Topic: Album Art Downloader XUI (Read 1298415 times) previous topic - next topic
  • mamyllyn
Re: Album Art Downloader XUI
Reply #2800
Hello,
Here is the answer to my own question:
Uninstall all and do it again.
Now all the covers are saved to the directory where they are missing from!
I have one question that  I can not figure out:
How can I add a setting so that the album art will be downloaded straight to the folder that is missing the album art? Now it downloads it to my music folder and not to the specify folder like: Anthrax/Stomp folder.
  • mm511
Reply #2801
Been using Album Art Downloader for a while on my Windows 10 machine.
Suddenly it will not load. Spits out the following error code, something about fonts. I did install a new font recently, but can that really break a program this thoroughly? Help!
Album Art Downloader has encountered a fatal error, and has had to close.
If you wish to report this error, please include this information, which
has been written to the file: C:\Users\mm511\AppData\Local\Temp\AAD_errorlog.txt
App version: 1.0.2.0, running on Microsoft Windows NT 6.2.9200.0 (64 bit)
System.TypeInitializationException: The type initializer for 'System.Windows.Media.FontFamily' threw an exception. ---> System.IO.IOException: More data is available.
   at Microsoft.Win32.RegistryKey.Win32Error(Int32 errorCode, String str)
   at Microsoft.Win32.RegistryKey.GetValueNames()
   at MS.Internal.FontCache.FontSourceCollection.SetFontSources()
   at MS.Internal.FontCache.FontSourceCollection.GetEnumerator()
   at MS.Internal.FontCache.FamilyCollection.BuildFamilyList(List`1& familyList, SortedDictionary`2& familyNameList, SortedList`2& frequentStrings)
   at MS.Internal.FontCache.FamilyCollection.MS.Internal.FontCache.IFontCacheElement.AddToCache(CheckedPointer newPointer, ElementCacher cacher)
   at MS.Internal.FontCache.HashTable.Lookup(IFontCacheElement e, Boolean add)
   at MS.Internal.FontCache.CacheManager.Lookup(IFontCacheElement e)
   at System.Windows.Media.FontFamily..cctor()
   --- End of inner exception stack trace ---
   at System.Windows.Media.Typeface..ctor(FontFamily fontFamily, FontStyle style, FontWeight weight, FontStretch stretch)
   at MS.Internal.Text.DynamicPropertyReader.GetTypeface(DependencyObject element)
   at MS.Internal.Text.TextProperties.InitCommon(DependencyObject target)
   at MS.Internal.Text.TextProperties..ctor(FrameworkElement target, Boolean isTypographyDefaultValue)
   at System.Windows.Controls.TextBlock.GetLineProperties()
   at System.Windows.Controls.TextBlock.EnsureTextBlockCache()
   at System.Windows.Controls.TextBlock.MeasureOverride(Size constraint)
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Decorator.MeasureOverride(Size constraint)
   at System.Windows.Documents.AdornerDecorator.MeasureOverride(Size constraint)
   at System.Windows.Window.MeasureOverrideHelper(Size constraint)
   at System.Windows.Window.MeasureOverride(Size availableSize)
   at System.Windows.Interop.HwndSource.SetLayoutSize()
   at System.Windows.Interop.HwndSource.set_RootVisualInternal(Visual value)
   at System.Windows.Window.SetRootVisual()
   at System.Windows.Window.SetupInitialState(Double requestedTop, Double requestedLeft, Double requestedWidth, Double requestedHeight)
   at System.Windows.Window.CreateSourceWindowImpl()
   at System.Windows.Window.ShowHelper(Object booleanBox)
   at System.Windows.Window.Show()
   at System.Windows.Window.ShowDialog()
   at AlbumArtDownloader.Splashscreen.ShowIfRequired()
   at AlbumArtDownloader.App.OnStartup(StartupEventArgs e)
   at System.Windows.Application.<.ctor>b__0(Object unused)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Boolean isSingleParameter)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Boolean isSingleParameter, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at System.Threading.ExecutionContext.runTryCode(Object userData)
   at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Boolean isSingleParameter)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.TranslateAndDispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Application.RunInternal(Window window)
   at AlbumArtDownloader.App.AlbumArtDownloader.IPriorInstance.Run()
   at AlbumArtDownloader.InstanceMutex.RunAppAsServiceHost(IPriorInstance instance, String channelUri)
   at AlbumArtDownloader.App.Main(String[] args)
  • AlexVallat
  • Developer
Reply #2802
Yes, unfortunately fonts can break all WPF programs, for example: http://faithlife.codes/blog/2009/11/how_to_crash_every_wpf_application/
You could try removing and re-registering the font, it might help.
  • JWiels
Reply #2803
Getting repeated crash when trying to update/change presets:
Error log:
? is there a fix?
has been written to the file: C:\Users\johnw\AppData\Local\Temp\AAD_errorlog.txt
System.ArgumentNullException: Value cannot be null.
Parameter name: element
   at System.Windows.Media.VisualTreeHelper.GetChildrenCount(DependencyObject reference)
   at AlbumArtDownloader.Common.FindVisualChild[TChild](DependencyObject obj)
   at AlbumArtDownloader.EditPresets.OnNewItemContainerGenerated(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at System.Windows.Controls.ItemContainerGenerator.SetStatus(GeneratorStatus value)
   at System.Windows.Controls.ItemContainerGenerator.Generator.System.IDisposable.Dispose()
   at System.Windows.Controls.VirtualizingStackPanel.MeasureOverride(Size constraint)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
   at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
   at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
   at AlbumArtDownloader.ArtSearchWindow.OnEditPresets(Object sender, RoutedEventArgs e)
   at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
   at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
   at System.Windows.Controls.MenuItem.InvokeClickAfterRender(Object arg)
  • AlexVallat
  • Developer
Reply #2804
Error log:
? is there a fix?
Thanks for reporting that. I haven't been able to reproduce the issue, can you give me the exact steps that cause it? On the popup menu you click "Edit Presets..." and then what, it crashes immediately? Or are you trying to add or delete a preset? Have you previously been able to add or delete any presets? You could try resetting your settings by deleting the %localappdata%\AlbumArtDownloader folder, that might help.
  • JWiels
Reply #2805
Previously have successfully edited presets to make a list of about 8.  But have experienced many crashes in the edit preset process recently.
The above log was triggered by clicking 'Add' while in 'edit presets' dialog.
Crash trigger is inconsistent; sometimes when selecting 'edit presets', sometimes 'Add', sometimes after editing at 'close' after editing.  It will always crash once 'edit preset' is started.  At some step in the process. Even edit then immediately close -> crash.
Preset edits are  never saved. The list reverts to the previous list of presets.
Will check the app data folder.
Can this file or list be manually edited?
Thanks for quick reply
