Repeat album (ON/OFF)
Menu | Playback | Control | Skip album once (ON/OFF)
Menu | Playback | Control | Random album track (ON/OFF)
Menu | Playback | Control | Repeat current track once (ON/OFF)
Menu | Playback | Control | Skip next track once (ON/OFF)
Menu | Playback | Control | Reverse (ON/OFF)
Menu | Playback | Control | Previous playlist (ON/OFF)
Menu | Playback | Control | Next playlist (ON/OFF)
Menu | Playback | Control | Repeat playlist once (ON/OFF)
Menu | Playback | Control | Gap tracks | 5s - 1h (ON/OFF)
Menu | Playback | Control | Gap albums | 5s - 1h (ON/OFF)
Menu | Playback | Control | Stop after albums once | 1 - 10 (ON/OFF)
Menu | Playback | Control | Stop after tracks once | 1 - 20 (ON/OFF)
Menu | Playback | Control | Alarm | 5s - 5h (ON/OFF)
Menu | Playback | Control | Timebomb | 0.5h - 5h (ON/OFF)
Advanced Preferences | Playback | Stop after album (OPTION/MODE)
Comments:
Stop after album: TRACKNUMBER = TOTALTRACKS
Stop after last track: create field name LASTTRACK with field value 1
[attachment=7600:foo_stopafteralbum.zip][attachment=7601:foo_stop..._3.6_src.zip]
msvcr100.dll dependency removed
Stop after album v0.2
ADD: Stop after current after x albuns
ADD: Stop after current after x tracks
ADD: Stop after current after x minutes (based on tracklength sum)
Stop after album v0.3
FIX: minor bugs
ADD: allow using album/time/track simultaneously
Stop after album v0.4
RMV: Only stop once (general)
ADD: Only stop once individually for Album/Track/Time mode
ADD: Timebomb mode (simple timer firing stop after current)
ADD: Gap (stop after current -> stop -> gap (default: 10s) -> start next track)
Stop after Album v0.5
ADD: Paused (stop after current->stop->(gap)->next track paused)
ADD: Repeat album (album stop after current->stop->(gap)->album is repeated) (experimental)
Stop after album v0.6
ADD: Tracknumber mode
ADD: Skip album option
Note: Please read Preferences | Components | Stop after album | About | Usage
Please report bugs/crashes/feature requests in 3rd party thread.
Stop after album v0.7
FIX: several bugs
ADD: option presets for modes
Stop after album v0.8
ADD: most common presets as menu commands (Repeat album. Skip album, Gap album)
Stop after album v0.9 "official release"
Stop after album v1.0
FIX: reset when stopping
FIX: Timebomb not working
ADD: Timebomb message popup
ADD: Repeat current once (menu)
ADD: Skip next once (menu)
ADD: Gap (every track) (menu)
CHG: component on/off in Advanced Preferences
FIX: minor bugs
Stop after album v1.1
ADD: Random album
Stop after album v1.2
ADD: (main menu command) Timebomb 0.5h-5h
Stop after album 1.3
CHG: mainmenu commands moved to submenu "Control"
ADD: Menu | Playback | Control | Stop after albums | 1 - 10
ADD: Menu | Playback | Control | Stop after tracks | 1 - 20
Stop after album 1.4
FIX: "Stop after album" command (bug introduced in 1.3)
ADD: Menu | Playback | Control | Reverse (ON/OFF)
Stop after album 1.5
Maintenance release
several improvements
Stop after album 1.6
Bugfix release
Code optimization
Stop after album 1.7
FIX: bug in "Repeat album" cutting of beginning of first track
CHG: Skip album -> Skip album once
Stop after album 1.8
FIX: "Repeat current once" not reseted properly
Discussion thread: http://www.hydrogenaudio.org/forums/index....showtopic=83748 (http://www.hydrogenaudio.org/forums/index.php?showtopic=83748)
Stop after album 1.9
FIX: "Stop playback after current track" option in (Playback) Preferences is now working, when Stop after album component is inactive
(thanks for reporting romor)
Stop after album 2.0
RMV: Preset options removed, because of minor usefulness
Stop after album 2.1RMV: enable/disable component (in Advanced Preferences)
CHG: Compiled with SDK 2011-03-11
foobar2000 v1.1 or newer required to run components made with this SDK.
Stop after album 2.2ADD: (mainmenu) | Playback | Control | Stop after last track
How the new feature works:
Tracks with a special tag trigger "Stop after current".
Add a new tag to the chosen track(s), enable "Stop after last track" and the playback stops after this "marked" track(s).
How to add the new tag:
- Mark and rightclick your chosen track(s) in playlist
- Properties | Tools | Add new field...
- Insert field name "LASTTRACK" with field value "1"
Stop after album 2.3
FIX: bug in stop after last track
ADD: (mainmenu) | Playback | Control | Stop after album & last track
CHG: More verbose description of some commands in statusbar
Stop after album 2.4
ADD: (mainmenu) | Playback | Control | Previous playlist after album
ADD: (mainmenu) | Playback | Control | Next playlist after album
ADD: Advanced Preferences | Playback | Stop after album | Previous playlist & play
ADD: Advanced Preferences | Playback | Stop after album | Next playlist & play
Playing the highlighted track of the previous/next playlist (first track, if no track highlighted).
FIX: bugs fixed, code simplifing/pruning
Stop after album 2.5
FIX: "Next/Previous playlist & play" now works with "playback follows cursor" disabled
Tip: "stop after current" button in CUI-toolbar
CUI-Button-Toolbar | Button options | Add | Playback/Stop after current
Indicates whether "stop after current" is enabled or not
Discussion thread:
I'll reply there.
Stop after album 2.6
FIX: only once commands in advanced preferences
Stop after album 2.7
ADD: Menu | Playback | Control | Next playlist after playlist end (ON/OFF)
Stop after album 2.8
ADD: Menu | Playback | Control | Next playlist after playlist end (1st track) (ON/OFF)
ADD: Menu | Playback | Control | Repeat playlist (ON/OFF)
thanks to kode54 for hint.
Stop after album 2.9
CHG: (mainmenu command) Previous playlist (focused track) -> Previous playlist (1st track)
CHG: (mainmenu command) Stop after albums (1-10) -> Stop after albums once (1-10)
CHG: (mainmenu command) Stop after tracks (1-20) -> Stop after tracks once (1-20)
ADD: (mainmenu command) Timebomb | Timebomb# min, Abort
ADD: (mainmenu command) Alarm | 0.5h - 5h, Alarm# min, Abort
Stop after album 3.0
CHG: skipalbum, repeatalbum, etc. improvements
Stop after album 3.1
ADD: shorter alarm times (5s-0.5h)
Stop after album 3.2
ADD: Gap tracks submenu: 5s - 1h, track length
Stop after album 3.3
ADD: Gap album submenu: 5s - 1h, track length
FIX: few bugs
Stop after album 3.4
RMV: Next playlist after album (focused track)
RMV: Next playlist (focused track)
CHG: Repeat playlist -> Repeat playlist once
CHG: minor issues
Stop after album 3.5
FIX: stop after album for untagged tracknumber/totaltracks
Stop after album 3.6
ADD: Postgap, Add a pause after the track in seconds (x.xx) defined by tag %postgap%.
Download: see first post
Discussion thread:
https://hydrogenaud.io/index.php/topic,83748.0.html
