Topic: Line at 18 or 20 kHz in spectogram (Read 997 times) previous topic - next topic
in quite a few higher resolution files I have found a line exactly at 20 kHz, but I have also seen it at 18k.
What may be the cause of this?
Thx
X
And while we're at it, the following, above 20k, that's just random high frequency noise? I've also seen it before in a 358k SACD conversion to 96k FLAC.
X
Re: Line at 18 or 20 kHz in spectogram
Lines can be noise from CRT monitors.
CRT noise that high? They're usually hovering at around 15 kHz.
Second one is sort of standard for how SACD work, as far as I understood.
TAPE LOADING ERROR
That's dither with shaped noise.
The 20kHz line to me looks like some dsp or filtering artifact.
Thank you, I'd guess it may be a DSD transfer to PCM? Thanks for the key word "shaped noise", I looked into DSD a bit[1], it wouldn't be my choice. Just from the technical idea. As I understand it (and for sure it is limited understanding) they work around dynamic range obstacles by signitificantly altering the signal? "The art of noise shaping"? However, I am pretty sure, in a PCM transfer this kind of noise is just useless weight to the file sizes and can/should be filtered. There's no natural sound above 22k.
I now have that habit to look into the spectogram of >48khz files. Some have natural frequencies above 22k, some a big NOTHING, some just randomness.
[1] OMG, 99 years old people on Youtube telling the audience that DSD "just sounds better".
