Topic: CBR AAC Encoder (Read 9383 times) previous topic - next topic
Re: CBR AAC Encoder
But, if you're using the same bitrate, higher sampling rate means lower quality. You have a different opinion and that's not a problem for me. Also, 11025Hz is a medium sampling rate for me.
It's not my opinion, it's a fact. But that is not important now. If you are satisfied with 11025 Hz sampling rate and muffled sound, that's okay.
Re: CBR AAC Encoder
In my opinion, you are an atom slightly outside the Schwarzschild radius of a supermassive black hole at the edge of the observable universe.
You are of course entitled to a different opinion, but they are all opinions and thus none are more wrong than the other.
A more relevant opinion is that TOS#8 has been inadequatly worded from the dawn of HA time.
I did an ABX today, remember.
Re: CBR AAC Encoder
Just out of curiosity, what is a low sampling rate for you & also what is a high sampling rate?
Re: CBR AAC Encoder
It is easy to fake a null result. If you pretend not to hear the difference between 8 kHz at 32 bits and 16 kHz at 16 bits, nobody can force you to actually listen instead of clicking at random.
Re: CBR AAC Encoder
5512.5Hz is low, and 22050Hz is high for me.
May I kindly ask how old you are? I am 65 and can clearly hear a difference from 22050 Hz to 44100 Hz.
Re: CBR AAC Encoder
I'm much younger than you, but that's not the problem because I can hear the difference between 22050Hz and 44100Hz too. I'm not in a search of "fidelity", I'm in a search of a "warmer" sound.
Re: CBR AAC Encoder
Reply #32
I got 16/16, remember.
Re: CBR AAC Encoder
Reply #35
11025Hz does not sound like muffled to me as I use linear interpolation. You should give it a try.
Re: CBR AAC Encoder
Reply #36
Use bad resampler to compensate for bad encode?
Re: CBR AAC Encoder
Reply #37
Sampling rate and quality are seperate things.
You seriously think that a 16/16 disproves differences?
A 16/16 ''proves'' differences.
And so your argument that sampling rate does not affect quality, is not in any way supported by anything you try to bring to the table.
I posted a downsampled file at https://hydrogenaud.io/index.php/topic,126168.msg1046984.html#msg1046984 .
Isn't it clear that it is bad quality?
Re: CBR AAC Encoder
Reply #38
11025Hz is not a bad sampling rate for me, and linear interpolation is not a bad resampling method for me. By the way, did you know that most Flash games were used 11025Hz 16kbps mono MP3's and resampled them with linear interpolation? This is the default audio format of Adobe Flash. If you want to see a game that uses this sound format, go to https://archive.org/details/tails-nightmare .
Re: CBR AAC Encoder
Reply #39
I'm looking at quality from a different viewpoint, please respect to my opinions.
Re: CBR AAC Encoder
Reply #40
Here at HydrogenAudio, high quality means "perceptually indistinguishable from the original".
Re: CBR AAC Encoder
Reply #42
Not necessarily. "Perceptible but not annoying" is not the worst: https://hydrogenaud.io/index.php/topic,125899.msg1044043.html#msg1044043
But sacrificing an audible octave or more just in order to boost bit depth to 32 - and claiming it improves - that is kinda ...
Re: CBR AAC Encoder
Reply #43
fdkaac, qaac , neroaac
@shadowking Do you know how can I export a raw AAC (.aac) file with qaac, and use the --lowpass setting with it (it says it requires libsoxconvolver but I don't know how to install it)?
Re: CBR AAC Encoder
Reply #44
This sound is not the result of just the encoder. It's bass boosted, bit crushed and heavily equalized/DSP'd to sound like that.
TAPE LOADING ERROR
Re: CBR AAC Encoder
Reply #45
Why do you think it's bass boosted, bit crushed, and heavily DSP'd? I compared it to the original music and I did not see any signs of bass boost, bit crush, and heavy DSP effects.
Re: CBR AAC Encoder
Reply #46
I found how to install libsoxconvolver (topic#116598) but I still need to learn how to export a raw AAC file with it or convert a .m4a file to a raw AAC file.
Re: CBR AAC Encoder
Reply #47
But, I still can't apply a custom cutoff. Does anyone know why?
Re: CBR AAC Encoder
Reply #48
What cutoff are you trying to apply and how are you trying to apply it (command-line example)?
korth
Re: CBR AAC Encoder
Reply #49
I want to apply lower cutoffs for some bitrates and higher cutoffs for some bitrates, but I could not. Here's an example command that I tried to export a lower cutoff (I don't want to use that low cutoff, this is just for testing): qaac -c 24 -r 22050 --lowpass 2000 sh44m.wav
