Topic: Questions of formatting the status bar and Column List (Read 2044 times) previous topic - next topic
Can the status bar be formatted to to show the number of selected files?  Also can Column UI be formatted so one of the columns is the date the file was modified.  I tried adding this "%_file_mod_date%" to the Column Ui > Playlist View > Columns, the Title as "Date Modified" Linked meta field "%_file_mod_date%" but that didn't display anything.
Marc
use %last_modified% instead %_file_mod_date% (where did you get that tag name?)
status bar can show the lenght of selected items
for the number of selected, i think it can't show
I tried %last_modified% and still no data shows up.  What else should I try?
"Linked meta field" is AFAIK only for inline editing, not display. (And should be in a form like ARTIST, not %artist%.)
[edit] ah, he is using "Linked meta field"
