Topic: exhale - Open Source USAC encoder (Read 142774 times) previous topic - next topic
Re: exhale - Open Source USAC encoder
Reply #1050
Meanwhile I tried Windows 10 with Snapdragon 850 and the error doesn't show up, it seems confined to Windows for Intel processors. I'll try with 32-bit processors later.
Reply #1051
Meanwhile I tried Windows 10 with Snapdragon 850 and the error doesn't show up, it seems confined to Windows for Intel processors. I'll try with 32-bit processors later. The executable was compiled for x86.
Reply #1052
Sorry, Ziengaze, I cannot reproduce the phenomenon you're observing. All Windows compiles I tried (John's from post 1025 and my own), from the most recent commit on GitLab, produced 145.7 kbps on that 2L-125_stereo... audio file. Which Windows compiler are you using exactly, and on which Windows version exactly?
Chris
Reply #1053
Built on windows 10 21h1 using msys2 with gcc 11.3.0.
Reply #1054
So Ziengaze and I have done several other tests. All other compilers mentioned above, plus clang 14, have no problem compiling exhale. Also, the faulty compile only has problems with CVBR modes 5 and higher (non-SBR) as well as f and higher (SBR), which allowed us to trace the issue to very few changes made in exhale's source file lib/exhaleEnc.cpp. The strange thing is that NetRanger's last compile in this post seems to be fine, while Ziengaze's compile with the same gcc version seems faulty.
We just can't figure out what the problem is. Any help is greatly appreciated.
Chris
Reply #1055
That sounds like a job for unit testing.
Reply #1056
Do decode from the command-line, you can use an FFmpeg build with the latest FDK-AAC included. If you know how to compile FFmpeg yourself with the "non-free" extensions enabled, I recommend you do that. If not, I found the following page which links to precompiled binaries for Windows:
https://www.reddit.com/user/VeritablePornocopium/comments/ccilei/ffmpeg_with_libfdk_aac_for_windows_x64/
Under "Static builds - ffmpeg.exe" you can find a still working Mega.nz link. I haven't tried the downloaded executable yet and I'm not responsible for it (so use it at your own risk!), but it shows it was built with --enable-libfdk-aac when run without arguments from the command prompt.
The official ISO/MPEG reference decoder for USAC is closed-source and not publicly available.
Chris
Is there any option to include the exhale source encoder in ffmpeg as a non-free FDK-AAC build?
This would prove very useful since ffmpeg is the most convenient transcoder tool out there.
Reply #1057
In the early days of exhale development, someone already mentioned this in FFmpeg ticket #8411, but I decided this is too much work for me, and the FFmpeg developers don't seem to be interested very much (judging from the response to that ticket). Others would have to write exhale wrapper code for FFmpeg.
It's also not trivial since I believe exhale would have to be run in a two-pass fashion, with the first pass required to collect frame loudness information and the second pass for the actual audio encoding using the loudness data from the first pass. The only other xHE-AAC encoding plug-in available for FFmpeg that I'm aware of, the one by MainConcept and Fraunhofer IIS, requires such a two-step approach, as shown in Sec. 4. Plugin Usage of their User Guide.
Chris
Reply #1058
Are there any more updates planned regarding quality?
Would you consider it almost transparent at 192kbps? I think in the forum test. the Apple LC-AAC had a score around 4.94
Reply #1059
There are no updates planned, the latest exhale version achieves a mean opinion score of about 4.9 with CVBR preset 9, see this post and the following one for a blind test of a fix which was published in exhale later. And 4.9 was my goal from the start.
There is, however, an undocumented command-line which you can use to turn off the USAC noise filling functionality at CVBR preset 9 (it doesn't make any sense at lower-bitrate presets):
For 22 and 44.1 kHz input: exhale.exe 9 n 43 input.wav output.m4a
For 24 and 48.0 kHz input: exhale.exe 9 n 50 input.wav output.m4a
My ears aren't good enough anymore to tell a difference at ~192 kbps, but if someone is really interested in getting the maximum audio quality out of exhale at this bit-rate, feel free blind-test the default command-line against the above one and report whether there is any improvement by the latter on any audio content. If so, I might change CVBR preset 9 accordingly.
