Topic: "frameless" windows on second monitor? (Read 4487 times) previous topic - next topic
Hey all, I've recently discovered the beauty that is dockable_panels, I like having my foobar set up on my second monitor.
But if I Have a window without a "frame" and I close foobar, when i open it again, the borderless window will have moved to the primary monitor. Almost as if it's position had been "reset"
this doesn't happen with a window with the title bar still on it.
Anyone know of a solution, or have seen this problem before and direct me to a solution?
Thanks in advance.
Could be a bug on my end, I added it to my list of known bugs, and I'll look into when i get a chance.
There used to be a link to my website here.
Awesome, I didn't expect you to respond. I gotta say, I'm a big fan!    If it wasn't for your easy-to-use, functional, customizable components, I would have been scarred away from foobar before I really got to see how cool it is. Keep up the good work!
Is your secondary monitor on the left or the right of the primary?
Actually I am using dockable panels on a multimonitor setup and am experiencing wierdness too.
Docked or undocked, with or without titlebar.. if I close foobar with the panel showing then the next time I load foobar the panel is a tiny little box in the upper left corner of my primary monitor (0,0 coordinates, smallest size?) and I have to resize it. If I close foobar with the panel hidden then the next time I load foobar the panel is the proper size but has been repositioned to the upper left corner of my primary monitor.
Mine is on the left
Edit: your "beta" seems to have done the trick, thanks!
