Topic: Unable to interpret CueTools repair results (Read 738 times) previous topic - next topic
hi all,
I ripped a CD with EAC using secure mode.  The resulting log file indicated there were errors with 3 files - "3 track(s) could not be verified as accurate".
I ran the repair feature on CueTools, but I don't know what to make of the result.  I have new flac files in the output folder along with three other files: image.accurip, image.cue, and image.log.  The .accurip file indicates it has "corrected 307 errors", but I don't know what the rest of the log is telling me.  The .log file appears to be identical to the original EAC log including the error messages, so I don't really know why its there.  Most importantly, are the new flac files repaired?
I apologize if my question seems obvious or if its been answered elsewhere - I've searched within this forum and on google, but I've not found anything that explains things in a manner I can comprehend.
I've uploaded the EAC log and the .accurip file - any help would be greatly appreciated.
thx
Exact Audio Copy V1.6 from 23. October 2020
EAC extraction logfile from 24. October 2024, 10:09
Ruthie Foster / Full Circle
Used drive  : ASUS    DRW-24B1ST   c   Adapter: 1  ID: 0
Read mode               : Secure
Utilize accurate stream : Yes
Defeat audio cache      : Yes
Make use of C2 pointers : No
Read offset correction                      : 6
Overread into Lead-In and Lead-Out          : No
Delete leading and trailing silent blocks   : No
Null samples used in CRC calculations       : Yes
Used interface                              : Native Win32 interface for Win NT & 2000
Gap handling                                : Appended to previous track
Used output format              : User Defined Encoder
Selected bitrate                : 768 kBit/s
Quality                         : High
Add ID3 tag                     : No
Command line compressor         : C:\Program Files (x86)\Exact Audio Copy\FLAC\FLAC.EXE
Additional command line options : -5 -V -T "ARTIST=%artist%" -T "TITLE=%title%" -T "ALBUM=%albumtitle%" -T "DATE=%year%" -T "TRACKNUMBER=%tracknr%" -T "GENRE=%genre%" -T "COMMENT=%comment%" -T "BAND=%albuminterpret%" -T "ALBUMARTIST=%albuminterpret%" -T "COMPOSER=%composer%" %haslyrics%--tag-from-file=LYRICS="%lyricsfile%"%haslyrics% -T "DISCNUMBER=%cdnumber%" -T "TOTALDISCS=%totalcds%" -T "TOTALTRACKS=%numtracks%" %hascover%--picture="%coverfile%"%hascover% %source% -o %dest%
TOC of the extracted CD
     Track |   Start  |  Length  | Start sector | End sector
        1  |  0:00.00 |  3:49.40 |         0    |    17214
        2  |  3:49.40 |  4:04.30 |     17215    |    35544
        3  |  7:53.70 |  3:00.65 |     35545    |    49109
        4  | 10:54.60 |  5:22.04 |     49110    |    73263
        5  | 16:16.64 |  4:44.01 |     73264    |    94564
        6  | 21:00.65 |  2:25.14 |     94565    |   105453
        7  | 23:26.04 |  4:57.21 |    105454    |   127749
        8  | 28:23.25 |  5:41.18 |    127750    |   153342
        9  | 34:04.43 |  4:05.55 |    153343    |   171772
       10  | 38:10.23 |  4:08.41 |    171773    |   190413
Track  1
     Filename G:\Torrents\Ruthie Foster\01 Smalltown Blues.wav
     Pre-gap length  0:00:02.00
     Peak level 98.9 %
     Extraction speed 1.3 X
     Track quality 99.9 %
     Copy CRC A82D9322
     Cannot be verified as accurate (confidence 3)  [FAF5592F], AccurateRip returned [3E1CDCF8]  (AR v2)
     Copy OK
Track  2
     Filename G:\Torrents\Ruthie Foster\02 Get Out Of My Way.wav
