eMule 0.28a is out
2003-04-17 16:06:37
Downloadhttp://www.emule-project.net/home/perl/gen...amp;rm=download ---------------------- - April 15th, 2003 - ---------------------- Sony/bluecow: tweaked hashing algorithm, should be less CPU intensive now VQB: long UL sessions checked for not "full chunk" method VQB: prevent multiple checks of directories when hashing (khaos) ---------------------- - April 14th, 2003 - ---------------------- VQB: added Total UL/DL ratio to statstree ---------------------- - April 13th, 2003 - ---------------------- bluecow:Redid "Add Friend" dialog. bluecow:Added "Detail" dialog for not connected friends. If a friend is currently connected, the details function shows the "Client Details" dialog. ---------------------- - April 12th, 2003 - ---------------------- Unk: Receive Hard and Soft file limit for servers. Unk: Server list was not updated when a server description was received. bluecow:Workaround for columns resizing to zero width when double clicking on divider. bluecow:Fixed bug where unwanted client could become a friend. bluecow:Fixed bug with OP_ASKSHAREDFILESDIR where remote client does not get the shared files from a folder which has no trailing backslash. bluecow:Support for viewing remote client's shared directories in search results. bluecow:Fixed bug where client changed from HighID to LowID and receives still the old HighID of itself via source exchange and wanted to connect to itself. ---------------------- - April 11th, 2003 - ---------------------- bluecow:Unified all message boxes. bluecow:Optimized drawing and sorting functions for several list controls. bluecow:Fixed bug in source exchange where client gets no sources as long as it does not have at least one complete part. bluecow:Little optimization on loading of server.met bluecow:Implementation of eDonkey protol message OP_END_OF_DOWNLOAD bluecow:Several small code changes and potential bug fixes due to temporary compiling with warning level 4! ---------------------- - April 9th, 2003 - ---------------------- bluecow:Fixed bug when requesting hashset and remote client does not answer immediatly with the hashset. bluecow:Fixed heap corruption when receiving a server's OP_SERVERIDENT without any strings ---------------------- - April 7th, 2003 - ---------------------- Ornis: Categories: Doubleclick opens category-preferences; Category shown as downloadlist column (optional) Ornis: Category: new priority preference - new assigned files get this priority Ornis: Category: resume next paused download in the same category (optional & manual) Ornis,bluecow: MLDonkey better recognized Ornis: Red warning rating icon is shown when more than 1/3 of the ratings are bad ---------------------- - April 6th, 2003 - ---------------------- bluecow:New first run time wizard. bluecow:Hotfix for partfiles getting too large. bluecow:Fixed credit score ratio computation for clients which have transfered >4GB to an other individual client. (thx le_fred+Harvey56) ---------------------- - April 5th, 2003 - ---------------------- bluecow:New log window with a rotating log, max. nr. of lines can be specified in preferences.ini (MaxLogMessages=<num>; <num>=-1 ... unlimited) Ornis: Webserver: downloadlist shows priorities of files and the controls to change it Ornis: Webserver serves images. Local files (contained in binary zip & self installer) are now used for webserver display ---------------------- - April 4rd, 2003 - ---------------------- Ornis: Removed unnecessary repaint (&program-freeze) of the statistic graphs ---------------------- - April 3rd, 2003 - ---------------------- bluecow:Fixed bug with message box "An attempt was made to access an unnamed file". Instead of that message box the log entry "Invalid or corrupted packet received" is created. bluecow:Minor speed improvements by replacing many functions which deal with MD4 hashs. bluecow:Added small hex dump log output for unknown opcodes (Maella). bluecow:Double click in all client related listview controls opens client detail dialogs. bluecow:Double clicking on download filename opens file details dialog. bluecow:Sources found during local server and UDP searching are stored and eventually added to the download file. bluecow:If adding a file to donwloads from a remote clients file list, the remote client is added as a source. bluecow:SearchList: Already downloaded files (found in known.met) are shown with an appropriate color. bluecow:SearchWnd: Last typed in server-met URL is saved in preferences. ---------------------- - April 1st, 2003 - ---------------------- bluecow:Fixed deadlock when canceling an HTTP download of server.met Ornis: Tooltips over cat-tabs displays some summary information of that category Ornis: optional display of the cat-tabs as "Title (loading/Filecount)" (Preferences->Display) Ornis: Statusbar doubleclick: e.g. Log-Pane shows complete line in MessageBox, MessageIcon opens the message-window Ornis: Show webserverstatus in the "MyInfo"-box, incl. current active sessions ---------------------- - March 30th, 2003 - ---------------------- Ornis: Webserver: fixed sorting transferlist by progress Ornis: Save category-setup during runtime (avoid loosing settings) Ornis: Date and time representation appropriate for locale ---------------------- - March 28th, 2003 - ---------------------- Ornis: Webserver: Dont allow guests to clear the logs Ornis: Webserver: server-search control via webserver & start downloads Ornis: Wevservertemplate: set file-settings are saved now Ornis: more shortcuts for the lists: Ctrl+A selects the whole list; downloadlist +,-,Cursor left/right to expand&collapse sources of files ---------------------- - March 26th, 2003 - ---------------------- Ornis: Uploads-Tooltip better display of transferred data Ornis: new: Scheduler, to plan settingchanges & actions Ornis: select the webserver-template as preference ---------------------- - March 26th, 2003 - ---------------------- Ornis: Webserver, portchange restarts webserver automatically [cax2] Ornis: Webserver, disable guestlogin reacts immediately Ornis: Some potential (certain circumstances) exitcrashes fixed [2bottleMOD]