Chris
Reply #1061
You can take it a bit further if you want. Compile ffmpeg (and ffplay) with
--disable-decoder=aac
--disable-encoder=aac
--disable-decoder=aac_fixed
--enable-libfdk-aac
This disables all of ffmpeg's internal AAC decoding - so you'll never get any error codes about AOT 42 even if you don't remember to pass -acodec libfdk_aac to ffplay or prefix your ffmpeg -i with -c:a libfdk_aac. "It just works." ffmpeg will now also default to libfdk_aac, libopus, and libvorbis in any context where it needs to encode for output. USAC playback is drag/drop to ffplay without needing to write an admittedly simple .bat script to handle it, and if you build mpv from here, it'll work there too.
You can apply that to a lot of other codecs that have "iffy" ffmpeg implementations (opus/vorbis) or have faster alternatives (dav1d) as long as you're including the appropriate external library. Disable some MP2 encoders too while you're at it...
--disable-encoder=opus
--disable-decoder=opus
--enable-libopus
--disable-decoder=vorbis
--disable-encoder=vorbis
--enable-libvorbis
--disable-encoder=mp2
--disable-encoder=mp2fixed
--enable-libtwolame
--disable-decoder=av1
--disable-decoder=libaom
--enable-libdav1d
Reply #1062
Hi all, I had a question about USAC encoding that I asked on the project gitlab, but figured I'd ask here, too, in case anybody knows. https://gitlab.com/ecodis/exhale/-/issues/23
So, I'm working on a program that will read in a FLAC Icecast stream, then re-encode it to HLS in different codecs, I've been successful with the standard AAC, as well as ALAC and FLAC in fragmented mp4.
I wanted to integrate the Exhale library to add USAC as an option. But there's a part of the HLS specs that has me thrown:
2.22. For xHE-AAC, loudness metadata MUST be present according to the Basic Loudness Metadata specified in ISO 23003-4 Table I.5; samplePeakLevel or truePeakLevel MUST be present. The methodDefinition SHOULD be 2 for video content.
I'm reading in audio and immediately encode it, and everything I've seen about loudness metadata requires 2 passes. But for a live audio source, I assume there must be some method of essentially saying no, there is no loudness metadata, or a kind of "null" loudness metadata, that states the audio should just be decoded as-is, without any dynamic range correction applied.
In the Exhale API you can set a few different loudness-related fields, but they all reference tables from the standards, which I don't have. I didn't know if anybody can help craft what these fields should be set to to signal that there's no/empty DRC? I just want the audio to be decoded using the same methods as the other codecs.
The fields, for reference:
  • bsSamplePeakLevel
  • methodDefinition
  • methodValue
  • measurementSystem
  • reliability
Reply #1063
I'll write a detailed answer on Gitlab on the weekend. A short answer for now:
Indeed, unlike in AAC, loudness metadata must be present in xHE-AAC. Therefore, you, as a user of this Extended HE-AAC encoding library, must take care of on-the-fly loudness normalization (similar top what's being done on the radio) to -23 LUFS. In general, I highly recommend you use a properly tested and certified commercial solution incorporating such loudness normalization and HLS interfacing - exhale wasn't developed for your "live streaming" use case, and unfortunately, I won't be able to help you very much.
Chris
Reply #1064
Thank you for the response.
Unfortunately, all the commercial solutions I've found start at ~$1,000 (or you need to contact for a quote, which I assume is going to be in the thousands), and this is for a hobby project. My budget is effectively $0 + my free time.
I do look forward to reading the detailed response, the reason I do all this is for learning, so thank you in advance for helping me learn more about all this tech.
Reply #1065
I confess that, in an attempt to maintain backward compatibility with exhale's initial API, the loudness info pass-over got pretty complicated. Don't know yet about the bsSamplePeakLevel for -1 dBFS (let's figure this out privately and update this post later  - done), but revisiting app/exhaleApp.cpp, I was able to collect the following numbers for you:
  • bsSamplePeakLevel = 672, for -1 dBFS
  • methodDefinition = 1, see constant EA_LOUD_INIT
  • methodValue = 139, for -23 LUFS
  • measurementSystem = 2, part of value 11 in code
  • reliability = 3, part of value 11 in code
Chris
Reply #1066
A Quick question about encoding, I  have 6 and 8 channel WAV files that I want to encode as hexagonal and octagonal that is 6.0 and 8.0 ( and eventually  16.0 ) without lfe lowpass filtering, this is for Ambisonics.
Can this be done with exhale?
If so how? What parameters to use?
Reply #1067
Sorry, no, exhale, as an Extended HE-AAC encoder, doesn't support 6.0 and 8.0 audio. The xHE-AAC standard suite itself doesn't even support 5.1 (it specifies mono and stereo audio only).
Chris