     Pre-gap length  0:00:00.44
     Peak level 89.3 %
     Extraction speed 2.0 X
     Track quality 100.0 %
     Copy CRC 51423687
     Accurately ripped (confidence 3)  [3CDC5F73]  (AR v1)
     Copy OK
Track  3
     Filename G:\Torrents\Ruthie Foster\03 Rain From My Shoulders.wav
     Pre-gap length  0:00:00.45
     Peak level 80.2 %
     Copy CRC 9FCF517D
     Accurately ripped (confidence 3)  [572FB2BE]  (AR v1)
     Copy OK
Track  4
     Filename G:\Torrents\Ruthie Foster\04 Lost In The City.wav
     Pre-gap length  0:00:01.45
     Peak level 83.1 %
     Extraction speed 1.9 X
     Copy CRC 74692B19
     Accurately ripped (confidence 3)  [B76E5CC0]  (AR v1)
     Copy OK
Track  5
     Filename G:\Torrents\Ruthie Foster\05 Home.wav
     Peak level 79.4 %
     Extraction speed 2.6 X
     Copy CRC FB5CE30F
     Accurately ripped (confidence 3)  [CB6D2036]  (AR v1)
     Copy OK
Track  6
     Filename G:\Torrents\Ruthie Foster\06 Those Who've Flown Away.wav
     Peak level 71.6 %
     Extraction speed 2.4 X
     Copy CRC ED101D9B
     Accurately ripped (confidence 3)  [88BECA23]  (AR v1)
     Copy OK
Track  7
     Filename G:\Torrents\Ruthie Foster\07 Prayin' For Rain.wav
     Peak level 98.9 %
     Extraction speed 2.8 X
     Copy CRC 289402A0
     Accurately ripped (confidence 3)  [0AD2B04F]  (AR v1)
     Copy OK
Track  8
     Filename G:\Torrents\Ruthie Foster\08 Full Circle.wav
     Pre-gap length  0:00:00.43
     Suspicious position 0:01:44
     Suspicious position 0:01:46
     Peak level 98.8 %
     Extraction speed 1.0 X
     Track quality 99.6 %
     Copy CRC D6EAD0F5
     Cannot be verified as accurate (confidence 3)  [CBE46926], AccurateRip returned [13120611]  (AR v2)
     Copy finished
Track  9
     Filename G:\Torrents\Ruthie Foster\09 Heal Yourself.wav
     Peak level 98.8 %
     Extraction speed 3.1 X
     Copy CRC E7996AEF
     Accurately ripped (confidence 3)  [0317A39B]  (AR v1)
     Copy OK
Track 10
     Filename G:\Torrents\Ruthie Foster\10 The Fight.wav
     Peak level 68.6 %
     Extraction speed 1.1 X
     Track quality 99.7 %
     Copy CRC B09EF584
     Cannot be verified as accurate (confidence 3)  [D29BE52F], AccurateRip returned [9D4BE1B5]  (AR v2)
     Copy OK
 7 track(s) accurately ripped
Some tracks could not be verified as accurate
There were errors
End of status report
---- CUETools DB Plugin V2.1.6
[CTDB TOCID: 2faTjEFCFb9j8Ez6op23zQ7l6p4-] found
Submit result: 2faTjEFCFb9j8Ez6op23zQ7l6p4- has been submitted
Track | CTDB Status
  1   | (11/11) Differs in 91 samples @02:54:70-02:54:71,02:55:23
  2   | (11/11) Accurately ripped
  3   | (11/11) Accurately ripped
  4   | (11/11) Accurately ripped
  5   | (11/11) Accurately ripped
  6   | (11/11) Accurately ripped
  7   | (11/11) Accurately ripped
  8   | (11/11) Differs in 213 samples @01:45:42,01:45:71-01:45:72,01:46:70-01:46:71,01:47:10
  9   | (11/11) Accurately ripped
 10   | (11/11) Differs in 3 samples @02:06:14
If you are sure that your rip contains errors, you can use CUETools to repair it.
==== Log checksum E79BDE1F3742D166A061B814598432A8165F08B4858230A617CAEFEB64DE6EE3 ====
Re: Unable to interpret CueTools repair results
The EAC extraction log is just a copy (no changes).
I'll look at the accurp log later (unless you could just post the text).
korth
So to be clear, the image.log is always simply a copy of the original EAC log?
This is the text of the image.accurip file:
[CUETools log; Date: 24-Oct-24 11:10:55 AM; Version: 2.2.5]
CUETools DB: corrected 307 errors.
