Batch FLAC --> MP3 conversion with a different file structure?
Reply #9 – 2015-02-21 15:52:47
You could just go on that folder, press F3 (search) -> *.* cut the files and paste them onto the root. Are you sure it's not better to move them with foobar2000 with another renaming scheme? What car do you have? did you mean just run Foobar as a conversion, but altering the file path to be without an Artist sub folder (I.e. At Root)? Since I posted the other thing that occurred to me was that it'd be ideal if I could simply promote files from folders where there's a single file (which I suspect is a lot of them) and have all those folders that have multiple files stay the same, so that I can take advantage of limiting play to a single folder/artist, if wanted (as you can limit play to within a particular folder). But now I think I'm probably going beyond practical limitations and reasonableness. The car is a new Honda CR-V VTi-S (middle of the range). It's crazy how far car audio lags and the limitations you come up against with compatibility and file formats. NOT "right click - Convert" BUT "right click -> File Operations -> Move to". Honda is what I was afraid you were going to say, the car is amazing but the audio management is a goddamn mess. We bought a new Odyssey and wow, I am still looking for a good way to copy the files for travel since we don't want to keep touching the skip, volume etc. I didn't even know about the 650 limit. This is my Car configuration: Conversion Format: FDK AAC VBR 3 (~100 kbps) + ReplayGain calculated automatically after conversion + Manually apply to the file. Honda doesn't read the tags and you always have the lossless backup to reconvert if something doesn't work properly. Destination: this is what I am still working on. It used to be:[%genre%]\[%artist% ][%date% ][%album% ][D%discnumber% ][%tracknumber% ][%title%] and this is what I use now (still have to use it really): [%artist% ][%date% ][%album% ]\[D%discnumber% ][%tracknumber% ][%title%] One simple change/removal of the genre tag changes how you organize, play, travel, feel. It changes everything, I still have to test it but I think this new way will work better. Try and see.
