Topic: ID3v2.4 Tag Editor (Read 2898 times) previous topic - next topic
ID3v2.4 Tag Editor
Hello!
I am looking for an ID3v2.4 tag editor which should also write tags at the end of the file (feature introduced in ID3v2.4 tags). Those are NOT ID3v1(.1) tags.
Thanks,
Sebastian
ID3v2.4 Tag Editor
I don't if programs like "tag and rename" only uses id3v2.3 but helium2 can use id3v2.4.
www.helium2.com
I guess many programs won't use id3v2.4 before winamp supports it.
ID3v2.4 Tag Editor
EAC can write id3v2.4, however I'm not sure if it's writen @ the ass by default.
ID3v2.4 Tag Editor
The only one I know that can write them to the EOF is Frontah
"You have the right to remain silent. Anything you say will be misquoted, then used against you."