[AccurateRip ID: 000f8a41-007d7c15-8109ea0a] found.
Track   [  CRC   |   V2   ] Status
 01     [3e1cdcf8|55d887b9] (3+0/7) Accurately ripped
 02     [3cdc5f73|6c073956] (3+0/7) Accurately ripped
 03     [572fb2be|98137e75] (3+0/7) Accurately ripped
 04     [b76e5cc0|99d8b253] (3+0/7) Accurately ripped
 05     [cb6d2036|f8009360] (3+0/7) Accurately ripped
 06     [88beca23|ea4c0235] (3+0/7) Accurately ripped
 07     [0ad2b04f|8658866c] (3+0/7) Accurately ripped
 08     [13120611|83c6639f] (3+0/7) Accurately ripped
 09     [0317a39b|a39e3a7c] (3+0/7) Accurately ripped
 10     [9d4be1b5|2ec689f1] (3+0/7) Accurately ripped
Offsetted by -5:
 01     [2d4f14d8] (0/7) No match (V2 was not tested)
 02     [87d07f9d] (0/7) No match (V2 was not tested)
 03     [176b20c5] (0/7) No match (V2 was not tested)
 04     [40e30f29] (0/7) No match (V2 was not tested)
 05     [9c36d3d7] (0/7) No match (V2 was not tested)
 06     [a0e74765] (0/7) No match (V2 was not tested)
 07     [6ae785c1] (0/7) No match (V2 was not tested)
 08     [5d4afffb] (0/7) No match (V2 was not tested)
 09     [4df27fe0] (0/7) No match (V2 was not tested)
 10     [58f743bc] (0/7) No match (V2 was not tested)
Offsetted by 676:
 01     [84642778] (0/7) No match (V2 was not tested)
 02     [0d882fab] (0/7) No match (V2 was not tested)
 03     [6afffd72] (0/7) No match (V2 was not tested)
 04     [5299bd4c] (0/7) No match (V2 was not tested)
 05     [541a4262] (0/7) No match (V2 was not tested)
 06     [17d60227] (0/7) No match (V2 was not tested)
 07     [e5458c0c] (0/7) No match (V2 was not tested)
 08     [48b67238] (0/7) No match (V2 was not tested)
 09     [0357821a] (0/7) No match (V2 was not tested)
 10     [2c71ffd0] (0/7) No match (V2 was not tested)
Track Peak [ CRC32  ] [W/O NULL] [  LOG   ]
 --   98.9 [22EABDAD] [1F2C3112]
 01   98.9 [B8066B04] [1FD8B355] [A82D9322]
 02   89.3 [51423687] [BF039AE9]   CRC32
 03   80.2 [9FCF517D] [A6852A79]   CRC32
 04   83.1 [74692B19] [C37C4BAC]   CRC32
 05   79.4 [FB5CE30F] [DCB17054]   CRC32
 06   71.6 [ED101D9B] [6A163057]   CRC32
 07   98.9 [289402A0] [9DB3EA6D]   CRC32
 08   98.8 [96FC7880] [EA98F06D] [D6EAD0F5]
 09   98.8 [E7996AEF] [CBF37B8A]   CRC32
 10   68.6 [0CBAB1E8] [DA2A200D] [B09EF584]
Yes.
The bottom section of the accurp log is showing you the CRC32 of tracks 1, 8, and 10 are now different than they were in the image.log (look at the 'log' column, CRC32 means a match to that column, the original CRC hash in the log column means a difference).
The top AccurateRip section shows all ten tracks as accurate with a confidence of 3.
Edit: try to explain log hash difference better and fix auto-spelling-correction errors.
korth
thanks Korth,
I can be confident then that CueTools has done a repair?
It was the image.log file that had me confused, not to mention the other info in the .accurip file (Offsetted by -5 and Offsetted by 676).
I've tried CueTools a handful of times before, but I've always been a bit unsure exactly what it was doing.
You could run 'verify' on the repair. That would give you both CTDB and AccurateRip results.
If you have the 'Verify' section on the AccurateRip tab set to 'Write AccurateRip log' 'In source folder', you should make a backup (rename) image.accurip
In this wiki page I tried to explain the accurip log.
korth
