All right... here is a small list of a few switches I'd like to see added:
-artwork : Adds cover artwork from JPG, PNG or GIF files. If multiple
<image> : images are being added to a single album, the assumed sequence
: is FRONT COVER, INSIDE 1, INSIDE 2, ... BACK COVER
-cdtextcue : Parses an extended CD-TEXT compliant CUE sheet to determine
<cue> : MPEG-4 chapters, album information and song tags.
-channels : Specifies the desired number of audio channels in the encoded
<number> : stream, if this differs from the source.
: "1" will downmix to mono, by averaging channels.
: "2" will downmix surround to stereo, or duplicate a single
: channel as dual-channel mono.
-invert : Specifies channels to invert. For stereo, can be used
<chan,chan> : without any additional parameters to switch L and R.
: For surround, channel pair to be inverted must be specified
: (LF, RF, LR, RR, FC, P1...).
: If inverting multiple sets in a surround signal, sets may
: be given in sequence.
: EX -> "-invert LF,LR,RR,RF" would switch the LF with the LR,
: and the RR with the RF.
: WARNING: It is pointless to use this with MONO! (Lest you ask...)
Sigh... wishful, wicked and ungrateful, isn't it?
Appreciatively,
- M.
