Topic: Is foo_input_amr still working? (Read 3697 times) previous topic - next topic
HI
I remember I was able to easily replay .amr files from my phone on foobar2000, not so now. The component seems very long not
 updated so there may be incompatibility issues. Please for verification how the component does now, and possibly recommend me a functional alternative, thx.
Unable to open item for playback (Seek offset out of range):
"C:\Users\Anakunda\AppData\Local\Temp\audio.amr"
General
Complete name        : C:\Users\Anakunda\AppData\Local\Temp\a.amr
Format               : MPEG-4
Format profile       : 3GPP Media Release 4
Codec ID             : 3gp4 (isom/3gp4)
File size            : 135 KiB
Duration             : 1 min 1 s
Overall bit rate mode: Constant
Overall bit rate     : 17.9 kb/s
Encoded date         : UTC 2017-06-20 13:25:00
Tagged date          : UTC 2017-06-20 13:25:00
FileExtension_Invalid: mov mp4 m4v m4a m4b m4p 3ga 3gpa 3gpp 3gp 3gpp2 3g2 k3g jpm jpx mqv ismv isma ismt f4a f4b f4v
Audio
Format               : AMR
Format/Info          : Adaptive Multi-Rate
Format profile       : Narrow band
Codec ID             : samr
Bit rate mode        : Constant
Bit rate             : 12.7 kb/s
Channel(s)           : 1 channel
Sampling rate        : 8 000 Hz
Bit depth            : 13 bits
Stream size          : 95.7 KiB (71%)
Title                : SoundHandle
Writing library      :
Language             : English
mdhd_Duration        : 61684
Re: Is foo_input_amr still working?
foo_input_amr is working with foobar2000  1.3.15 and can decode amr files.
Alternative is foo_input_exe+ffmpeg
I tried to play older amr files even without foo_input_amr. They can play. That means amr support is already included in fb core.
The problem seems to insist in specific amr files produced by Call Recorder License - ACR. The media info identifies something nonstandard - FileExtension_Invalid
Phone however still can play these amr files.
Yes. I removed foo_input_amr and fb2k still can play older amr files
Nowadays we already have foo_input_ffmpeg which can play not only amr-nb, but also amr-wb.
i just tried foo_input_ffmpeg and foo_input_amr with fb2k (all up to date) and specific amr files produced by Call Recorder ACR. all dont work. works with mpc and vlc though.
Can you share short problematic file?
